12-19-2016, 11:53 PM
#321 (permalink)
I am confused . 5 kw instead of 17.5 kw / 26 kw surge ? And 80% of 26 = 20.8 ? Not 17.5 kw ?
God bless
Wyr
12-20-2016, 12:39 AM
#322 (permalink)
Full sized hybrid.
Suzy - '13 Toyota Avalon Hybrid XLE 90 day: 37.18 mpg (US)
It's all in the math.
The Honda 7000 is a 7kW generator that can put out 5kW continuously.
12-20-2016, 07:10 PM
#324 (permalink)
I would be surprised if the "7kw Honda" could make 5kw sustained for an extended period of time.
12-20-2016, 07:14 PM
#325 (permalink)
God bless
Wyr
26kw is the useless factory surg rating. 17.5kw is the running watts.
#326 (permalink)
Full sized hybrid.
So you're saying that for $5,000 it's not worth it?
12-20-2016, 07:22 PM
#327 (permalink)
What the honda?
It's 5,000 dollars too?
If you are going to get a "7kw generator" with the intent of running it hard periodically to boost charge a electric vehicle there is absolutely no need for an inverter generator.
Now if you were going to completely charge the vehicle, run the A/C or heater and use the generator a lot below half capacity fairly often then the inverter may be a good choice.
12-20-2016, 07:31 PM
#328 (permalink)
Full sized hybrid.
So you don't think an inverter generator would be necessary? It seems the inverter generators get real expensive real quick, whereas other portable generators are much cheaper.
It's been below freezing for the past few days. In January I'd like to go to Montrose, about 65 miles from here. But I've got several changes in elevation and the cold to deal with. I might make it on one charge, but then again I might not. A backup portable generator would be great, but not if it costs an arm and a leg or fries the onboard charger.
#329 (permalink)
I would want to use something like my 922cc V-twin 30hp 26kw surge 17.5kw running.
How much for something like that? What would be the best way to supply 370v DC at 15kW. It might actually work to just connect to the battery terminals (with a fuse) with no further mods.
12-20-2016, 07:50 PM
#330 (permalink)
Full sized hybrid.
A fuse and possibly a diode.
