Old 08-15-2021, 12:01 PM   #1 (permalink)
Eco Rodder
Front air dam vs underbody belly pan
On an old car, in my case a 1966 Chevelle, with a horrendously shaped underbody, is it better to use an air dam to try to keep the air out or try to fab a belly pan?
I already have an air dam I’ve made for the front so would it be worth it to remove it and smooth the underbody?
The Chevelle is a full framed car with dual exhaust the full length, two relatively huge mufflers, I live rear axle. It’s a mess. It would require a LOT of framing to support it and I’d still have to leave the exhaust area open.
This is more for mpg than downforce.
Opinions?
ID:	31146   Click image for larger version
Worlds highest MPG LFX V6 powered 1966 Chevelle
The Following User Says Thank You to 67-ls1 For This Useful Post:
aerohead (08-18-2021)
Old 08-15-2021, 12:53 PM   #2 (permalink)
Most people seem to use the air dam because it's less fabricobbling.
If you do a belly pan start at the front instead of the back (or so I hear).
IRONICK (08-16-2021)
Old 08-16-2021, 02:41 AM   #3 (permalink)
IRONICK's Avatar
'Front air dam' cannot even be compared to 'underbody belly pan'.
It is a percentage of what 'underbody belly pan' can do.
Old 08-16-2021, 03:45 AM   #4 (permalink)
Eco Rodder
So your vote is for a belly pan. Noted.
Old 08-16-2021, 01:11 PM   #5 (permalink)
ecomodder.com/forum/showthread.php/aerocivic-how-drop-your-cd-0-31-0-a-290.html
The Aerocivic has dual side skirts between the wheels.
Old 08-16-2021, 04:41 PM   #6 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I think the general consensus, arrived at in other threads on this very topic, was that a good front air dam could deliver about 70-80% of the results of a comprehensive belly pan at 10% of the cost and effort. If you already have a dam built the obviously start there. Establish some baseline results without the dam for comparison, then run some tanks with to see how it fares.
Add the side skirts a la Aerocivic and it likely gets even better.
The Following 2 Users Say Thank You to elhigh For This Useful Post:
67-ls1 (08-16-2021), freebeard (08-16-2021)
Old 08-17-2021, 09:55 AM   #7 (permalink)
Eco Rodder
Very interesting. 70-80% of the results is a pretty good return considering how much easier it is.
Old 08-17-2021, 02:06 PM   #8 (permalink)
That's why they're more popular. Bang for the buck.
Old 08-18-2021, 11:20 AM   #9 (permalink)
Chevelle
Opinions?
GM's two lowest drag cars had full belly pans and no front airdam. Cd 0.137 and Cd 0.14 ( if we ignore the Cd 0.089 Sunraycer ).
A 'guess' for the '66 would be around Cd 0.51.
Today's 'Chevelle' Malibu is around Cd 0.28.
A look under a modern Malibu would say a great deal about GM's strategy for drag reduction over the decades.
HOT ROD Magazine used a full aluminum belly pan on their Cd 0.20, 200-mph Project Red Hat Camaro ( originally around Cd 0.49 ).
There are no low-drag cars without full belly pans.
You're the only one who can make the call on, how much you're willing to invest, time and moneywise.
In one example of a early- 1980s Cd 0.30 car, a full pan with 'slow' diffuser netted a delta- Cd 0.070 drag reduction.
67-ls1 (08-20-2021)
Old 08-20-2021, 08:42 PM   #10 (permalink)
Eco Rodder
I agree with everything you say. But a belly pan on a old full frame car would be a huge undertaking. So I’ll have to live with the less efficient airdam for now.
aerohead (08-25-2021)
