Old 08-05-2008, 11:08 PM   #11 (permalink)
Modified Driver
Twerp's Avatar
Location: South Western middle of nowhereish New Hampshire
Frozen Tundra - '03 Toyota Tundra 4WD SR5 Access Cab
90 day: 26.51 mpg (US)
Red Skateboard - '91 Honda Civic DX
90 day: 45.49 mpg (US)
Originally Posted by Binger View Post
what about for those of us with automatic transmissions...when I shut off at a light I put it in neutral to restart.
If I mounted a kill switch to the shifter I could put it in neutral and kill the fuel while rolling...but will it restart once I let off the switch because it is an automatic?
Will that cause harm to the transmission puting it back in D while rolling at 25-30mph? or less?
I'd be careful about doing EOC with an auto trans. I've heard that there are many auto transmissions that can be damaged by running without power to the fluid pumps. I'm no expert on this one, but I know that running an automatic Tundra with the engine off is not recommended. At the very least, look in your owner's manual at the section on towing/dinghy towing. If it gives you any warnings about running the driving wheels in neutral with the engine off, you might consider giving up on EOC and pursue other methods of saving fuel.
Old 08-05-2008, 11:24 PM   #12 (permalink)
Civic - '98 Honda Civic DX
90 day: 41.44 mpg (US)
I will look into that...I actualy tried some EOC going to and from work...and it did fine...but its good to know that there could be an issue...so I will find out.
I actualy did a 4 block eoc right into my drive way
Old 08-05-2008, 11:41 PM   #13 (permalink)
90 day: 51.82 mpg (US)
PaleMelanesian - thanks for posting that link. I'd forgotten about it.
Old 08-06-2008, 02:56 AM   #14 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
modmonster -
I am pretty much in agreement with what everyone else has been posting. Here is how I describe a bump-start :
1 - Engine off, coasting at 25+ MPH.
2 - Push clutch all the way in.
3 - Move stick shift to 5th gear position.
4 - Let foot up on clutch just enough to engage engine and then push clutch back in. My non-car knowledge makes me think I am "tapping the flywheel" to turn over the engine. For me this is a pretty quick movement. If the tap goes well, the engine starts very smoothly, almost no bump in the bump-start.
5 - Let foot up on clutch and drive in 5th as normal.
I have experimented with lower gears, but the MPH "soft bump" range is very narrow, so I almost *never* do it.
CarloSW2
American Solar Energy Society
Old 08-06-2008, 11:18 AM   #15 (permalink)
I went to the mitsubishi dealership this morning and the mechanic I discused EOC with said there should be no issues doing this with my car.
I may give this a try for a bit.
When I was doing it last night I had no issues with my brakes or my steering. I'm not sure that it counts as a true P&G but omaha has alot of hills...and I can get my car rolling and shut it off in neutral and roll for a very long distance. I crested a hill at about 25 mph and had enough EOC momentum to cover a stretch of about 2 miles.
Old 08-06-2008, 05:13 PM   #16 (permalink)
The Hulk - '96 Ford Aspire Base
90 day: 51.64 mpg (US)
Black Hole - '06 Kia Rio LX
90 day: 39.16 mpg (US)
Send a message via AIM to steensn
I have no problem doing a soft bump in second aroun 15 mph. I don't know if it is just my car, but I always use second gear at around 15 mph with the double clutch technique.
I use it so that I can judge lights and coast to them in time to never fully stop along with stop signs. I can coast all the way to 15 mph just before the stop sign using my brakes at the end and never use my ignition to start. Seems pretty seemless and I get great results.
2006 Kia Rio
1996 Ford Aspire
Old 08-06-2008, 07:01 PM   #17 (permalink)
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
Interesting that they OK it. Most all Autos get their oil pumped from the spinning of the engine. With out the engine on, even in N the gears are rotating inside, but with no oil to lubricate. If you start having any weird transmission action, start the engine up and drive it easy and let the thing cool down some.
Autos are a PITA to have rebuilt.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 08-06-2008, 11:04 PM   #18 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Try 4rth or 5th gear and see if it works, I think it would be easier on the engine. I used to bump start in the gear that I would normally be driving in at the speed in question, but have found that moving up a gear or two to bump start works better.
Nissan Versa Aeromods
Old 08-06-2008, 11:29 PM   #19 (permalink)
I find the double-clutching method strange. I've EOC'd Fords and Metros both, and didn't need to double-clutch either. I just engage and disengage the clutch in the normal fashion. The whole operation is quite smooth. Is it just me???
Old 08-07-2008, 07:53 AM   #20 (permalink)
My car def does not like just engaging the clutch straight up. Even if I "get it right" it doesn't sound "happy." It sounds very smooth and much better doing a double clutch. I'm sure every car is different.
2006 Kia Rio
1996 Ford Aspire
NO Damage to auto transmission by EOC ScottC33 Hypermiling / EcoDriver's Ed 35 07-09-2009 02:42 AM
Best MPG with EOC & without EOC xbUser Hypermiling / EcoDriver's Ed 21 08-21-2008 11:25 PM
Metro EOC switch how to bbjsw10 EcoModding Central 10 07-18-2008 09:05 AM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
