Old 01-24-2015, 04:06 AM   #51 (permalink)
Silver Magnum - '03 Dodge Ram 1500 Laramie
90 day: 11.43 mpg (US)
Originally Posted by oldtamiyaphile View Post
An average car cruises on about 7hp at moderate speeds. I could see a truck needing maybe 50hp max at cruise.
To work this out you need your hp for given speed/rpm X load. If your truck cruises at 30% load then that's about 50hp based on your figures.
I have no idea what it is now, if I'm on the gas more than a hair (out of OD naturally) its busy accelerating to around 80mph while staying under 2500......I'm just trying to figure out based on the engine in its old stock form needed to produce to move and maintain the truck at a reasonable speed
Old 01-24-2015, 04:17 AM   #52 (permalink)
iowahawk: The Real Acme
This sounds like exactly what you are looking for.
Dear lord........I must make me one of these......for reasons.......(thoughts of having an "I win" button overwhelm all logical thought)
Old 01-24-2015, 12:30 PM   #53 (permalink)
Swapping gears, not cheap is going to be about the least expensive option to see any real improvement.
Old 01-24-2015, 01:43 PM   #54 (permalink)
Historic rocket powered by rubber fuel - Technology & science - Space - Space.com | NBC News
The fuel,N-propyl nitrate, may be hard to come by. Spaceship One burns a combination of [an ingredient of] rubber and nitrous oxide. Burning rubber and NOS would make it fast and furious.
Xist (01-24-2015)
Old 01-24-2015, 04:06 PM   #55 (permalink)
I already have some tall gears, 3.55s because ironically these high gears work better with a stroker for getting power to the ground anyway and I can't go much lower.....the only thing lower would be 3.21 gears
Old 01-24-2015, 04:41 PM   #56 (permalink)
620-bhp
Originally Posted by Striker2237 View Post
well what i meant is that hemi would take the place of my engine, and 345hp is not anywhere close to 620
At what time or condition would you utilize 620-bhp?
My T-100,naked,only required 47-horsepower to maintain 70-mph.
Old 01-24-2015, 09:29 PM   #57 (permalink)
Drag strip............
Old 01-29-2015, 05:45 PM   #58 (permalink)
Drag racing
If you're doing 1/8 or 1/4-mile,your power to weight ratio will be the greatest factor in getting ETs down.Or maintaining what you've already got.
Mass is the poison of acceleration.
If you add a second powerplant/powertrain,that additional weight will really cut into your time and exit velocity.
With no aluminum,or lightweight composite body available,it will be hard to cut weight in order to add weight ,while maintaining a constant weight.
Old 01-30-2015, 12:06 AM   #59 (permalink)
Oh 2nd engine wouldn't be for speed lol! I would make it dis-connectable so It wont get in the way of the 408
Old 01-30-2015, 03:01 AM   #60 (permalink)
Send a message via MSN to markweatherill
A V8 that can do cylinder deactivation would be a better bet. Not as good mpg as a four-cylinder - but arguably better in lots of ways than having a separate four-cylinder in the vehicle.
