Old 09-19-2008, 10:03 PM   #1 (permalink)
90 day: 51.82 mpg (US)
Master list of 65+ proven mods for increasing MPG
Along the lines of our 100+ hypermiling/ecodriving tips compilation, here's another one:
---> 50+ efficiency modifications - EcoModder.com
Feel free to make comments, suggest additions/corrections in this thread. Thanks to the other moderators for working behind the scenes to get this ready.
Old 09-19-2008, 10:50 PM   #2 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
Great compilation. Will the link be put on the top banner alongside 100+ tips?
In case I missed it, you may also want to mention that some mods may violate vehicle codes (and put in the requisite "check your local laws first!!!" warning). Ex: front wiper delete
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
The Following User Says Thank You to azraelswrd For This Useful Post:
rdtony (12-03-2009)
Old 09-19-2008, 11:03 PM   #3 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Chevy Metro LSi
90 day: 48.88 mpg (US)
That is AWESOME!! Nice job, I'm sure that took a bit of time. Another tip if you wanted to keep your wipers get a set of the new Bosch ICON style wipers --> Bosch ICON Wiper Blade - OE Bracketless Technology for the Aftermarket pricy at $20 for one blade, but they work great and hopefully help out slightly in the fight against drag!
*they are also called in general bracketless or beam blades
Old 09-19-2008, 11:10 PM   #4 (permalink)
Hi,
Typo patrol:
Frontal area reduction - permalink
This mod involves any radical modification that reduces frontal area. This may include c[h]opped tops,
Old 09-19-2008, 11:23 PM   #5 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Awesome job
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 09-21-2008, 08:01 AM   #6 (permalink)
Originally Posted by azraelswrd View Post
Great compilation. Will the link be put on the topbanner alongside 100+ tips?
Yup, that's the plan.
Also, there is a mention about legality & safety in the blurb at the top.
Typo fixed!
oliyar (04-29-2010)
Old 09-22-2008, 09:03 PM   #7 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
How about losing your OWN weight! A lot of us could stand to lose 10-50+ pounds which definitely would improve our MPG. Seriously, that is an important factor in our search for optimal mileage.
Old 09-22-2008, 09:10 PM   #8 (permalink)
amateur mech. engineer
Sporty Accord - '88 Honda Accord LX-i
90 day: 23.25 mpg (US)
Dad's Camry - '01 Toyota Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Toyota Camry
90 day: 37.3 mpg (US)
I found a couple of mistakes.
1) Advancing ignition timing: If you increase power without increasing fuel flow, you will decrease the BSFC, not increase it. The goal is to minimize the BSFC, which is a measure of the amount of fuel used to do a certain amount of work.
2) Hot / warm air intake: I think that a higher air intake temperature will increase the heat transfer through the cylinder walls because of the increased temperature difference between the air and the cylinder during the power stroke. Also, hot intake air doesn't change ignition timing unless the engine starts to knock (or ping) and the engine is equipped with a knock sensor. If the engine is not equipped with a knock sensor then somebody may need to retard the timing to eliminate knocking. You may want to mention that power will probably go down with hot air intake because of reduced air density.
Old 09-22-2008, 09:49 PM   #9 (permalink)
sickpuppy318's Avatar
the mazda - '01 MAZDA Protege LX
90 day: 34.68 mpg (US)
i think i found one too
Call channel five, get them broads over here, tell them of the tragedy of my trappedness.
Old 09-24-2008, 09:22 AM   #10 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
I dreamed about it one week ago
Added to the list of documents to be translated into french.
Thanks a lot,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 148 08-12-2021 10:53 PM
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
