Old 04-01-2010, 11:21 AM   #11 (permalink)
thanks, your right. the vehicle that everything is going into is a 96 with obd2
the parts vehicle is a 95 with obd1
both are 3 cyl manual models both with the same body styling also.
no wires were cut or anything and everything is labeled so install should go fairly easy. i just dont want to get the 95's motor in to find out it wont run right.
im wanting to swap motors because my 96's motor has 120k miles on it, and the 95 has 85k miles on motor and trans.
the 95's body was completely rusted through so i figured Id use the solid car.
along with turning the parts car into a metro truck last night lawl.
Old 04-01-2010, 12:48 PM   #12 (permalink)
sorry for being rude earlier, ive been looking all day, and not having any luck. basically i just need to know if i should pull the trans off the 95 and put it on the 96, or leave it on and finish installing it.. I just want to make sure i dont get the 95 motor in and find out it wont run off the 96 ecu.
but i cant find any walkthroughs or guides, all i saw was the sensors on the intake needed to be swapped, so i did all that.
Old 04-02-2010, 10:37 AM   #13 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The info you need is somewhere on TeamSwift.net, but basically I think you need to change the oil pump and pan to swap the crank sensor over to the '95 engine. What's wrong with the '96 engine? 120k miles is nothing. Just use it if compression is good.
Restore oil additive... suspectnumber961 The Unicorn Corral 46 11-20-2018 01:15 AM
efficient engine design user removed EcoModding Central 27 11-24-2014 02:02 AM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 02:22 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 03:05 AM
