09-12-2013, 06:17 PM
#751 (permalink)
Zoomed and... not seeing it. Down below in the diffuser, yes.
09-12-2013, 06:28 PM
#752 (permalink)
lower
Originally Posted by kach22i
Is this a strategy to keep a Lithium-ion pack alive?
09-12-2013, 07:11 PM
#753 (permalink)
The Following 3 Users Say Thank You to NeilBlanchard For This Useful Post:
09-14-2013, 03:19 PM
#754 (permalink)
09-14-2013, 03:59 PM
#755 (permalink)
09-14-2013, 05:10 PM
#756 (permalink)
Do unbuilt concepts count?
Exploder II by Cristian Polanco, Guatemala
An inverted wing rounded on top for crosswind performance, and with a shallow V-shape to the side to suppress vortexes forming at the top. The open wheels are questionable though.
09-14-2013, 06:20 PM
#757 (permalink)
An inverted wing ........
I'm completely hooked on inverted wings (expressed as car bodies) at the moment, thanks for posting.
Looks to be another one off that same site.
http://www.michelinchallengedesign.c...iu-shun-china/
Bulldog GT by HBH: An Aston-based mid-engined supercar
04 November 2011
http://www.classicdriver.com/en/arti...gined-supercar
09-16-2013, 09:11 PM
#758 (permalink)
Extreme Aerodynamics Due To Unique Roof Surface
http://futuristicnews.com/extreme-ae...-roof-surface/
A new concept car has been presented by a French designer Dimitri Bez. Hexa is a solar-powered car, featuring an unusual roof covered in dimples. The unique roof surface, inspired by a golf ball, helps to increase the vehicle’s aerodynamics, efficiency, reduce its drag and limit any heat transfer.
09-17-2013, 12:17 AM
#759 (permalink)
That actually looks reasonable, dimpling only the areas that might conceivably benefit, instead of the whole car just because they can. Although some of the dimples should be perforations to make the backlight.
They're round to be omni-directional, couldn't you do the same thing with louvers, sort of a linear dimple?
https://www.google.com/search?q=Audi...r+Concept+2000
09-17-2013, 04:01 AM
#760 (permalink)
Looking at the angles of the roof, it doesn't need any dimpling for aero purposes.
Where the design might use them - like aft of the rear wheel arcs, where the bodywork falls of sharply - there are no dimples.
You don't want round shapes on the rear.
