View Poll Results: Do you think people would buy a diesel-powered 60s American Classic?
Yes, they'd be lining up to pay $8k or more 9 17.65%
Sure, there'd be a few people interested in paying $6k-8k 15 29.41%
Good luck, I'm sure someone would pay $4k-6k 10 19.61%
It's your dream, but you might be alone on this one 17 33.33%
Voters: 51. You may not vote on this poll
Old 01-19-2012, 03:26 AM   #41 (permalink)
Originally Posted by lacolocho View Post
I would love to hear more if you ever do the 7.3L swap.
Do you know if it needs modifications to bolt in?
Don't ever plan on one ford engine being able to bolt up to where another one was just removed. Ford is very, very bad about backwards, forwards and lateral bolt up compatability.
Old 01-19-2012, 07:10 PM   #42 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Keep on mind that 7.3 engine (International T444E) engine is a 1,200 lb hunk of iron. Every 1960s chromium bulldozers will become undriveable with that bank vault up front.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 01-19-2012, 10:29 PM   #43 (permalink)
That was my thought about it too. If there's a will there's a way. I wouldn't want to try it, but I'd sure like to see one
Old 01-19-2012, 11:00 PM   #44 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Hey all, new to the forum.
I'm considering swapping diesel engines into 50s or 60s American cars and was referred to a post on this forum by someone over at the Benzworld.org
What do people think of doing such a swap?
I think the swap is just fine, most people driving a classic around here took out the straight 6 or 4 banger and put in a 350 and made a tricycle out of it.
I myself had my 82 6.2 diesel swapped into another suburban with a 5sp MT. for a craftmobile. The key with 6.2s is to stick with the C code motors (pollution control) and keep them slow and lumbaring preferably with a manual transmission and a nice high rear end. (2.5's/2.8's with an old 3sp + granny is best) I considered strongly swapping my 6.2 into a big cheap motorless ancient bently with a nice Scrooge McDuck look. I might be alone in that line of thought however. I was thinking I could keep the motor to the rear of the engine bay and use the rest as a trunk.
Anyway An 82 C-code 6.2 with good heads and bolts will last 500k as long as the harmonic balancer is decent.
A 6.2 is good at fuel economy but not at power, that is all you need to know, abuse it and loose it.
Oddly the same is true of the 5.7 olds and good wrench, I see many of them lasting in the 500k area so long as people added
1. Fuel water separators
2. Replace the head bolts occasionally.
Those that didn't have vastly different oppinions of that same motor.
Also my 82 6.2 still has the original pump, sadly I have an air leak which makes it hard to start but once running it is just fine and pokey as it was designed to be. The air leak has messed up my accellerator pedal (nothing then vroom) but I think a lift pump might fix it.
A 6.2 is a MUCH better idea than a Ford product because it is just about as easy to install as a 454/350 and can use all of the same parts and it is MUCH lighter.
Cheers
Ryan
Old 01-19-2012, 11:20 PM   #45 (permalink)
Yes the 7.3 will take some modding to put into the mercury. Im planning for engine mounts and oil pan to be the big ones. This will probly be one of the more straight forward engine swaps ive done. Nothing that zip disks and a welder wont fix!!!! LOL
As far as the weight goes this is not a concern. if it sits too low ill grab some heaver duty coil springs and shocks from the wrecker out of another vehicle. Build some spacers. whatever it takes. there is enough steel in the front of the car already so strength is not going to be an issue. Stopping steering also are not a concern. Im going to put an engine in that makes around 200 LESS HP. Disk brake 9 inch kits are dirt cheap.
Old 01-20-2012, 02:57 AM   #46 (permalink)
The ideal engine combo seems to be small valve C-code heads (those don't usually crack) with C-code small mouth precombustion chambers for fuel economy and a non-EGR J-code intake.
Do you have the original "brick" style fuel filter?
Upgrading to an electric fuel pump is a nice mod. I use the holly blue fuel pump and a carquest 4-7psi pump for back up.
Old 01-20-2012, 02:19 PM   #47 (permalink)
rmay635703's Avatar
It has two fuel filters, the 89 had a brick.
I guess I will do the lift pump thing eventually, I am still wondering the best way to find an air leak to restore it somewhat before I invest in a pump.
Handling might suck having an RWD with most of the weight ahead of the front axle and the go pedal won't work on ice.
Old 01-20-2012, 03:07 PM   #48 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by me and my metro View Post
I am a diesel mechanic by trade. I have run GM diesels over the last 30 years. Back in the early 80s I stuck a 4.3l Olds v-8 diesel in a 68 Vista-cruiser.
I thought the V8 was a 5.7 liter. A 4.3 would be a V6.
Old 01-20-2012, 03:41 PM   #49 (permalink)
Any tips on using a 5.9L (other than the pump)?
Those are a lot easier to come by
Old 01-20-2012, 05:16 PM   #50 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
lacolocho -
I picked "Good Luck ...". Instead of American classic cars I would target the people that cherish European classic cars like VWs, Opels, and BMWs. I would guess that they would be more amenable to the "what if " of modern diesel drivetrains in their cars.
CarloSW2
American Solar Energy Society
