Old 08-28-2009, 06:41 PM   #31 (permalink)
woodsmith's Avatar
Cheers Blue,
The car is a Japanese import so it has all the underbody panels.
I am doing an electric conversion on it so engine and radiator airflow won't be needed, I just need to keep the controller and the motor cool.
I will block off the holes in the nose cone and see what I can do with the area above the engine cover. If I can change teh spoiler for a smaller one then I will do that. I am on the UK MR2 owners club forum so I will see how much of the ICE and parts Ic an sell on and see if I can trade the spoiler too.
Thanks.
My EV Trike Project
Old 08-28-2009, 07:55 PM   #32 (permalink)
90 day: 51.82 mpg (US)
Late to the party, but I also would have said "lose that aftermarket spoiler" to reduce drag.
There's a chance the OEM spoiler may have reduced both rear lift and drag compared to the "base" car that had none. It'd be useful to know if Cd figures are available for the two versions (turbo and non-turbo versions, if I'm not mistaken).
As for noticing a difference in driving once the conversion is done, I'm afraid you won't be able to conclusively / reliably say whether it helps or hurts your energy consumption in regular use - likely way too many variables to eke out the effect of a single mod (unless it's utterly massive).
You'll have to do something a little more methodical, such as repeated coast-down testing from high speed, or terminal velocity / average speed testing on a steep, long hill.
Old 09-07-2009, 07:30 PM   #33 (permalink)
Stickers - '91 Ford Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Originally Posted by MadisonMPG View Post
Who brain washed Hermie at birth?
I could ask the same of you.
Originally Posted by Christ View Post
The MR2 will not necessarily have more weight in the rear
*I actually think it's 42/58 F/R*
Contradictory, don't you think? Especially since even a BMW front-engine, rear drive has a front/rear bias of around 52/48 F/R, and they even put the battery in the trunk to improve wieght bias and design their cars to have zero-lift aerodynamics.
The engine is the heaviest thing in the car. Obviously, unless you're doing a LOT of work to counter it, wherever the engine sits is going to be the heavier side. Common sense, dude.
Old 09-07-2009, 09:44 PM   #34 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
maybe just "chop" the wing and use it for a mounting bracket....
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 42 12-27-2012 01:59 AM
Another boattail + rear wing botsapper Aerodynamics 7 04-29-2009 08:43 PM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 09:40 PM
civic hatchback rear wing Nden Aerodynamics 3 12-20-2008 10:12 PM
