Old 12-10-2020, 11:04 AM   #61 (permalink)
Steel cities gray: corvette color in 1972, light charcoal but has a greenish flip-flop with largish flakes in red yellow blue orange green silver and gold. Car appears to change color based on ambient background
It does appear stubby's car is repainted.
freebeard (12-10-2020)
Old 12-10-2020, 12:36 PM   #62 (permalink)
That's probably it. More likely the Buick was repainted with a Chevrolet color than a Norton color.
Examples under different lighting: www.corvsport.com/steel-cities-gray-1972-chevrolet-corvette/
Old 12-10-2020, 01:03 PM   #63 (permalink)
I am looking at a 2000 Insight.It is grey with the CVT trans.It has 182k on it.It has a new CVT,a new radiator,a new battery pack.It belongs to a friend of my wife.She is the original owner.I am pretty Shute she has done good maintenance on it over the years.I am guessing that the replacement cost for major parts,CVT,hybrid battery,radiator was fairly costly. She is asking $5,000 for the car.Is this a reasonable price? The car is up in Ohio,I live in Florida and would have the car shipped.I called one shipper who wants$835.00 or $799.00 paid with cashiers check to ship from Cleveland Oh.to where I live in Gainesville Fl.This cost include s shipping ins.I have never had a car shipped before.Does this price seem reasonable or should I shop around? ThankYou ahead of time for any help with this.
Old 12-10-2020, 01:35 PM   #64 (permalink)
Are you okay with a maintenance risk of $3000 on it in the first 3 years?
20 year old hybrids are bought by tinkerers, collectors and enthusiasts, who don't care about the money involved because they're fixing it themselves, creating workarounds or are independently wealthy and don't care about the money.
If you're considering it for the economics and don't meet one of the criteria above, it's almost certainly a financial mistake.
The Following User Says Thank You to S Keith For This Useful Post:
Stubby79 (12-10-2020)
Old 12-11-2020, 01:43 AM   #65 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
No CVT in 2000. It has to be a 2001 or newer.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 12-22-2020, 03:47 PM   #66 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
LED Headlights showed up a few days ago...so was time to put them in!
Starting current with just the lights turned on:
Stuff it in and test they work and the beam pattern isn't messed up:
Low Beam:
Now to get the rubber seals back on. Thankfully, the bases come off the LED headlights:
Wouldn't just go back together as is. Had to trim the extra rubber off the seal. Still wouldn't go, until I pushed the seal all the way down so it wouldn't get pinched:
First one went back together just fine. Second one? Wouldn't turn very fat before the rubber ground it to a halt. Had to get some pliers on it to get enough torque to turn it in that tight space. (Wasn't that much force, just couldn't do it by hand at such an awkward angle)
Current after LED headlights were in:
This looked awful:
Not what I was expecting to find:
(Not a fan of "warm" white LEDs...whats the point?)
Mine:
After:
Much better!!!
Can't stop now!!! MOAR!!
Remember me blowing the tail light fuse testing the LEDs I had on hand? Here's how to stop wasting fuses, using connectors made from a dead fuse:
Look, Ma! It works:
Shaddap son, it wasn't that smart.
Testing. Gotta figure out how it works, stop guessing!
Tail lights:
Brake lights:
No annoying voodo floating ground witchery to make this difficult. (Thank you, Honda!)
Called it quits for the first day there. Got distracted saving this guy from getting stepped on:
It was pissing down rain, barely above freezing, he was too cold and wet to do anything but sit on the sidewalk along side my building, under my balcony, waiting to become lunch for some neighborhood cat. Didn't even try to fly away when I scooped him up.
Wonder if it the same dumbass one I put back in it's nest a couple of years ago...
Back to it...
Bench testing:
Top row is positive. Brake, brake, tail lights. (wth?)
Bottom is all ground.
Of course my LEDs go +/+/-/-...though at least they're bipolar. Of course, ya gotta find which lead goes to the "low" and which to the "high", and connect those to the +'s in the right order in the socket. Sigh. Test the current draw of each lead to do that...
Rather rearrange the wires on the bulb than in the socket. So this is what I ended up with:
Both positives flipped over to the same side, one lead extend over - with heat shrink to stop it shorting against the ground leads - to where it needs to be. Both ground lead flipped to the same side. A dab of hot glue to stop them wandering during installation.
Tested in-car, then installed "permanently". Results:
Tail lights:
(backfeeding the high brake LEDs. It's pretty dull, so OH WELL.)
Brake lights:
Final current readings:
Tail and headlights:
Tail/brake lights & headlights:
8 amps saved. ~100 watts. I'll take it.
Have indicator bulbs, checked while I was in there, but...
Too tall.
Can't cut them down without wrecking them, either:
Pulled the flasher to make sure it can be modified for LEDs:
Yup, there's the shunt. Good enough for now...gotta decide if it's worth the bother, considering how impossible it is to get at the front ones. And finding smaller, but still bright enough bulbs at a reasonable price? Apparently not. Whatever. Problem for another time.
Dunno why I took this photo...current with the LEDs in, car "on" but not running. HVAC fan on low and whatever other draws are going on. Future reference, I guess?
The rotten cherry on top:
El-cheapo-grande seat covers! (just exhausted my Spanish vocabulary on that one!)
Decent, everywhere but the head rests. Much too wide there. Stuffed the headrest covers on it that came with it. (but no seat covers? WHY?)
...with the hope that they'll squeeze it in to taking a better shape more permanently. If not, nip and tuck...
Bah, whatever.
Well, we shaved off 100 or so watts after all that. Was it worth the effort? EHHHH....for that alone? Not really. For the enjoyment of overcoming each obstacle? Sure. For having bright white headlights? That's definitely worth making the effort, IMO.
(I'll give feedback on how much light the headlights put out after I drive it tonight)
ID:	29808   Click image for larger version
ID:	29809   Click image for larger version
ID:	29810   Click image for larger version
ID:	29811   Click image for larger version
ID:	29813   Click image for larger version
ID:	29814   Click image for larger version
ID:	29815   Click image for larger version
ID:	29816   Click image for larger version
ID:	29818   Click image for larger version
ID:	29819   Click image for larger version
ID:	29820   Click image for larger version
ID:	29821   Click image for larger version
ID:	29823   Click image for larger version
ID:	29824   Click image for larger version
ID:	29825   Click image for larger version
ID:	29826   Click image for larger version
ID:	29828   Click image for larger version
ID:	29829   Click image for larger version
ID:	29830   Click image for larger version
ID:	29831   Click image for larger version
ID:	29833   Click image for larger version
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
Ecky (12-23-2020), samwichse (12-22-2020)
Old 12-22-2020, 04:42 PM   #67 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
That lower draw will really help keep the engine off while sitting at lights in the rain.
Old 12-23-2020, 03:14 AM   #68 (permalink)
Stubby79's Avatar
Some Rain-X will help on that account as well!
The Following User Says Thank You to Stubby79 For This Useful Post:
samwichse (12-23-2020)
Old 01-11-2021, 02:04 PM   #69 (permalink)
Stubby79's Avatar
Wipers stopped dead in the middle of the windshield about a week ago. Moved them back by hand...something obviously let go. Think the "too-long" driver's wiper slapping against the windshield frame probably didn't help any.
Was half expecting the other end of the linkage that comes off the motor to have popped off...it was the sloppiest of the two ends when I put the new bushing on. Nope. Was the new bushing end that popped off. Wasn't my modifications to make it fit the linkage that gave, either. Just popped off the motor's ball. It's back on now.
22" wiper was still slapping against the windshield frame, despite being adjusted as far down as it could go. So I borrowed a 20 from another car of mine. Nope. Settled for a new 19" i had on the shelf. Better, but still making some contact.
Only does it when the system voltage is at normal running voltage (14.2v), or on high. The momentum is what's carrying it, and presumably there's enough slop in the linkage that it doesn't hold it back from doing so at the end of the sweep. If it happen again (more like WHEN), I'll have to look at the other bushings and see if they can be replaced. Can't be bothered to go back in until then.
Before all that, though, I thoroughly cleaned the glass - inside and out - and then applied rain-X. Won't be much of an issue if it goes again. Won't be running the wipers half as much, so might take a while before it does.
Since I'm not tinkering much on her at the moment, and the pillars are thoroughly sealed up, I might as well park her on the street to encourage me to drive her more often.
Old 01-12-2021, 10:14 AM   #70 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I replaced all of the bushings in mine and got rid of that slop. That's definitely what's going on.
