Old 08-06-2013, 07:01 PM   #91 (permalink)
runnabout - '95 Honda Civic EX
90 day: 43.79 mpg (US)
Originally Posted by wolydotmatrix View Post
I wired the switch through the clock-spring (cable-reel).
The first time that I had heard someone use that term I thought they were crazy. Never put much thought into how exactly all those wires were in the steering column
Old 08-06-2013, 09:52 PM   #92 (permalink)
Coasting in the Carolinas
wolydotmatrix's Avatar
Blue - '94 Honda Civic DX
90 day: 47.49 mpg (US)
I took one apart once (after i broke one at work) just to see what happened. Looks like ribbon cable that you would find inside a computer, rolled up like bubble gum tape. Reminds me of a clock-spring that you wind taught, with the wheel turned in one direction and unwind turning the other. The wheel and reel must be timed together. Over the years, the wires are getting smaller and the reel's are getting thicker. Just think of all the steering wheel controls in the cars of today. To explain the brakage, the reel was out of time by 180 = full lock breakage.
Proper Prior Planning Prevents Piss Poor Performance.
Old 09-09-2013, 05:59 PM   #93 (permalink)
Wannabe hyper..., miler !
bikeprof's Avatar
White Variant - '96 Volkswagen Passat TDI ~ GLS- 4 Cyl
Minivan - '96 Chrysler handicap IMS built LXI
Insight - '10 Honda Insight EX
Wolydotmatrix:
Hmmm, so your car is an AUTOMATIC?
If your car has gears, then you DO have to remove hands from steering wheel, NO?
Old 09-10-2013, 09:52 AM   #94 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Look at his mileage log. It's a manual. The automatic shifter knob offers a convenient, professional-looking place for a button on the shifter.
Since it's a manual, he has to move a hand from the wheel regularly anyway. As does anyone driving a manual.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
wolydotmatrix (09-14-2013)
Old 09-10-2013, 03:59 PM   #95 (permalink)
bikeprof's Avatar
YES, it is a manual now that you mentioned but that was something I could not locate when I went looking into his personal data.
That you mention is what I presumed, that the vehicle was a manual one and that the necessity to remove the hands from the wheel was a necessity !
Hmm, double work?
That the switch is there is GREAT! He has one installed...
The Following User Says Thank You to bikeprof For This Useful Post:
Wobblybob (09-13-2013)
Old 09-14-2013, 09:24 PM   #96 (permalink)
Hmm, double work?
Yes, as with almost all cars your hands must be removed form wheel at one point or another while driving. My intent was to limit the number of times "my" hands had to be removed because of shifting. That being said, most of my EOC driving is in 5th gear. I just use the clutch disengage and then resume. I just move my thumb about an inch and push in the clutch.
Old 09-15-2013, 12:06 AM   #97 (permalink)
fifteenwindow's Avatar
Nameless - '14 Mitsubishi Mirage DE
90 day: 53.13 mpg (US)
My kill switch is mounted under the steering wheel, just to the left in the corner of the panel that you'd remove to get into the wiring around the fuse panel in a 94 civic. I can't see it from where I am sitting, but it's near my left knee. I used a heavy duty toggle switch from the hardware store. At first I had a momentary switch in there from Radio Shack, but I did not trust it. It seemed too cheaply made for such a serious job.
Old 09-26-2013, 08:13 PM   #98 (permalink)
Green Machine - '99 Dodge Caravan
90 day: 26.78 mpg (US)
Auto start and stop switch.
Anyone ever thought of making an auto kill and start switch?
Basically detecting neutral gear and shutting off when no throttle is needed then restarting when the throttle is pressed?
Or something like that anyways.
Old 09-26-2013, 10:26 PM   #99 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
For instance if the car's speed sensor shows it is still and the gear selected is neutral? Or something like that? That's basically what lots of new cars are doing correct? Like the new Honda Fit.
Old 09-27-2013, 05:29 AM   #100 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
That could be an interesting project... To detect if vehicle is moving for Start/Stop and to EOffC - this one could be more tricky...
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
