10-15-2012, 01:53 PM
Hello from Sunny VA
Hey all, been lurking for about a week since I got my civic. I'm planning on putting on a lexan (top) grill block, coroplast (or something) bottom grill block and mooncaps, but waiting on $.
I'm also considering putting in some LED Daytime Running Lights, but I have to look into legality and what the current DRL setup is.
It's an '09 bought with 16k miles, so my wife won't let me do anything fun like a boattail or skirts.
First tank got me ~29 MPG (U.S.) with standard crazy driving, and I started hypermiling in the last 30% or so of my 2nd tank and managed 36.7 (404 miles!), which is a hair over my EPA HWY. My current commute is 70% secondary toll highway (55 mph with one booth) and 30% outer suburbia. Looking forward to what tank #3 gets me.
My reachable goal is 45MPG, which gets me under $100 and is also equal to the HCH's EPA Highway rating and better than double what my old Mountaineer gets (although that's before adjusting the nut behind the wheel).
I also have a stretch goal - 60MPG. Not a whole lot of reason here, just feels like a good number to aim for.
I'll make sure I get some "Before" pics up before I start putting the neckbolts on!
Thanks for all the info you guys have put up so far, I'll definitely be stealing some DIY ideas...
10-15-2012, 03:09 PM
Hi -
70% @ 55 mph and 30% outer suburbia sounds pretty ideal as far as MPG friendly territory goes (depending on traffic). I predict good results
As for those rear wheel skirts, show this to your wife and see what she thinks:
from: http://ecomodder.com/forum/showthrea...irts-3816.html
60 is going to be a stretch with an automatic, but it's good to stretch.
Welcome to the forum!
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
10-15-2012, 10:52 PM
Thanks metro! I'm sure if I had a couple hundred dollars worth of fiberglass and 70 or 80 hours to kill I could make some skirts like that, but I have kids instead
10-18-2012, 12:15 PM
cheap post towards images...
10-18-2012, 12:16 PM
another post...
10-18-2012, 12:17 PM
last one.
10-18-2012, 12:18 PM
Originally Posted by MetroMPG
Hi -
Ok so I've been thinking about this... And I think I could pull it off with fiberglass, cardboard, and a couple attempts. Since the fiberglass and resin come in fairly large quantity at Home Depot anyway, I might just give this a shot... I won't paint until I'm happy with the shape and effect, so one can of Honda touchup and a can of good high-impact clear-coat should do it. I'll probably need a can of black krylon for the mooncaps, but I haven't entirely decided on a paint scheme there.
I was playing in pixlr, and here's my ideal target car. Blue is lexan, red is cardboard/fiberglass, peach (mooncaps) is up in the air, but probably cardboard/fiberglass. I mostly did a different color there so you could tell it was a cover under the skirt in the rear.
I have some experience with plexiglass resin/sheet over cardboard, but I will definitely need to find some 4mm mylar for that smooth finish trick.
I have some concerns about the kamm - I'll need to be able to use the trunk. I might do a partial in cardboard with trunk clearance and try a tuft test.
edit: And I did show my wife those pics, and she okay'd them. Thanks metro!
10-18-2012, 12:29 PM
Testing signature...
10-18-2012, 12:43 PM
#9 (permalink)
So, what did you do with the body?
( KIDDING!)
There are other ways to do it that don't involve adding a hinge above the rear glass. More complex, but it's doable.
From: http://ecomodder.com/forum/showthrea...ods-20741.html
10-18-2012, 01:05 PM
#10 (permalink)
And it's ok being loose on the sides like that? Looks like it's just held on with hinges on top and the lynch pins on the trunk?
