Old 09-12-2017, 10:30 AM   #151 (permalink)
90 day: 51.82 mpg (US)
3rd fill: 45 MPG
45.1 MPG US = 5.2 L/100 km
From just under the 1/2 mark, clicked off until I could see fuel in the neck, like last time.
More mods!
Previously done: 50 PSI; AC/PS belt delete; partial grille block; passenger mirror delete; front license plate relocated.
More mods added during the last tank: MPGuino; full front air dam; LRR Dunlop Enasaves on front wheels; driver's side mirror delete; synth 5w30 oil change.
Coming soon: timing advance; wheel discs; test rolling resistance of Enasaves vs. the tires it came with before changing the rears.
I swear I'm going to start a mods thread.
Driving style: same as last tank. Weather got cooler though.
MPGuino fail: I couldn't calibrate the MPGuino -- it keeps randomly freezing/resetting and losing the tank data. It's still extremely useful to have onboard for trip-by-trip numbers though.
And based on trip numbers vs. this tank result, it's dialled in reasonably closely.
THANKS, AntiochOG for sending me your Miata MPGuino settings.
Daox (09-12-2017)
Old 09-12-2017, 12:27 PM   #152 (permalink)
...beats walking...
Maybe you could log MPG vs. TEMP data throughout the year to see what "curve" you get?
Old 09-12-2017, 03:50 PM   #153 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Can you adjust the timing? There's no distributor to rotate...
Old 09-12-2017, 04:16 PM   #154 (permalink)
Yes! The Camshaft Angle Sensor angle controls timing.
See: https://www.miata.net/garage/ignition.html#timing
Old 09-13-2017, 09:34 AM   #155 (permalink)
re-gearing
Last night: so I couldn't for the life of me locate the timing mark on my crank pulley -- it's a TINY engraving, and the accompanying paint mark disappeared long ago.
So instead I changed my gearing...
That's a 15 inch Civic rim that my neighbour had laying around. Tire size is 185/65R15, the same width but larger diameter than the factory 185/60R14 tires. I've got them on the rear axle only.
RPM difference @ 80 km/h (50 mph):
  • OEM: 2587 RPM
  • NEW: 2404 RPM
Difference in rolling resistance? Unknown!
Difference in aero drag? Unknown! (It raised the rear of the car by about 3/4 inch).
Difference in rotational weight? Unknown!
Back to timing... I did end up finding the wee timing mark this morning using the "find TDC with a screwdriver through the spark plug hole resting on top of the #1 piston" method. So I'll get to advancing the timing soon enough.
wdb (09-13-2017)
Old 09-15-2017, 01:43 PM   #156 (permalink)
aero-hiding the re-gearing
Difference in aero drag? Still unknown... but improved!
Re-used the 15 inch wheel discs I saved from my 2007 Honda Civic former winter beater, and which also spent some time on my 2004 Prius winter beater.
I need to make up a pair to cover the factory 14 inch wheels on the front.
I swear I'm going to start a mods thread some time.
If the fuel gauge and the odometer can be trusted, the car is on its best tank yet: 46+ ?? More mods than last tank, plus the weather turned warm again. We'll know soon.
kurzer (09-15-2017)
Old 09-15-2017, 09:56 PM   #157 (permalink)
Stubby79's Avatar
You're crazy.
In a good way.
Old 09-16-2017, 10:06 AM   #158 (permalink)
Endless money pit - '07 Toyota Yaris
90 day: 42.07 mpg (US)
Red - '08 Honda Cbf600
90 day: 50.76 mpg (US)
Rwd and ecomoding..my ideal automotive lust..
I had a great time with my lightweight BMW,having a blast on the twisty roads and ecodriving everywhere else.
Averaging 36 mpg and a pair of rear tyres every 6 months...
Enjoy it!
The Following User Says Thank You to jimhs For This Useful Post:
MetroMPG (09-16-2017)
Old 09-16-2017, 10:30 AM   #159 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I would love to see what you could do with a 3.63 rear end.
5-speed with your current gear (I'm assuming a 4.3) = 2404 at 50.
5-speed with 3.63 = 2000 at 50.
Of course the cost would never outweigh the gains. It's 1200 for an assembled 3.63.
Old 09-16-2017, 01:12 PM   #160 (permalink)
$1200! That's more than I have in the car. I do know a guy with the next-gen Miata from mine, and he autocrosses it. His has a slightly taller rear end, so I suggested we swap. But his is a LSD and he didn't think mine was. So, no go. Sad.
I'm definitely enjoying driving without brakes MUCH more than in my Firefly.
