Old 12-04-2012, 01:41 PM   #21 (permalink)
Eco taco - '21 Toyota Tacoma Sr access cab
90 day: 22.72 mpg (US)
I meant if the plastic were to catch fire or fall off while driving and hit someone's car that's all properly done right the possibility of this happening is very slim
The Following User Says Thank You to johnathanf1lm For This Useful Post:
WesternStarSCR (12-04-2012)
Old 12-04-2012, 01:51 PM   #22 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
1. coroplast doesnt 'catch fire'.
2. PLEASE answer the questions. Have you done an underbelly pan? Have you read the threads?
or do you just say stupid things without thinking?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
The Following User Says Thank You to mcrews For This Useful Post:
govman6159 (12-04-2012)
Old 12-04-2012, 02:28 PM   #23 (permalink)
Alright, lets all calm down.
The truth really is as we've said. Plastic which the OEMs use isn't any different than the plastic you and I can get at a store. Its nothing special except it probably looks a little prettier. Just keep it away from the exhaust and you'll have absolutely no issues. Saying it is dangerous is simply not true.
That being said, ALL modifications have to be done with safety in mind. You shouldn't have anything flying off your car. If you don't know if it is going to stay attached you should redesign it to be sure, and then test it in a safe manner. I'm happy to say this is virtually a non-issue on this board and I can't even think of a time when I read some mod spontaneously failed in any bad way.
Old 12-04-2012, 02:48 PM   #24 (permalink)
mcrews's Avatar
Actually, on a TEST RUN on a deserted road by the ranch, I was testing to see how FEW mounting points I needed w/ a new/redesigned install on my front underbelly pan.
and yep, at about 40mph it popped out. But that was why I was testing it.
TO make sure it was mounted securely enouch to withstand the air force that blew thru the lower grille opening.
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-04-2012, 03:05 PM   #25 (permalink)
Sorry for turning this topic into a belly pan argument I'm actually planning on doing a front one only. Anyway back to topic. Anyone know where to get a scangauge for cheap.
Old 12-04-2012, 03:10 PM   #26 (permalink)
If you're on a budget and don't mind Chinese stuff the ultragauge does the job for a good amount less than the scangauge.
Old 12-04-2012, 04:03 PM   #27 (permalink)
Thanks I'll look into that. Now I'm actually surprised no one said torque converter lock up
Old 12-04-2012, 04:20 PM   #28 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
yea i would go with the ultragauge as well it is much cheaper than a scangauge and although assembled in china it was at least developed by an American company.
Torque converter - really dont need a mod as i can get my car to use its torque converter anywhere above 45mph and sometimes lower speeds. The better at hypermiling you get the easier it gets to enact it.
I only saw it in 1 other spot but Smooth wheel covers they costed about $5 total to make covers for all 4 wheels and i have seen the most mpg increase from them although i didnt test my tire pressure change as when i bought the car i immediately pumped em up
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 12-04-2012, 04:51 PM   #29 (permalink)
mcrews's Avatar
the wheel covers are iffy. need steel rims for a good fit, then gotta find a round item size that fits.
I was never willing to drill into my alloys.
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-04-2012, 05:04 PM   #30 (permalink)
The Dirty330 Modder
Gealii's Avatar
Same i would never drill into anything metal or fiberglass etc on my car. Zip ties come in handy
- Henry Ford
