08-26-2020, 04:20 PM
#311 (permalink)
Originally Posted by ssullivan
That looks faaaast, in a much classier way than the usual Miata in my opinion.
It looks a bit crude & slab-sided to my eye... sorta like an old BMW 7-series factory skirt:
08-26-2020, 04:26 PM
#312 (permalink)
Originally Posted by serialk11r
Why isn't there a tail spoiler yet?
Good point! Like this?
I didn't test/research it enough. Too many projects!
08-26-2020, 11:54 PM
#313 (permalink)
I just checked Ebay and turns out there are no cheapo 50 dollar spoilers of substantial size
IIRC the trunk is so far below the "template" you can really just add to the trunk any 2-3 inch tall chunk of foam cut to approximate tapered "ducktail" shape (I'm sure you can make it look great, given your work).
The Following User Says Thank You to serialk11r For This Useful Post:
08-27-2020, 01:05 AM
#314 (permalink)
08-27-2020, 09:09 AM
#315 (permalink)
Drilling for water
Since I dont use this car in the winter, I'm OK with drilling little holes underneath for mounting brackets, in this case for the skirts.
Imagine my surprise when I punctured the right side rocker panel:
It ran for a surprisingly long time! Maybe a cup or 2 of water came out.
I'm not sure how the rocker is supposed to let rainwater out (or how it gets in), but this one is obviously blocked... or used to be.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
08-27-2020, 09:46 PM
#316 (permalink)
Cyborg ECU
Car catheter?
08-29-2020, 01:30 AM
#317 (permalink)
Master procastinator
Oh no! You punctured the blinker fluid reservoir!
The Following User Says Thank You to iikhod For This Useful Post:
08-29-2020, 02:47 AM
#318 (permalink)
Eco-ventor
Maybe the previous owner was an ecomodder too and those were his ballast tanks for downhill trips?
08-29-2020, 05:01 AM
#319 (permalink)
Hnm...
An enclosed space. Wonder what you could use it for.
I am trying to fit a shower on to my car at the moment, and if i had found such a reservoir I would try to utilize it.
09-08-2020, 12:48 PM
#320 (permalink)
Originally Posted by teoman
Hnm...
Helium!!
