Old 12-23-2010, 08:18 AM   #241 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by JasonG View Post
Explain again how an increase in temperature creates more snow ?
They claim it's based on more heat, resulting in more water evaporation, then forget the condensation phase also requires more cold or it just wouldn't happen ...
One of the GW advocates is claiming we could be seeing 50 years of cold winters because of global warming ...
Fits in nicely with the expected trend towards a cooler planet which my geology professor predicted 20 years ago based on previous temperature variations.
The bloke drilled his own ice cores back in the old days.
Apparently he was already a sceptic even befor this GCC thing even started to take off
Landslides have occured for millions of years, it's just one form of natural erosion.
In some places we're accelerating it through land use, but in other places we're temporarily preventing it from happening.
We see it as a bad thing because it takes away our infrastructure, which we foolishly built where nature was bound to destroy it.
Wildfires occur naturally, though many are attributed to arson or plain carelessness (like the recent Israeli wildfires).
Again, humans cause some of them, but at the same time prevent other wildfires from happening or spreading.
Old 12-23-2010, 08:34 AM   #242 (permalink)
euromodder's Avatar
Climate is long term; weather is short term.
Lots of rain (6 months worth in less than a week) is different than it has been -- a data point showing possible long term change.
Why is what you claim as proof of GW, long term, thus climate ?
It is not.
California has had an expectional amount of rain.
It happens.
But it happens infrequently.
That's why you now see it as exceptional.
So it's the weather, it's not climate change.
Guess what, it's nothing new either.
Almost all ancient civilisations speak or write about torrential rains at some time in their history.
One of these tales even made it into a global best-seller.
The snow pack is the source of water in the summer, and if the snow pack is melting faster than it is built up, then that is another data point showing possible long term change.
If the small amount of rain that normally come all through the year stops happening, then you get a drought; then that is another data point showing possible long term change.
You see short term variations and start panicking.
Every change you see instantly becomes a trend, and indicates long term change.
Yet it's not even sure it'll happen next year ...
Anything you see in your lifetime, is short-term by definition ...
A century is less than nothing in the cycles the earth goes through.
Old 12-23-2010, 08:52 AM   #243 (permalink)
Of course we had rain before the temperature average increased. And we had snow, and landslides, and wildfires, and lightning. That is not what we are talking about.
We are talking about changes in the previous patterns, and long term trends in all sorts of things. Just like some places are seeing increases in rainfall, others are seeing decreases in rainfall -- long term changes; we are also seeing larger tropical zones (2+ degrees latitude north and south for 8.5 million square miles more tropics) and we are seeing some areas getting colder.
Overall, the average temperatures are warmer, but that does not mean that they are warmer everywhere.
Warmer temperatures mean that water has lower density -- and greater volume. Higher levels of carbon dioxide mean less heat is lost back out into space, and higher acidity on average in the oceans. But even this is is not all over -- it depends on the temperature; colder water absorbs more carbon, which means that the richest fishing areas will be most affected. It depends on the adjacent land -- limestone areas counteract the acidification somewhat, while granite areas will be affected more.
So sure, it cools things to condense water, but there is more heat to evaporate the water. And the clouds that do not produce precipitation -- cause more warming. Because water vapor is GHG, but it depends on carbon dioxide to "get started".
Warming climate melts more ice -- most all glaciers are melting, as are the Arctic and Antarctic and Greenland ice. It is the land ice that will have the greatest affect on ocean level. But the lowered albedo of open water means there is more heat absorbed.
Warming climate melts the tundra, which is releasing lots and lots of trapped methane. Methane is a far more insulating GHG than is carbon dioxide; so we will see more and more warming now that we have passed the probably threshold of 350ppm of carbon dioxide.
Warming climate is causing plants and animals to die off. Plants in particular are on the other side of the carbon dioxide / oxygen balance in the atmosphere. The large boreal forests that have already died are releasing the carbon dioxide they had absorbed at a much higher rate than if they had a "normal" life cycle.
[Edit: I am not panicking; but I am very concerned. I do believe the scientists, though; because they have looked at all the factors, and as time has gone on (in the decades that they have been working on this), the trends are worse than originally thought; and none of the data indicates that this is anything other than anthropomorphic climate change.
Things have already changed, and we need to acknowledge the facts. We need to do whatever is possible to minimize future changes.]
Old 12-23-2010, 10:53 AM   #244 (permalink)
I believe the scientist. I know it doesn't matter to some here. My arguement is "what if you are wrong?"
If you are wrong, global warming could be a real threat, and if severe enough could threaten extinction of some to many (or all?) species on our ONLY planet.
If the scientists are wrong we'll have "wasted" money building more efficient transportation, less polluting industries, spent more time walking or biking on short trips, carpooled or limited the number of trips unneccesarily to save gas (and money). Etc, etc, etc..
I know it's an over simplification of the problem. But where we can easily lower CO2 emmissions-we must (and why not?), where it is hard to lower-we must try and where it seems impossible-we should try something...
The Following 2 Users Say Thank You to mnmarcus For This Useful Post:
Frank Lee (12-23-2010), NeilBlanchard (12-23-2010)
Old 12-23-2010, 05:14 PM   #245 (permalink)
The PRC.
No that would be just events as opposed to a long term trend where those events become either more or less numerous or serious. And when we say serious do we mean they become bigger or they threaten more of us and our property ? And if the latter then maybe we shouldn't have moved out of the cities to those landslide regions ? Of course when we weren't there we weren't observing them either.
But to get this we have to know a pattern. We only know patterns in some places for 150 years, or less. Did I tell you about the church near where I live which is over 1000 years old and still in continuous use ? The roof leaks. It may be because they replaced the old roof in 1875 or it may have leaked since the place was built in 950-odd or when it was replaced in the intervening time.
Who knows ? We don't have records of all the leaks.
We could of course try to reconstruct the leak rate using the rate of growth of fungus between the stones on the floor or the tide marks in the crypt but before we could do that we would have to get some known leak statistics and construct a relationship between those items and leak rate.
This is really how climate is reconstructed. No honest this is really how it works. People get Nobel prizes for this mince. Unbelievable but true.
If temps are increasing then over what period ?
For this to be significant we would have to be able to say this has not happened before. And we can't. All we can say is that during the pathetically miserable period we have been observing nature with any interest some things have changed.
Those 1000 year temp records are reconstructions. Pretend. Make believe. Made up. Assumptions. Models. Maths. And not very good maths either. See my 1000 year old church example above.
Arhenius worked out the CO2 greenhouse effect in his experiments. He also calculated the feedback rate - i.e. how much the heat retained increases for an increase in the concentration of CO2.
Why do the models always include several times the level he calculated in their software ? Why do the models also assume several times the rate of change observed when calculating the possible effects ?
Of course the clouds also reflect more radiation from the sun something which is hard to calculate or include in models but you can feel it.
You remember the sun, the thing that provides all the energy we use to live? Big, fiery, ball shaped thing in the sky. I remember it, but then again I live in Scotland so I tend not to see it often. Clouds, now I see lots of those very very often.
Have you observed the link between the fiery ball, and clouds and temperatures at all ? In my part of the world when the fiery ball is visible then temperatures get warm. When clouds get in the way then it gets cold and Mrs A complains about being chilly when we sit outside in the garden.
This is an instant effect on local temps. But clouds are tens of square miles in size sometimes. Thats a lot of the ground coolling by a few degrees in a couple of seconds.
Damn tricky to model though. No matter how big your computer is.
Except, er, well, firstly it has happened before and has reversed, and at the moment in the antarctic, you remember that bit at the bottom of the planet, well its getting bigger. More ice you see. And its summer there at the moment.
How do we know ? Well the tundra contains a lot of trapped plant matter. Those plants lived at some point so it must have been warmer.
Anyway why is 350ppm a threshold, says who? A threshold to what exactly? Some kind of vicious circle of some kind ? But the evidence suggests it has been higher before and it went down again. And we are talking about 350 ppm - thats parts per million. Of which our additions are what ?
It hasn't before. Remember those polar bears ? They have lived through much warmer times than now. And it looks like they are still there. In fact there are so many that some countries would like them off the endangered list.
Plants like warmth too - they also like water. Combine the two you get rain forests - loads of life there.
Cold is not good for animals to reproduce either. Apart from the obvious comfort issues to those of us without fur, cold temps also reduce fertility.
I strongly panic about the opposite - that we decide to make loads of changes which do not change the environment - as we aren't doing anyway - but at the same time condemn billions of people to illness, starvation, poverty and ultimately death for no purpose. Meanwhile we live comfortably in the developed world thinking we are making a difference, except we too also stop developing, advancing and growing our knowledge.
If you want to reduce your CO2 drastically then quite simply have no children. Each child is (according to most sources) a tiny CO2 factory in a baby grow. Or indeed move out of the US and the developed world, and live where you simply don't have the means to make CO2. Your life will be miserable, full of illness and with little food, heat or comfort. Your life expectency will be reduced as will that of your children.
Ironically of course all those weather and climate satelites wouldn't be there unless we spent the fuel and created the CO2 to put them there.
I have no problem acknowledging facts. Its just when the talk turns from the facts to trying to apportion some kind of cause and effect I start to disagree. The science is not settled. Thousands of scientists agree and thousands do not - the model of 99% of experts telling you your house is dangerous and 1% not is no longer valid.
Old 12-23-2010, 06:00 PM   #246 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
mnmarcus -
Yes, I agree. This has been posted somewhere else on Ecomodder but I think it fits your POV :
CarloSW2
American Solar Energy Society
The Following 2 Users Say Thank You to cfg83 For This Useful Post:
NeilBlanchard (12-24-2010), tecrench (12-29-2010)
Old 12-23-2010, 06:23 PM   #247 (permalink)
The PRC.
What if you are wrong ?
The implications of what this movement wants is not just a little less car use here, a car pool there. Efficiency and saving money is good - ecomodder good I would suggest.
The full implication of the kind of CO2 reduction program envisaged will affect every aspect of your day. Consider every interface you have with energy. Its not obvious - think everything you consume, from toothpaste to petroleum - they are not unrelated. Think also the food you buy and where you buy it and how you get there. And how do you keep it ? What if you couldn't preserve it in your fridge and had to consume it on the day of purchase ? Maybe you could grow some. Maybe not in winter when the snow is thick on the ground or if you live in a city ?
What about when you are sick, think about the medicines you need. How are they made, how are they researched, tested ? Now think of every one of those costing about 2-3-400% more. Not because it really does, just because someone has decided to tax the perceived CO2 produced by those things ?
Well, you have a choice - you can vote them out.
Now imagine you live in the developing world and your life is already marginal. Now the items you have to buy, note - not choose to buy, cost 2-3-400% more. What are you going to do ? You can't just car pool or turn the heating down a bit.
You probably don't have a vote.
Old 12-23-2010, 06:40 PM   #248 (permalink)
The PRC.
To those who think a low CO2 economy is dead easy.
As you admire that wind farm nearby consider that in each of those wind turbines is a rare metal. This metal has to be refined in a very inefficient and dirty process resulting in some slightly radioactive waste not to mention the near slave labour used to extract it from the ground in the first place.
Oh and the mines themselves are likely to be in China so the material has to come 1/2 way round the world anyway before it can be used.
Anyway, at the end of the day you can admire the zero CO2 (if you ignore the bits above of course) production of about 0.1-0.9% of the peak demand of electricity with the full, satisfying knowledge that there is...
...99.9% of conventional and nuclear power stations to back it up when it isn't working.
Which is quite often.
Old 12-23-2010, 09:36 PM   #249 (permalink)
euromodder's Avatar
Previous patterns that are only some decades old.
Heck, NA and Europe getting colder is a massive area that gets colder, not hotter ...
Sure it's not the whole planet, but it's a sizeable part of it.
Check the ice core data.
High amounts of CO2 in the atmosphere are followed by cooling ... not further warming.
We've been through that, we're coming out of a glacial period.
Things are warming up and have been for ages - like 12000 years, long before any substantial anthropogenic influence could have occured.
The tundra has warmed up in previous warm periods and released methane then, just as it does now.
Cracks in sub-oceanic sealing layers have caused huge oil and gas spills before.
In some places, methane is boiling up from the seabed right into the atmosphere.
As it always has.
Once upon a time, the area where I live used to be sea.
You don't need to dig deeper than 50ft to find the clues and the fossils ... so it's not really that long ago.
The sea has been here a couple of times before, so it's likely to be back some day.
Things cool down after we've had high amounts of CO2.
Old 12-23-2010, 09:51 PM   #250 (permalink)
Hmmm... there are barely enough resources to support life here.... hmmm... what to do? I KNOW! I'll have about 12 kids! It's the solution to everything!
