Old 11-30-2018, 07:13 PM   #121 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I forgot to mention that 3x2 might be cutting it too close voltage wise for those caps. That gives you a max voltage of 13.5 assuming every cap is perfectly in balance.
I mean the shape of the caps themselves, they're too long in a row of 6 to fit in my battery area.
Old 11-30-2018, 07:30 PM   #122 (permalink)
90 day: 29.78 mpg (US)
Hah, I get it now. For some reason I was envisioning my 3 in one row, 2 in another row setup using my 2.85v caps.
Old 12-01-2018, 06:23 AM   #123 (permalink)
teoman's Avatar
A3 - '12 Audi A3
The capacitors may not appreciate the heat in the engine bay for their longevity. For the caps in the engine bay, a fellow member had suggested adding 2 hoses to the battery box. One leading to the front of the car and the other leading to the intake. That way the battery compartment is cooled when the engine is running with a constant flow of ambient air. This will obviously not help heat soak when the engine is stopped so insulation may be in order.
Old 12-01-2018, 06:23 AM   #124 (permalink)
teoman's Avatar
A3 - '12 Audi A3
My lithium battery bms has arrived. I hope to be able to play with it next week.
Old 12-01-2018, 10:28 AM   #125 (permalink)
Mine are living in the rear driver wheel well, that's where my "battery box" is.
Old 12-01-2018, 03:33 PM   #126 (permalink)
Not as pretty as when it shipped:
Next to my lithium battery:
Supercapacitors tucked into my spare well:
Lithium battery had to move to the back, these caps are BIG! They nearly fill the footprint of the original 12v battery.
I'd say the 400F caps were entirely inadequate for starting the car, but these caps are huge. Probably an ideal size for my car would be ~1200-1600F. On the flip side, the starter really cranks now.
Old 12-02-2018, 04:05 AM   #127 (permalink)
Sweet! Make darn sure those caps don't ground out on anything even by rubbing through insulation. They will spot weld in an instant.
Xist (12-09-2018)
Old 12-02-2018, 04:30 AM   #128 (permalink)
teoman's Avatar
A3 - '12 Audi A3
For some reason the pictures do not appear on my phone.
They do not appear on my computer either.
Old 12-02-2018, 04:58 AM   #129 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Dang, i somehow missed that alibaba link. Are they genuine maxwells? And are they brand new?
If they are genuine that is a real bargain!
Old 12-02-2018, 05:00 AM   #130 (permalink)
Looks like it, and looks like it. They're behaving as I'd expect.
