Old 09-11-2018, 02:48 PM   #101 (permalink)
90 day: 57.12 mpg (US)
I've seen tugs that lift the nose wheels of the plane and therefore need no ballast.
Old 09-11-2018, 04:36 PM   #102 (permalink)
Back on topic — A Ghia that looks like a tug?
https://forums.pelicanparts.com/off-...l#post10131176
Old 09-11-2018, 07:35 PM   #103 (permalink)
Hoopie
Hoopie's Avatar
Started chopping the Ghia today.
The Following 3 Users Say Thank You to Hoopie For This Useful Post:
HHOTDI (09-13-2018), MetroMPG (09-19-2018), Xist (11-13-2018)
Old 09-11-2018, 07:36 PM   #104 (permalink)
Hoopie
Hoopie's Avatar
freebeard (09-11-2018), MetroMPG (09-19-2018), Xist (11-13-2018)
Old 09-11-2018, 08:18 PM   #105 (permalink)
Yikes! No turning back now.
Old 09-12-2018, 05:34 PM   #106 (permalink)
Just duct-tape it back on!
Wasn't the APC from "Aliens" the one that would function terribly as an APC? What kind of obstacles could it climb?
I hope that the tugs that support the front wheels of a plane have a Freak out the New Guy button that makes constant cracking noises until you turn it off.
Hey! Hoopie! Keep up the great work!
Old 09-12-2018, 09:37 PM   #107 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by elhigh View Post
IIRC wasn't the APC in "Aliens" an airport tug? And they had to remove thousands and thousands of pounds of ballast and still was pretty damned heavy.
An A380 is 570 tons - 1,250,000 lbs
300-400 ton airplanes are quite normal
They're not going to start moving if the tug has no substance
Old 09-12-2018, 09:40 PM   #108 (permalink)
euromodder's Avatar
Ouch ... kinda hurts
But keep up the good work !
Impressive
Old 09-12-2018, 10:46 PM   #109 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
You, sir, are a "doer"
Old 09-13-2018, 09:26 AM   #110 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Holy cats. Well, if you weren't committed before you sure are now!
I totally dig these repowering-with-hybrids threads. I think they're a truly cool way to keep classic style on the road while delivering good mileage and pollution control.
The Following 2 Users Say Thank You to elhigh For This Useful Post:
