12-27-2013, 03:51 PM
Benni - '12 Hyundai Accent SE
Do I really need a SG?
My 2012 Accent outputs instant fuel economy as well as avg fuel economy. I reset my 2nd trip meter every time I fill up, so I know how many miles I have traveled per tank. So the question is, how much more will the SG benefit me? Is it that much more crucial to getting the best economy out of my car, or will it just be a waste since I already have the basic instrumentation? Another quick question is, do more people get the SG II or the SG e? I was looking at the e and it seems to be more geared to what I would use....
thanks!
12-27-2013, 05:37 PM
...beats walking...
The OEM "basics" works fine--for now--but, later, when you want (or need) to know more, like coolant temp, ignition advance/retard, etc., only the SG (or similar) can provide you that information.
The Following User Says Thank You to gone-ot For This Useful Post:
12-27-2013, 06:33 PM
I had a pretty good mpg screen in my Q45 and it got me to 27mpg. Then I found this site and got a sg. Topped out at 32mpg. Especially if you upsize your tires. See link in my sig
12-27-2013, 07:30 PM
Cyborg ECU
Scan Gauge or Ultra Gauge will show you voltage and engine load percentages as well as throttle position and intake air temp... all those are readings I like to have because of all the mods I have and want to monitor. But you have an automatic transmission, so the single best feature, engine load, is not as useful to you. Still, put an Ultra Gauge on your list (cheaper than Scan Gauge by half) and eventually if you get one I doubt you'll ever regret it.
12-27-2013, 09:14 PM
The cost of a device that reads your OBD2 codes alone is $100. The SG and UG can do this and much more. I'd go for the UG between the 2.
If you have an Android though, I would buy an ELM237 and pair it with your phone.
I bought this for $13, and it is full-featured, including the ability to read OBD2 codes and reset the check engine light.
Mini ELM327 Bluetooth OBD2 Auto Diagnostics Scanner w Power Switch for Android | eBay
12-28-2013, 02:07 PM
Smeghead
I have found that in vehicles without factory MPG displays that I really want to have some sort of information (ultra gauge and MPGuino before that). In cars with factory instant and average displays I get by without any extra information that an aftermarket display can provide. so long story short if your car has mpg displays you don't need to buy another thing though the added info is worth the asking price as you get more into it.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
The Following User Says Thank You to bestclimb For This Useful Post:
01-03-2014, 01:39 PM
SG is so good ,, it can tell you how many dollars & cents you spent per trip enabeling you to find the most efficient route, this feature is awesome. i felt the same way as you, i didnt want to fork over 150$ for the scanguage but i have never looked back , my total savings for the 2013-14 year are $514 so it was payed for itself 3 times,
The Following User Says Thank You to dmafanp For This Useful Post:
01-03-2014, 02:18 PM
I second RedPoint5, the engine code reader alone is worth its money, and all of the additional information an aftermarket MPG gauge is also important. Someone once told me that too many people, including mechanics, limit their diagnostics to reading codes, and I spent shops twice what I had previously paid for my Ultraguage, and all they did was use their own code reader.
My understanding is that a code reader tells where you to start diagnosing, but it almost seems like I am better off reading the code, fixing whatever it says is wrong, and going from there.
One morning I drove to the shop simply to have my oil change. I had a CEL, so I had them take care of both, but they wanted $500 to replace my knock sensor, with a "Faulty Knock Sensor" code. The part was $85. It was one bolt and I simply needed to unplug the old one and plug in the new one.
Code readers are good tools for saving money and so are MPG gauges. One thing that I have not read here is that factory gauges tend to be something like 5% off, while you can calibrate an aftermarket one, so that it is much more accurate.
01-04-2014, 12:34 PM
#9 (permalink)
I'm waiting for my UG to arrive. I do not have any instrumentation in my char related to FE except maybe the temp and fuel gauge  but I can still manage decent MPG by just managing the way I drive.
The reason for me getting an UG is to be able to monitor some things better, and hopefully get even more MPG out of my little car.
I won't see crazy increases to make me save the $100 I bought it for during the first 6 months or so, but after that i will probably break even.
Besides, you can bring it with you in every car you want / would buy later on that might not have the fancy equipment of you current car
01-04-2014, 12:43 PM
#10 (permalink)
having instant feedback WILL improve your mpg....it's like a video game....you have to win!!!!
The Following User Says Thank You to mcrews For This Useful Post:
