Old 04-05-2013, 03:57 PM   #51 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
... Except for those from the pre-leaded gas era?
Old 04-05-2013, 08:48 PM   #52 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Beau View Post
With all due respect, it appears we've lost focus on this thread - which is about sulfur (not lead) reduction.
In the end, sulfur reduction is good news. Ten cents per gallon is a small price to pay for less environmental/health damage down the road.
Old 04-06-2013, 01:41 PM   #53 (permalink)
That would make most any engine from the pre-unleaded gas era "crap".
Well, I'd have to agree, though some were bigger piles of crap than others. Nostalgia is fine, but any honest & knowledgable person will have to admit that design & manufacturing standards weren't all that great back then. I grew up working on cars from the '60s, and what was accepted as normal for service intervals on everything from oil changes to valve jobs would probably lead to lawsuits today. Seriously, when was the last time you heard of a modern engine needing a valve job?
Old 04-06-2013, 03:19 PM   #54 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
My 4A-FE needs the valve clearance checked every 60k, along with the timing belt.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 04-06-2013, 05:56 PM   #55 (permalink)
I'll have to second that. I actually think sulfur should've been eliminated from the fuels a long time ago...
Old 04-07-2013, 10:54 PM   #56 (permalink)
Checking the clearance, and adjusting if necessary, is emphatically not the same thing as a valve job. That involves taking off the cylinder heads, removing valves & springs, and lapping or grinding each valve & seat so that they make good contact. Typically you'd also check valve guides for wear, replace the seals, etc.
