09-13-2018, 11:55 AM
#111 (permalink)
Ok I will admit I'm dumb here. Why are you cutting up the ghia?
09-13-2018, 11:11 PM
#112 (permalink)
He’s cutting up the Ghia to put the body shell, minus the frame and floorpan, onto the Prius we seen the body removed from earlier
My current Ecotec project...
My last Ecotec project...
09-14-2018, 01:38 AM
#113 (permalink)
Those cuts are minimal to make two pieces. Why I don't know. Easier to move around?
Standard stuff if you're chopping a top or replacing rusty rocker panels.
I'm standing by to see if the doors are hung on the Ghia or Prius cowl.
.tragectory: Line goes down and to the right.
09-14-2018, 04:16 PM
#114 (permalink)
Hopefully the prius cowl because it should be stiffer. Sitting on a ghia open door is enough to warp it bad enough it wont close.
Done rocker panels, haven't done chop top, did a ragtop conversion. Didn't piece the body.
09-17-2018, 04:50 PM
#115 (permalink)
Hoopie
First attempt
I need to adjust the core support location a bit. Getting closer though.
The Following 6 Users Say Thank You to Hoopie For This Useful Post:
09-17-2018, 07:08 PM
#116 (permalink)
Is that the top of suspension travel or ride height? Ghias look best when they're stanced.
Don't be afraid to add wheel-arch flares.
09-17-2018, 07:36 PM
#117 (permalink)
Nice! I just hope you find a way to get more air to the radiator. Check the nose of a '49 Studebaker for ideas.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
09-18-2018, 12:11 AM
#118 (permalink)
My gen III Prius hardly needs any air. I can run a full grill block most of the year if I'm not driving up a grade. Not sure what the actual airflow requirements will be, but if it's not sufficient flow, perhaps ducting the existing vents would suffice.
09-18-2018, 12:34 AM
#119 (permalink)
The bullet nose was 1950-51. The shark mouths are big compared to the Ghia. If more air flow were needed, I'd go with two more Ghia grilles turned upside down below the originals.
09-19-2018, 09:30 AM
#120 (permalink)
Originally Posted by elhigh
I totally dig these repowering-with-hybrids threads. I think they're a truly cool way to keep classic style on the road while delivering good mileage and pollution control.
Yup!
Crazy Torchinsky on Jalopnik has written a couple of articles espousing the same thing.
I forwarded him the 1946 Prius Chevy pickup build thread, but he didn't bite.
