Old 06-23-2016, 02:28 PM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Just had my BEST TANK!
69.1 mpg, over 678.8 miles in my 2000 Insight.
Wa-hooo!!!
AND - This weekend I plan to clean the EGR manifold passages. That should give some additional improvement.
Coast long and prosper.
The Following 2 Users Say Thank You to brucepick For This Useful Post:
Dave's Civic Duty (07-05-2016), The donkey CRX (06-24-2016)
Old 06-23-2016, 02:39 PM   #2 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Nice job!
FYI - I happen to know from experience you can drive at least twenty miles with zero bars showing on the gas gauge, so I expect to see you in the 700s next tank
Old 06-23-2016, 02:55 PM   #3 (permalink)
Woohoo, congrats.
Old 06-23-2016, 04:14 PM   #4 (permalink)
brucepick's Avatar
Gen-1 Insights
Originally Posted by cowmeat View Post
Nice job!
I dunno about that 70+ mpg thing. Maybe! I've been languishing in the mid-high 60's for a while. I believe I lucked out with the weather on this tank.
But yes - it should improve with a cleaning of the EGR passages. I've been spraying the nuts and bolt heads with PB Blaster in preparation. Very rusty. They look awful. The gasket and 3 o-ring things are ready for me to pick up at local Honda place.
Old 06-23-2016, 05:20 PM   #5 (permalink)
cowmeat's Avatar
Maverick Hybrids
Check the torque on the plugs while you're at it, they tend to back themselves out on these things.
My first Insight was running a little rough when I bought it and I assumed it was the motor mount/3-cyl issue. But I went to check the plugs to see if they needed to be cleaned, and found that one had worked its way almost out of the hole, the only thing stopping it was the coil being screwed down
Old 06-23-2016, 05:32 PM   #6 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
The plugs do tend to back out on these motors.
My most recent tank:
My driving technique is still being refined after two years; it's largely what is responsible for the improved mileage.
Old 06-24-2016, 11:19 AM   #7 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
70 is just an inch away. Keep going, you'll do it!
Also, this thread has good info. I wondered how far I could go on the gas gauge and had no idea about spark plugs backing out! How often do you guys check those?
Old 06-24-2016, 11:29 AM   #8 (permalink)
I found mine loose when I decided to change my spark plugs preventatively about 6 months after getting the car (~1.5 years ago), as they were still the original plugs at 170k miles, so far as I could tell. I haven't checked them since, but ought to. I'll report back whether I find them loose or not this evening.
Old 06-24-2016, 12:07 PM   #9 (permalink)
cowmeat's Avatar
Maverick Hybrids
I check my plugs about every six months (basically I pull the coil boot, put a socket on them and make sure I can't turn them easily).
Old 06-26-2016, 09:38 PM   #10 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
Just got started w my 2000 TDI 5 speed Beetle, pre-SGii, 49.87MPG. Had a 93 Civic Hatch 5 speed, best on that was 47MPG. That car had the special VX or HX engine. Someone stole it while I was on a Valentine's Gig a few years back. Come out 2:30 in the morning & no car! Had so many rust holes in it, friends called it the cheese curl car, spray foamed the holes, haha!
Dave
The Following User Says Thank You to Dave's Civic Duty For This Useful Post:
brucepick (07-05-2016)
