09-08-2014, 07:58 PM
#71 (permalink)
Cyborg ECU
Originally Posted by Xist
I don't recall why I did not include them, but I would guess it was because that was really the sport trim, with the shortest gearing. We rarely see them on this site, and usually EM people want to avoid the shortest gearing vehicles. That's all.
09-08-2014, 08:12 PM
#72 (permalink)
ALL UP ON THE INTERWEB!!!
One more for California98Civic!
(I finally got the EOC kill switch installed- followed your how to from an old thread)
THANKS!
09-08-2014, 10:09 PM
#73 (permalink)
Furry Furfag
Oh wow, the insight has taller gears then my civic did?!?! It sure doesn't feel like it, even without assist. It feels like 3.73 and that's what I thought it had...
09-09-2014, 09:04 AM
#74 (permalink)
Hypermiler
The 99-00 Si runs a B16 engine from the Integra, not a Civic D series. I don't believe the parts are interchangeable. And the gear ratios are dumb.
10-19-2015, 04:35 AM
#75 (permalink)
California98Civic, great work! Is there a reason that you did not include the Civic Si? The 98-00 had a 4.266 final drive, according to Wikipedia, which strangely omits that detail for the HX.
It's a typo. 94-01 B18B uses 4.266 final. EM1 (99-00 Civic Si with B16A2) has final drive of 4.4.
What are y'all trying to figure out here?
10-19-2015, 10:33 AM
#76 (permalink)
Cyborg ECU
Originally Posted by Bense
... What are y'all trying to figure out here?
The goal is simply reliable data on the transmissions of a variety of the fuel sipper Hondas. It could serve several purposes, such as transmission swap planning, identifying whether a specific transmission has the gearing advertised, understanding speedo/odo variations, which transmissions might bolt-up easily and which would need mods, and probably more... it's a record. Some of the info is available elsewhere online in pieces. Other info was not online when I made this. I also sought to confirm as many of the sources as possible in reputable places (so that as few errors as possible creep in, like the wikipedia typo you just mentioned).
As much as possible, I got the data from Honda or confirmed it with Honda. I searched widely for Honda FSMs and found a bunch.
I'm always open to corrections.
03-29-2016, 09:45 PM
#77 (permalink)
home of the odd vehicles
Stupid question.
What type of size/spline count does the original honda insight 5mt transmission have?
20 splines ? What diameter?
Ditto the daihatsu charade.
I am thinking very strongly of dropping the transmission into my fathers miles zx40, dimensions are SCARILY similar in a few odd places but I have no desire to pull it all apart to test the halfshafts and input.
I wonder though if the transmission would survive tilted up a bit, too many things line up per eyeball guage in weird ways.
My thought is the daihatsu charade is a 18 spline and smaller (or maybe I am wrong), so the electric motor might be possible to love joy in there with a simple adapter to fit the smaller spline into the larger one, or maybe I am nuts.
Anyone have any ideas where to find exact specs of the Daihatsu and the Insight?
A couple adapters to make my fathers car shiftable with a deralect XMSN I will never use would be terrific.
Thanx
Ryan
04-14-2016, 04:27 PM
#78 (permalink)
But you're not going to cover any ground that either myself or Bone haven't already covered, discussed, debated, or entertained.
I'm all for progression. But the emphasis here is efficiency. There's nothing more inefficient than going to great lengths to discover what is already known.
So again, I ask, what exactly are y'all trying to figure out here?
04-14-2016, 04:35 PM
#79 (permalink)
Originally Posted by rmay635703
Stupid question.
Thanx
Ryan
Aside from the obvious method of physically inspecting the parts while they're in front of you, the database that you'd want to start with is a company that specializes in manufacturing clutch discs.
Aside from that, the inner diameter of the input shaft bearing has to be larger than the outer (major) diameter of the mainshafts' spline.
If you're measuring the ID of a church disc as 24mm, and if the ID of the input shaft bearing (ISB) is 22mm, then it ain't gon' work.
04-14-2016, 05:42 PM
#80 (permalink)
Cyborg ECU
...So again, I ask, what exactly are y'all trying to figure out here?
That question has already been answered and I have nothing to add to my former answer.
