Old 10-16-2013, 04:09 PM   #1 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
How to - Almost OEM Upper Grill Block for 2013 Subaru Sti
I want the upper grill block to look as OEM as possible and also to be removeable. This took me about 21 days to build (it took this long only because i can only work on it for about 2 hours a day).
Not to brag or anything, but i think it looks darn good!
Let me know what you think!
The basic method...i made a "copy" of the grill with fiberglass, then filled the void with greatstuff foam, then sanded and shaped with bondo.
grrr
FINISHED!
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following 6 Users Say Thank You to jedi_sol For This Useful Post:
Jyden (12-03-2013), NachtRitter (10-17-2013), Occasionally6 (10-16-2013), Phantom (10-29-2013), Sheepdog (10-17-2013), t vago (10-16-2013)
Old 10-16-2013, 05:52 PM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Nice work!
The Following User Says Thank You to nemo For This Useful Post:
jedi_sol (10-16-2013)
Old 10-16-2013, 06:35 PM   #3 (permalink)
...beats walking...
...yes, very nice work!
The Following User Says Thank You to gone-ot For This Useful Post:
Old 10-16-2013, 06:53 PM   #4 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Looks great! Going to have to figure out how to block mine out pretty soon while still staying incognito!
The Following User Says Thank You to brucey For This Useful Post:
Old 10-16-2013, 07:23 PM   #5 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
I'd say 21 days is well worth the wait. It looks like you put a lot of effort into this.
Just want to ask about airflow. Under the hood and above the new grill block is a small slit. Does that allow airflow through the radiator, or that blocked further back? Does the scoop allow airflow into the top of the engine compartment? On my 4Runner, the scoop is blocked inside, which doesn't allow airflow (for anything, let alone cooling). What about underneath the air dam? Does the radiator go down far enough to allow the air that does end up under the car to run through it? Do you have a belly pan to stop that flow?
I'm just wondering if there is any airflow anywhere in the system.
Very nice work!
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 10-16-2013, 07:27 PM   #6 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
it looks like the upper grill on the crosstrek is removeable. Therefore, you can take it off to spend more time with it to make it look nicer:
http://quirk-images.com/ebay01/subar...00U9-a.jpg.jpg
here are my instructions on how i removed my upper grill (without having to remove the front bumper). the procedure might be similar for your car.
http://ecomodder.com/forum/389371-post64.html
Old 10-16-2013, 07:32 PM   #7 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Very nice work!
Yes, i am running into airflow issues as the engine temps are now hovering around 195-205F...typically engine temps are 188F.
Yes the sti has FUNCTIONAL hood scoop that feeds the top mounted intercooler . The "slit" on the top doesnt lead to anywhere, its blocked from behind. I am thinking of making a small plug for that area too to increase laminar flow. Yes, there is a front FLAT belly pan from Subaru for smoother airflow down there.
However, the issue seems to stem from my larger lower grill block. Back when i was doing my "early" versions of upper and lower grill block, 100% upper grill and 80% lower grill did not effect engine temps at all. Therefore, i am going to trim my lower grill block some more to increase air flow to the radiator.
The Following User Says Thank You to jedi_sol For This Useful Post:
j12piprius (03-20-2014)
Old 10-17-2013, 11:22 AM   #8 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
This looks very nice. I appreciate the effort you put into this.
Could put an STi sticker on it, and no one would know it wasn't stock.
- Greg
Old 10-17-2013, 12:01 PM   #9 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Yes, it's on my list of things to do
Old 10-17-2013, 02:07 PM   #10 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
looks nice to me.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
