Old 07-13-2011, 12:36 PM   #351 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by apowers View Post
Yes I think it is a transforner. I'm not sure I can use it for anything other than a boat anchor.
Alvin
It looks like dual primary's and dual secondaries. Depending on the winding of it, you might be able to use it for an isolation transformer for an non isolated battery charger. If you wire the primaries in series and the secondaries in parallel you can get a pretty powerful step down transformer.
Did you measure the voltage outputs yet?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 07-13-2011, 11:30 PM   #352 (permalink)
apowers's Avatar
I put some DC voltage through it from a tiny 9 volt battery. I don't want to kill myself. That is not easy to measure voltage from it . On the primary side there is 4 taps plus a black wire that seems to be a common. The primary is wound with 17 gauge wire 5 in hand and the secondary is 14 gauge 8 in hand. The common wire has some type of sensor or something mounted tight to the coil under the wrapping.
I have a small transformer that I can run some AC through it. The small battery would just sag to nothing. Just tapping the battery contact was giving lots of different readings. It did burn out a small 12 volt bulb just using the 9 volt battery after it was down to less than 8 volts.
This thing weighs 30 pounds. The wire is copper but a magnet is attracted to the core.
Alvin
Old 07-14-2011, 01:48 AM   #353 (permalink)
Dear Alvn,
please put small AC voltage, then you'll get the output voltage. after that you will have the N ratio of primary and secondary, just use simple mathematic.....
Old 07-14-2011, 02:31 AM   #354 (permalink)
EV Connoisseur
I think DC in a transformer does not work.. or does it?
Old 07-14-2011, 02:36 AM   #355 (permalink)
It doesn't work
Old 07-14-2011, 07:14 AM   #356 (permalink)
Alvin
Transformers only work with AC. The battery was just being shorted out though the copper wire.
The small sensor you see is most likely a temp switch. When the transformer gets too hot, it will open and cut power. This is usually connected to the primary winding.
The core will be iron. Most likely laminated plates. This would be a low frequency in the range of 50-400Hz.
-Adam
Old 07-14-2011, 09:24 AM   #357 (permalink)
apowers's Avatar
There are 4 taps and a commom on the primary. I connected 125 volts AC to each one. The output with the secondary leads in series is 17.4 volts, 27.4volts, 30 volts,and 48volts. Half of the secondary leads halves the output.
I guess that answers my question, it is a transformer. Thanks to everyone for your time.
Alvin
Old 10-15-2011, 12:44 PM   #358 (permalink)
jackbauer's Avatar
Soon my 10kw water heater .... ooops I mean battery charger will be ready for action. Muhahahaha
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
LouMan (10-15-2011), mrbigh (10-15-2011)
Old 10-16-2011, 09:12 AM   #359 (permalink)
jackbauer's Avatar
Mounted the radiator on the enclosure today with a piece of aluminium angle and some 6mm threaded rod. Still not sure if I will mount the radiator in the passenger cabin. Depends on the amount of heat it pumps out!
ID:	9563   Click image for larger version
ID:	9564   Click image for larger version
www.evbmw.com
Old 10-22-2011, 10:43 AM   #360 (permalink)
jackbauer's Avatar
Some more progress on the charger build. Got the control stage built up on a piece of 6mm clear polycarbonate. All of the i/o to the control board are terminated on a piece of barrier strip. Also mounted on the polycarbonate are the display screen and the push buttons. Mounted two epcos 4700uf 400v caps in the main enclosure and a piece of din rail for the input rcbo , earth point and output fuse. Also mounted a 12v 5A dc power supply for the logic and coolant pump.
Can't wait to fire this thing up
ID:	9618   Click image for larger version
ID:	9619   Click image for larger version
ID:	9620   Click image for larger version
ID:	9621   Click image for larger version
www.evbmw.com
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
