Old 08-06-2012, 02:44 PM   #91 (permalink)
90 day: 51.82 mpg (US)
Yup, I do! (Assuming both have the same size openings for cooling.)
The many edges of the nose looked too sharp to my eye - it made me think some could be causing energy-robbing vortices.
Only my 2 cents.
Old 08-10-2012, 03:32 AM   #92 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
Electric Water Pump & Fan Digital Controller
Just received my EWP today! It is a EWP80 from Davies, Craig.
Planning to install it as soon as i'm getting a rendez-vous with my mechanic.
The plan is to replace the old HP stealing mechanic water pump for a Manually Controlled Fan & Electric Water Pump. I did not buy this to save money, only for pure fuel economy. It is also part of my belt-less engine project.
Here is its caracteristics as it is ritten on the box :
EWP80 Electric Water Pump Specifications :
Operating Voltage : 3V DC to 15V DC
Maximum Current : 7.5A
Maximum Flow : 80 L/Min, 21 Gallon (US)/Min at 13.5V DC
Operating Temperature : -40°C to 130°C (-40°F to 266°F)
Pump Design : Clockwise Centrifugal
Motor Life : 6000 hrs at 80°C (176°F) and 12V DC
Pump Weight : 900 grams (2.0 Lbs)
Pump Material : Nylon 66%, 30% Glass Filled
Seal : Ceramic Face Seal
Burst Pressure : 350 kPa (50 Psi)
Fan Digital Controller Technical Specifications :
Input Voltage : 12V DC to 15V DC
Output Vge olta: 5V to 15V
Maximum Current : 12A
Operating Temperature : -20°C to 60°C (-5°F to 140°F)
Targeted (Set) Temperature : 75°, 80°, 85°, 90°, 95°C (167°, 176°, 185°, 194°, 203°F)
Controller Type : PCB with Micro Processor
Sensor Type : Thermister in Waterproof Housing
Fan Cut-In Temperature : 3°C (5.4°F) Above Set Temperature
Time Out : 2 Min. (Or Set : 5°C/23°F) After Ignition OFF
Indicator LEDs : Temperature, Power ON, Pump Mode, Test and Fan
Weight : 90 grams (3.2 oz.)
Dimensions (Metric) : 101 mm (L) x 95 mm (W) x 35mm (D)
Dimensions (Imperial) : 4" (L) x 3-3/4" (W) x 1-3/8" (D)
Here are some pictures of the EWP (Note that this post will be updated.) :
This is the box it was delivered in.
This is the EWP & Fan Digital Controller.
Combo Pack pieces.
EDIT : Sorry for the head exercising pictures...
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
The Following User Says Thank You to echo-francis For This Useful Post:
Piwoslaw (02-01-2013)
Old 08-10-2012, 02:44 PM   #93 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
how much did the pump and required controller cost?
Old 08-10-2012, 05:06 PM   #94 (permalink)
40-60-40 MPH P&G
483$ in americain money and 128$ of border tax but i live in canada.
MPG=1 TIME=0
Old 08-10-2012, 06:52 PM   #95 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
You sure are ambitious ! ...That's a good thing !
Old 08-20-2012, 12:40 PM   #96 (permalink)
40-60-40 MPH P&G
Rear Wheel Skirts
Yup! He have laid the two rear wheel skirts.
Here is a picture of the passenger side rear wheel skirt :
The driver side wheel skirt :
The stash we have created to protect us from the sun :
MPG=1 TIME=0
Old 08-20-2012, 12:55 PM   #97 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
It's looking good Francis.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
The Following 2 Users Say Thank You to blownb310 For This Useful Post:
echo-francis (08-20-2012), HyperMileQC (08-30-2012)
Old 08-20-2012, 01:43 PM   #98 (permalink)
Just out of curiosity... did you try disabling the factory power assist to see whether you need the electric?
Old 08-20-2012, 02:06 PM   #99 (permalink)
40-60-40 MPH P&G
do you talk about the power steering?
MPG=1 TIME=0
Old 08-20-2012, 02:06 PM   #100 (permalink)
Yes
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
