04-17-2014, 07:34 PM
#31 (permalink)
Liberty Lover
Emre2blue, nice diffusers.
Why did you narrow the channels of them?
04-17-2014, 11:07 PM
#32 (permalink)
Too many cars
Originally Posted by johnlvs2run
I have one, but thought driving at the same time would cause it to short out.
Do you plug it into the power outlet in the dash, and leave it plugged in all the time?
Mine's always connected. I don't see how it would be shorting out.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
04-17-2014, 11:13 PM
#33 (permalink)
Liberty Lover
I'll try that then. The strange thing is that the Ex power outlet only works when the key is on, so the solar charger can't be used when it's off.
04-17-2014, 11:54 PM
#34 (permalink)
Too many cars
Same with mine. I connected the solar panel to the always hot dome light power wire. And I used a barrel plug so I can use the panel to top off my jump starter box as well.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
04-18-2014, 12:00 AM
#35 (permalink)
Liberty Lover
Thanks for the great idea and the photo.
04-20-2014, 03:03 PM
#36 (permalink)
Actually, don't know, I did it by my self, I thought dimensions are good to do the job. And it did actually . I wish I could take a picture of the rear window when it rains while I was driving. Water goes like eight straight line from top to bottom of the window. and cuts a little 0,2lt/100 km, from the consumption. Maybe if I tweak it, it would cut more than 0,2lt/100 km, If I had a chance I would do it with 3d printer. and polish it. Current ones are stainless steel, like knife.
The Following User Says Thank You to emre2blue For This Useful Post:
04-20-2014, 09:36 PM
#37 (permalink)
The vanes on diffusers are used to straighten airflow amd are generally longitudinal. Vortex generators—what I would call this example—are canted to ... generate vortexes. Which [apparently] can be helpful for reattaching airflow to a surface if they are mounted upstream from the point of separation.
Have you tried placing them on the top of the glass? That's where they would need to be on my car because separation starts about the midddle of the backlight.
11-12-2014, 12:38 AM
#38 (permalink)
halos.com
I'm working on a belly pan and something for the rear. These are my current aero mods.
The side skirts are Coroplast. The splitter is the top of an extra bumper cover. The tire deflectors are baler belting. The wheel covers are plastic serving trays. The grill block is cut from a pickup truck bed liner.
I started looking for a different tire deflector material after I hit my left one on a curb yesterday. The carnage wasn't total, but it did tear things up a bit. I'll have to get some of the baler belting. I like the fact it's stiff yet flexible. Might also have to try that for side skirt material.
[edit] took a picture of the fairing. Yellow line is the part that broke off. Red circle is a metal screw that it pulled away from. The fairing also twisted about 90* after I hit the curb, and then backed away. Fortunately, I was able to turn it back and retighten the attach bolt.
As I was musing on this today, it occurred to me I could get some rubber wall border and use that as the bottom 3" which would keep the bottom flexible while still deflecting airflow around the tires...
Reason: added picture
The Following 2 Users Say Thank You to ECONORAM For This Useful Post:
11-12-2014, 02:17 PM
#39 (permalink)
Spaced out...
This thread has me interested in splitters now. Need to do more reading and then build one. Friend has a whole bunch of plywood laying around from a shed he's tearing down. I think I need to grab a couple of sheets and start playing around...
Here is my "stealth" upper grill block. Coroplast from behind, glued/sealed using caulk;
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
11-14-2014, 02:09 PM
#40 (permalink)
Always Too Busy
Originally Posted by ECONORAM
[...]it occurred to me I could get some rubber wall border and use that as the bottom 3" which would keep the bottom flexible while still deflecting airflow around the tires...
I was thinking about the same thing, except all the border material I've looked at is rather flimsy. Spent quite a bit of time at the big box hardware stores looking, actually.
Sometime soon, I'm going to contact a local semi truck trailer outfitter, and see how much the rubber skirting they put on the bottom of trailer wings would run me... You know, scrap pieces. I think that would have the rigidity needed. Probably out of my price range, but, you know, it's a thought.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
