Old 09-09-2019, 04:16 PM   #391 (permalink)
90 day: 39.72 mpg (US)
90 day: 59.69 mpg (US)
Originally Posted by mpg_numbers_guy View Post
Curious, have you ever tried P&G once to see what kind of mileage you get? 80% load 6th gear, then EOC, etc.
That's how I got my lone 65mpg tank - 5 hours of P&G.
Kill switch will be added soonish, just trying to finish house projects first.
Old 09-10-2019, 02:53 AM   #392 (permalink)
Re tuning:
Typically you'll find OEM spark timing to be close to optimal. They'll leave a little bit of margin for bad gas and hot weather and whatever. You can often take this margin out but the gains are pretty small, IMO. What I would personally do is either keep it stock, or use an off the shelf map + PCV catch can to give it more knock resistance.
(if the engine is radically modified then you want to redo the whole thing)
AFR at WOT is again set conservatively so the valves and cat don't cook on a hot day with bad gas. You can remove some safety margin without issues, or remove a lot of safety margin and accept reduced cat lifespan.
I believe all potential low-rpm fuel economy gain comes from EGR and VVT adjustments on 2000-2015 era engines. The oil-pressure actuated VVT is slow-responding, so the OEM doesn't use the full adjustment range to improve response. Hot EGR I believe is limited to reduce intake heat soak (generally speaking every paper I've read suggests 10-15% EGR dilution is a non-issue, but some cars only use a max of 4%, so leaving a lot of pumping losses on the table).
I was able to increase my Scion FR-S's mpg 1% by maxing out intake cam retard for as late valve closure as possible, then retarding the exhaust cam just a tiny bit to get some EGR back (IIRC any more than 5 degrees caused misfiring). Retarding the exhaust cam increases pumping losses though so again there's only so much that can be done without external EGR.
On your Honda K24, you only have intake side VTC available, so things are a little harder, since you increase volumetric efficiency when you try to get more EGR. Since the low cam has low duration to begin with, closing it later probably has only a small effect on VE reduction, so advancing it a tiny bit more is probably the best you can do.
Lean burn or adding external EGR would be your best bets IMO. You'd want to bump the ignition timing advance up a little when doing so. My gut feeling would be increase it by (lambda - 1)*(15 deg - current timing)/2 (pretending that combustion speed is linear in AFR, compensating by 1/2 since friction increases and knock and whatever, comes out to 3-4 degrees max at low load assuming 1.15 lambda).
The Following 3 Users Say Thank You to serialk11r For This Useful Post:
Daox (09-10-2019), Ecky (09-10-2019), redpoint5 (09-10-2019)
Old 09-10-2019, 06:22 AM   #393 (permalink)
Fantastic post, thank you. My only issue is that I don't have access to a stock Honda timing map. I'm basing it from a Hondata map which I've advanced maybe 2 degrees across the board at part throttle.
Yesterday I sat in a parking lot holding the pedal at a fixed position with some loads running (A/C, headlights, defroster) and tried varying timing live to see if revs rose or dropped, but I wasn't able to get any solid data before under hood temps got really out of control.
Old 09-10-2019, 11:36 AM   #394 (permalink)
Here are some of the supposedly stock timing I have to work with:
04-05 TSX (in KPro)
07 TSX (in Flashpro) - same engine, same low cam lobes
09 TSX - cams are very similar to 07, has a one-port header
12 Civic Si - physically identical to the 09 TSX
A few points of comparison between these nearly identical engines:
2000rpm / 300mbar
05 TSX: 45 degrees
07 TSX: 40 degrees
09 TSX: 48.6 degrees
12 CSi: 51 degrees
3000rpm / 200mbar
05 TSX: 50 degrees
07 TSX: 40 degrees
09 TSX: 60 degrees
12 CSi: 53 degrees
3500rpm / 1bar
05 TSX: 32 degrees
07 TSX: 30 degrees
09 TSX: 27 degrees
12 CSi: 27 degrees
1000rpm / 1bar
05 TSX: 8 degrees
07 TSX: 15 degrees
09 TSX: 11 degrees
12 CSi: 11 degrees
Again, supposedly "stock equivalent" maps. Physically these engines are all nearly identical, same geometry, with the 09+ engines moving from a 4 port header to an integrated header with one port, and having (I believe) very slightly less aggressive cams. At WOT the timing is similar, but lightly loaded these maps are massively different, 20 degrees difference in ignition timing in some cases.
California98Civic (09-15-2019)
Old 09-30-2019, 08:51 PM   #395 (permalink)
Answers coming Soon™.
The Following 3 Users Say Thank You to Ecky For This Useful Post:
Gasoline Fumes (10-01-2019), MetroMPG (10-01-2019), mpg_numbers_guy (10-01-2019)
Old 09-30-2019, 08:54 PM   #396 (permalink)
Also had one of my headlights get smashed when a friend backed into my car, and as compensation he offered to buy a a pair of new ones. I'm thinking of going back to LED (for now) to cut down on complexity and weight. The projectors are really nice, but if I don't have to crack open the new headlamp housings, I won't. Shame I'll lose the black highlights though.
ID:	26915   Click image for larger version
Old 09-30-2019, 09:39 PM   #397 (permalink)
90 day: 29.78 mpg (US)
I had a neighbor back into my car with his truck and smash out my taillight. As compensation he offered his story about how normally my car isn't there when he backs up. Don't understand how people can trade integrity for trivial sums of money or effort.
Anyhow, looking forward to a top gear that stays in place and blows away the previous best tanks.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Daschicken (10-01-2019), Ecky (10-01-2019)
Old 10-01-2019, 08:49 AM   #398 (permalink)
90 day: 51.82 mpg (US)
^ It is because of neighbours like that that we have mandated back-up cameras.
It probably would have saved you a tail light.
Ecky: a top gear that stays in gear on its own? Coming soon??
Old 10-01-2019, 09:22 AM   #399 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
It sucks about your headlight getting broken, hopefully they can fix your trans though.
My current Ecotec project...
My last Ecotec project...
Old 10-01-2019, 06:05 PM   #400 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
At least he stuck around and paid for the damage!
Any specific LEDs you're looking at? Be sure to check up on beam pattern, etc.
Looking forward to the results on the trans!
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
