Old 07-28-2017, 05:20 PM   #111 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
I await rusty pics.
I await repair and result pics....maybe it will reassure me that I can do the same!
The Following User Says Thank You to Stubby79 For This Useful Post:
Daox (07-28-2017)
Old 08-02-2017, 01:38 PM   #112 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Mmmm... choco delish!
The passenger side, cut back to clean metal. Just one hole, and not too bad:
Choco delish patch template!
ID:	22297   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
Daox (08-07-2017), roflwaffle (08-07-2017)
Old 08-02-2017, 01:42 PM   #113 (permalink)
Flintstones! Meet the Flintstones!
The driver's side was unsurprisingly worse than it looked at first glance.
Here it is, sawzall-cut back to good metal.
FORTUNATELY! The edges of the cut are where the metal is thicker/structural and so slower to rust away. So there's a good "border" to weld to, almost all the way around.
That section running down the middle of the footwell is an underbody "frame rail" - a box channel stiffening element, also made of thicker metal. It needs a bit of first aid.
Based on what I'm seeing, I bet someone probably sells pre-fab floor patch panels for this car. Of course, I'm just going to cut & paste scraps of sheetmetal I have laying around.
Daox (08-02-2017)
Old 08-07-2017, 09:41 AM   #114 (permalink)
Rust repair progress
I made some progress this weekend!
I borrowed some steel boat stands to get the car up nice and high to work underneath:
Of course, the more I worked, the more bad metal I found. (The latest is a hole behind the plastic fender liner.)
But the floor itself is now mostly done, aside from cleaning it up, sealing, painting & undercoating.
I'm not going to win any welding awards. But it'll do the job.
ID:	22321   Click image for larger version
ID:	22322   Click image for larger version
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
eco_generator (08-08-2017), roflwaffle (08-07-2017), samwichse (08-16-2017), Stubby79 (08-07-2017)
Old 08-07-2017, 11:24 AM   #115 (permalink)
broke my fist bolt...
... and my 2nd, 3rd and 4th!
Up to today, I've been pleasantly surprised at how easily the nuts & bolts on a 27 year old car could yield to a wrench and a bit of penetrating oil. (Thanks to not being winter driven.)
But this fender did not want to come off easily!
Unfortunately, I found more future welding work hidden beneath it...
ID:	22349   Click image for larger version
wdb (08-08-2017)
Old 08-07-2017, 02:42 PM   #116 (permalink)
Reminds me a lot of the work I did on my Metro.
Old 08-08-2017, 07:57 AM   #117 (permalink)
Wow. You are next level masochist.
I was getting frustrated working on my car after breaking the suspension tower studs and discovering my sway bar bushings had crumbled away after spending several days redoing a bunch of wiring, and here you are with a car that makes mine look new patching all that rust like it's nothing...
Old 08-14-2017, 03:20 PM   #118 (permalink)
2 weeks later...
Rust repair is nearly done.
I have 2 small patches to finish this evening, then it's time to clean & seal the seams, paint (inside) and undercoat (bottom).
But with much messier welding!
Supposedly the masochist enjoys the pain. That definitely doesn't apply to me -- I'm sick & tired of working under this car and happy it's nearly over!
It occurred to me early on in this process that even at $700, I definitely overpaid for this car.
Part of this is my own fault: I work so slowly. I bet this is a weekend's work to someone with more experience. (And a work ethic!)
Old 08-15-2017, 12:57 PM   #119 (permalink)
Welding is done! Seam sealing done! Undercoating done!
Pics to come.
Old 08-15-2017, 05:24 PM   #120 (permalink)
Endless money pit - '07 Toyota Yaris
90 day: 43.61 mpg (US)
Cool!!
I wouldn't even dare to start a project like this
What kind of sheet metal did you use?
