Old 08-23-2009, 04:47 AM   #51 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
biggy boy -
Originally Posted by biggy boy View Post
Hi guys
I too have a Maxitrip AKA Maxicrap
I got mine at Princess Auto about two weeks ago.
I am finding the same problems with distance being to low.
And the current trip litres per 100 KM average is the same as the total.
Do you think if we use the English setting (MPG) instead of the metric settings
the mileage would read out correctly?
This thing is driving me nuts! I'm thinking of returning it and getting a Scanguage II.
I have sent two Emails to the manufacture Via there website, instructing them of the problems and asked when they will be releasing an update. I have not heard back from the MF's yet. The first Email was sent a week ago.
Glen
Welcome to EM!
For the ScanGauge, people have speculated that defaults should be entered in the unit with the better "granularity" in order to help the accuracy of the ScanGauge. This usually(?) means metric input. For instance, liters are smaller than gallons, so inputting the size of the gas tank in liters gives the Scangauge a more accurate default value.
Internally, it's a safe bet that the programming is metric. When the user setting is in English units, that just means the metric values are being converted for display.
CarloSW2
American Solar Energy Society
Old 08-23-2009, 09:24 AM   #52 (permalink)
truck - '01 GMC Sierra
90 day: 23.08 mpg (US)
Thumbs down
Thanks for the welcome
Yes using metric units for the setup does make sense!
That is what I used when I input the setup info.
The only thing I can figure about the inaccuracies of the Maxitrip is,
they rushed the software and didn't test it out for long enough before releasing it to the public.
I noticed at there web site they have software updates for several of their
other products, but not the Maxitrip
I wonder how long this device has been on the market?
I need to make a decision soon
Do I take it back?
Or do I wait for them to hopefully come out with a fixed update.
I like the look and feel of the unit.
But who knows for sure if they are going to update the software at all??
If I wait another week or two or more I probably won't be able to return it.
It really is of no use when the distance is so far off.
Old 08-23-2009, 01:45 PM   #53 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
biggy boy -
Do I take it back?
I agree. Chances are the MPG algorithm is not robust for the broad spectrum of cars out there. I'll bet they only tested for a narrow range of cars, got "good enough" results for those makes and models, and started selling it.
Scangauge got it right the first time, so they have a respectable track record. Aesthetically I think the Maxitrip looks nice, but it sounds like it can't cut the mustard for MPG.
CarloSW2
Old 08-23-2009, 05:59 PM   #54 (permalink)
Ya and it doesn't cut the mustard for litres/100 KM either !
Old 08-24-2009, 10:25 PM   #55 (permalink)
pickup - '01 Dodge Dakota Quad Cab 4x4 Sport
90 day: 16.35 mpg (US)
Focus - '16 Ford Focus SE
90 day: 31.46 mpg (US)
Maxiback
Do I take it back?
Welcome again bb.
I tried calibrating this thing in metric units. I'm pretty comfortable in them since I lived in Europe or Asia for about eight years off and on. Did not make any difference! It reads low for total miles or kilometers.
Mine is on it's way back. The main reason I got interested was the USB port. I thought possibly you could get some logs out of it. My thoughts are to spend the extra $30 US and get a SGII if you feel you need more instrumentation.
I am just not sure for myself. The factory CMTC average MPG tracks very closely to miles/gallons figured the old fashioned way.
Bottom line: too many problems and no apparent support.
Last edited by taredog; 08-24-2009 at 10:27 PM.. Reason: clarity (I hope) of miles divided by gallons
Old 08-25-2009, 07:58 AM   #56 (permalink)
I ordered a Scanguage II last night.
Got an email from the retailer saying it's going in the mail today.
The Maxitrip was returned yesterday.
Glen
Old 08-28-2009, 01:40 AM   #57 (permalink)
I too was once on the verge of returning my Maxitrip, but I finally got it figured out.
There is one major bug that throws off a lot of the Maxitrip's calculations. The distance driven is based off speed, but for some reason it's being multiplied by approximately .75. Miles per gallon is calculated using distance, so if the distance is wrong, almost everything is wrong.
To fix it, adjust the speed calibration value so that your distance driven is correct. 1.32 is a good starting point. Obviously your speed will no longer be displayed correctly, but you have a speedometer in your car already so who cares.
After doing that, my mpg readings are very accurate (within 1% of what I calculate when I fill up)
Old 08-28-2009, 02:07 AM   #58 (permalink)
Correct me if I am wrong..
We all adjusted the speed calibration to match the actual speed. Guess we were wrong.
You are saying to experiment with the speed calibration until the distance driven is correct? And live with that? That we must adjust the "speed calibration" to fix the miles driven and live with the other inacuracies?
Thanks for the solution. I guess we all can live with that after spending $100. We didnt't need any of those other readings anyway.
Just curious gtg465x, if you are working presently, who do you work for?
Old 08-28-2009, 02:31 AM   #59 (permalink)
You weren't "wrong" for adjusting the speed calibration to match the actual speed. Like I said, it's a bug, and I just gave you a workaround.
Yes.
The only inaccuracies you'll have to live with are the instant and average speed. Everything else will be correct. Do you really need these two readings? Your car does have a speedometer right?
I'm pretty satisfied that I get nearly all the features of a Scangauge for $100. By "any of those other readings", I guess you're just referring to speed lol.
I'm a college student. This is what I get for helping people out huh?
The Following 2 Users Say Thank You to gtg465x For This Useful Post:
cfg83 (08-28-2009), nmgolfer (08-13-2010)
Old 08-29-2009, 03:23 PM   #60 (permalink)
Yes.
Yeah, sometimes this is what you get from crotchety old men when you try to help out. Thanks for figuring out the work around.
I just hate to spend my money on a product that does not work as advertised. I get more than enough of that with vendor's software, firmware and hardware at work.
Last edited by taredog; 08-29-2009 at 11:32 PM.. Reason: added firmware and hardware to whining
