Old 07-11-2013, 01:22 PM   #41 (permalink)
EcoPlotting
night9's Avatar
Sliver - '12 Hyundai Elantra limited
90 day: 35.1 mpg (US)
t-ruck - '06 chevy Colorado Lt
90 day: 21.88 mpg (US)
Bob - '09 Harley Sportster Nightster
90 day: 38.88 mpg (US)
Pearl - '14 Toyota Prius C 3
90 day: 48.1 mpg (US)
I know this is way off topic but I was curious about seeing your trucks speed vs mpg chart. It would be interesting to reference. Considering your style of driving, I would assume, has more to do with the amout of time the engine is off and the truck is coasting rather than true ability of the motor to sip gas.
The Following User Says Thank You to night9 For This Useful Post:
101Volts (08-14-2013)
Old 07-12-2013, 09:27 AM   #42 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
I'm not sure how much a speed vs. mpg chart is really going to tell. Most all my driving is engine-off pulse and glide, so my speed is rarely constant.
I think the issue you're referring to is that fuel economy in terms of miles/gal has to do with two issues:
A) How much work/power is required
B) How efficiently that work/power is produced
Part A has to do with both drving style & non-engine vehicle mods. For example, driving slower (or aero mods) decreases the work required because there's less aero drag. Using less brakes also means the engine needs to produce less work per mile.
Part B is addressed by engine mods and, to a lesser extent, driving style. For example, I've switch to low weight synthetic oil, advanced the injection timing, added a ram cold air intake, etc. All these things mean I get more power from the same amount of fuel. The pulse and glide technique helps to, because it keeps the engine at higher loads where the engine is more efficient.
Recently, I've been using my loggers to try to get a handle on these two things (using vehicle speed, engine speed, ECM estimated torque, and ECM estimated fueling). According to that, I'm typically averaging about 0.22 hp-hr/mile and a BSFC of about 0.50 lb/hp-hr (~28% brake thermal efficiency). I'm not sure how accurate the ECM-estimated torque is, but those are the numbers I'm getting.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
The Following User Says Thank You to Diesel_Dave For This Useful Post:
Old 07-12-2013, 09:46 AM   #43 (permalink)
Also, I've been going through some of my loggers. I thought this was an interesting plot, showing how much distance I travelled in differnt speed ranges.
Diesel Dave
The Following 3 Users Say Thank You to Diesel_Dave For This Useful Post:
101Volts (08-14-2013), Joggernot (07-12-2013), mikeyjd (07-13-2013)
Old 07-12-2013, 10:36 AM   #44 (permalink)
Joggernot's Avatar
Just for an example of poor aerodynamics...My 2005 Yamaha 1100 motorcycle gets (measured by me):
28 mpg @ 90 mph
33 mpg @ 70 mph
45 mpg @ 55 mph
54 mpg @ 45 mph
Let's us know that low Cd is good, but motorcycles are not designed for aerodynamic efficiency.
Joggernot
The Following User Says Thank You to Joggernot For This Useful Post:
Old 07-13-2013, 08:45 PM   #45 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
It looks like the majority of your driving occurs between 50-20. Would you say that a typical glide on your main route is 50-20?
The Following User Says Thank You to mikeyjd For This Useful Post:
Old 07-15-2013, 09:35 AM   #46 (permalink)
My communte is ~5 miles in town, followed by ~15 miles on fairly open highway, followed by ~5 miles in town.
In the in-town section I don't get up to 50 mph that often. On the highway section, I do typically pulse up to ~50 mph. How low I go depends on traffic. If there's no one around, I do sometimes go all the way down to 20 mph. Otherwise it depends on if someone's coming up behind me--it can be anywhere from 20 mph to 40 mph.
Diesel Dave
Old 07-18-2013, 04:00 PM   #47 (permalink)
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
Dave, that is great that your mileage was way over the normal for a truck, and that is including lesser vehicles!
DOGS are the best friend a MAN has(most of the time/women at times).
Sorry for the loss, I know you miss your "puppy"...
My best on a 1996 VW Passat TDI variant has been 1,526 miles but on 26 gallons.
I'll get closer to your mileage record after my TDI goes to the doctor(one of these days :-).
The Following User Says Thank You to bikeprof For This Useful Post:
Old 07-19-2013, 12:35 PM   #48 (permalink)
I've seen your truck many times driving to and from work, and had a feeling you were hypermiling (the skirts are a giveaway). I had no idea the results were so good. I only coast to stop lights and draft at a reasonable distance. I'll try not to run you down while I'm cruising at 63mph.
Congrats! And sorry about your dog...
The Following User Says Thank You to Hank1510 For This Useful Post:
Old 07-19-2013, 01:45 PM   #49 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Post #43 is very useful.
What loggers do you use?
I suspect my speed profile shifts to the right.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
Old 07-19-2013, 02:19 PM   #50 (permalink)
I've used the OBDWiz software (it's free). I can get Vehicle Speed over the OBD connection.
Diesel Dave
