Old 12-23-2008, 02:54 AM   #11 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Christ View Post
1. Why won't a vacuum gauge work for you? Even if you're boosted, you're still in vacuum before the turbo spools, so the idea would be to keep out of boost as much as possible.
Diesels don't have a throttle and hence don't have a vacuum. Any thing that requires a vacuum is driven off of a vacuum pump.
Unlike a gas engine, diesels do not require a fixed fuel mixture to run right. In fact they run better the leaner the combustion gasses. Boost actually raises the efficiency of a diesel engine and will do so up until the point air starts to liquify. There is a break even point however where it takes more energy to create the boost than is recovered by the efficiency increase and thus boost beyond this point reduces net efficiency.
Generally however, if you drive so that your engine is generating the least amount of boost it is an indication that your pistons are extracting the most energy they can. This does not mean that you should modify your engine to reduce boost or try and prevent your intercooler from reducing intake manifold temps in any way.
Old 12-23-2008, 03:00 AM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I really should stop posting so early in the morning... or get some sleep at some point.. - I already knew this. Thanks though LOL.
Old 01-01-2009, 04:40 PM   #13 (permalink)
Impala - '04 Chevrolet Impala base
90 day: 32.84 mpg (US)
My old Fury had a vacuum gauge. Interesting that most vehicles today dont have a vacuum gauge. Someday the Impala will hopefully benefit from Scangauge.
Old 01-03-2009, 09:28 AM   #14 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Originally Posted by EXPIOWA View Post
*Cough*MPGuino*Cough*Same price*Cough*
*cough*carbureted*cough*hack*gasp
Old 01-05-2009, 01:07 PM   #15 (permalink)
<chuckles> Yes, the old Fury was carburated, a classic old 2 barrel that did a good job in fuel economy considering the size of the vehicle moved, the weight (old classic IRON) and a 3 speed, non overdrive transmission.
Old 01-16-2009, 09:10 AM   #16 (permalink)
cottonfox's Avatar
April - '09 Chevy Aveo5 LS
90 day: 43 mpg (US)
a lurking comment...
Originally Posted by Clev View Post
It measures the vacuum at the intake manifold. As engine power increases, the engine generates less vacuum. The upshot is that a vacuum gauge can show you approximately how much the engine is putting out.
Sorry for the insultingly new question, but what is the advantage of this over the tach, which shows how hard the engine is working in RPM's?
Old 01-16-2009, 10:11 AM   #17 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
The vac gauge shows how much the accelerator is pressed and therefore how much fuel is going into the engine.
ollie
Old 01-28-2009, 11:44 AM   #18 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
I'd see between 0 and 3 inches on the gauge. By adjusting my speed and throttle a little bit, I'm able to climb at about 6 inches at nearly the same speed.
I thought lower was better, no?
Old 01-28-2009, 10:30 PM   #19 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Nope. Higher vacuum is better (at least for a given gear. Lower vacuum can be acceptable in a higher gear for the same speed.)
Old 01-28-2009, 10:33 PM   #20 (permalink)
I thought lower was better as well... since opening the throttle more increases VE by lessening restriction via the throttle plate, which reduces vacuum... I was under the impression that regardless of gear or engine speed, less vacuum would create better efficiency.
Econometer/Vacuum Gauge Installation Guide Johnny Mullet Instrumentation 80 02-18-2015 12:58 PM
10-minute Accord vacuum gauge "install" Clev DIY / How-to 7 09-10-2010 03:53 AM
Used Vacuum Gauge for hypermiling holypaulie For Sale 5 11-26-2008 12:29 PM
no vacuum for vacuum gauge? modmonster Instrumentation 2 11-07-2008 07:40 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
