Old 08-23-2009, 01:58 PM   #21 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
i think you'll have to do some a-b-a. mileage or tuft testing
because of the shape of your car, it might react differently than anyone might expect. your rear window is near vertical. might have a recirculating bubble in there that is kinda protected by the spoiler. or maybe the spoiler is nothing but a big sail... either way, an abnormal result good or bad wouldnt surprise me
Old 08-23-2009, 09:59 PM   #22 (permalink)
chuckm's Avatar
Exploder - '02 Ford Explorer xlt
Rolla - '02 Toyota Corolla ce
90 day: 44.43 mpg (US)
Christ and Hermie,
I think I have an easy way to aid in solving this disagreement. First, was a spoiler standard equipment or was it an option? Or perhaps this spoiler was an after-market add-on? If every single stock MR2 has a spoiler, it is possible that there was an engineering reason for it. However, if this spoiler was an after-market job, then it is almost certainly to be more fashion statement than safety or handling requirement.
Still, I've come across a relative few situations where a spoiler produced a measurable improvement in safe handling at normal highway speeds.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 08-23-2009, 11:19 PM   #23 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
woodsmith -
How about the following :
1 - Take off the horizontal part.
2 - Use the sides as framework for a Kamm-Back.
3 - Spend lots of time and effort making it reversible (this is optional).
Benefits :
- Kamm Back may improve range
- Reversible in case you want to return to the OEM look
Problems :
- Won't make any money selling the spoiler
- Maybe a lot of effort that won't pay off (depends on your POV)
CarloSW2
American Solar Energy Society
Old 08-24-2009, 12:36 AM   #24 (permalink)
Has everybody forgotten our spoiler guidelines?
It's pretty safe to say, spoilers increase drag unless they take the form of a surface "extension".
I suppose there could be the exception that proves the rule...
Me, I'd leave it until I see how fast my EV goes and/or decide if I like how it looks.
Old 08-24-2009, 06:13 PM   #25 (permalink)
wing
I vote lose it.
Old 08-24-2009, 07:41 PM   #26 (permalink)
woodsmith's Avatar
Originally Posted by chuckm View Post
Christ and Hermie,
This spoiler is an aftermarket one to replace the one that was on the car. I have yet to see an MR2 without a spoiler at all and that could just be down to the usual types of owner prefering a spoiler or wing of any description as well as the factory fit option.
Originally Posted by cfg83 View Post
woodsmith -
Benefits :
Problems :
CarloSW2
I like that idea but not sure about the amount of body work involved to get it to look and act right not how the insurance company and the IVA will treat it.
I would probably only go as far as blanking off redundent vents and holes and maybe covering over the rear wheel arches.
My EV Trike Project
Old 08-24-2009, 08:08 PM   #27 (permalink)
Is this even a stock spoiler? I don't think I've ever seen an MR2 with one of those.
Old 08-24-2009, 08:20 PM   #28 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
winkosmosis -
My picture shows the OEM spoiler. I think the sides are OEM, and they just swapped out the horizontal part. If you look at the rear picture, I think you can see that it looks a little "incongruous" in the way it curves.
CarloSW2
Old 08-27-2009, 08:34 PM   #29 (permalink)
MR2 - '93 Toyota MR2 Turbo
90 day: 22.92 mpg (US)
Send a message via AIM to Blue Bomber
A fellow MR2 owner here. The wing is definitely not stock on your car, woodsmith, but the sides are. From what I've experienced, if you don't want to remove the wing because of the holes, but don't want to keep your current spoiler for drag reasons, find a stock one. The wind barely hits it (rain drops and especially snow sit on mine even at 60mph). Just for reference, but there were MR2s without spoilers available, as there are used OEM trunk lids out there without holes in them.
As far as the rest of the car, there are 2 major aerodynamic issues:
1: The rear, especially where the back window and engine lid are. There is very little flow up through the vents in the lid, so the air from above just dips in and slowly swirls around in that area (causing annoying water spots after it rains, since the water just sits there). That's why the air never really reaches the spoiler in the intended fashion. Add a vented lexan panel over that area (add venturi tabs at the end of the roof for bonus points!), and you'll probably see enough airflow at the spoiler to start thinking about removing the spoiler.
2. The front end. Since it's a mid engine car, the air basically flows through the radiator and slams against the front trunk firewall, then gets shoved almost straight downward, instead of flowing through the engine bay to the back. That, coupled with overall poor stock underbody aerodynamics, can actually create lift at high speeds from all the turbulence. Many people have complained about that throughout the years, a feeling of the front feeling floaty and disconnected on the freeway. The car can definitely benefit from a front and rear end underpanel to smooth things out. There are also what are known in the MR2 community as "Speed Flaps". They were available on MR2s in Japan, but never made it over here. They're the deflectors that you see under many cars today in front of the front wheels. They significantly reduce front end lift at high speeds. You can find replicas at Brady Motorsports.
As far as the radiator, if you're looking to sink some cash into this, you can tilt the radiator forward, cut a hole in the hood (or get a vented aftermarket hood), and vent the passing air out over the hood. That's the most aerodynamic way, and will significantly improve the front end's faults. A company called Border even sells a conversion kit.
Beyond those two issues, there really aren't any other unique problems as far as aerodynamics. The usual mods shown on this site will work, though they won't make your car look any prettier. Check out MR2OC.com, the biggest MR2 site out there. You need to register first to view anything, but there's a wealth of information on anything MR2 related you need.
Old 08-28-2009, 10:51 AM   #30 (permalink)
The radiator conversion is pretty awesome. I'm surprised enough people do that aeromod that there's a kit.
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 42 12-27-2012 01:59 AM
Another boattail + rear wing botsapper Aerodynamics 7 04-29-2009 08:43 PM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 09:40 PM
civic hatchback rear wing Nden Aerodynamics 3 12-20-2008 10:12 PM
