Old 11-25-2020, 12:37 PM   #11 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Kind of an extension on Vman's suggestion, how far in do separation edges affect the base pressure?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 11-25-2020, 04:43 PM   #12 (permalink)
Yes I should be able to do something like that.
Cd (12-05-2020)
Old 11-30-2020, 02:42 AM   #13 (permalink)
Fired up the system this morning... and no go.
Not sure if it's my interpretation of the software install instructions or something else. Just trialing it first on my desk PC.
Have emailed the makers.
Old 11-30-2020, 10:51 PM   #14 (permalink)
Luddite
deluxx's Avatar
ol-green - '96 Honda Civic LX
90 day: 50.11 mpg (US)
Since I have no tech literature on this subject, and haven't personally tested it, there's a fair amount of misleading information in earlier posts...
Old 11-30-2020, 11:12 PM   #15 (permalink)
Great! Do you want to cite it?
Old 12-01-2020, 03:52 PM   #16 (permalink)
Still no joy with the software, so apart from lots of emails going back and forth, nothing has happened.
Old 12-03-2020, 05:48 PM   #17 (permalink)
Can't make the provided one work, so they're sending another. Fingers crossed!
Old 12-09-2020, 12:07 AM   #18 (permalink)
New P16A arrived and is all working.
Here it is connected to just one of the 16 pressure pucks. The spike on the moving graph display is where I blew on the puck.
The P16A talks to the laptop via Evoscann's CANDI converter.
This is the 'absolute' version of the sensor and so I set the baro pressure and then it reads positive or negative with respect to that (ie no pitot tube / tank reference pressure needed). You can warm the sensor with your hand (temp displayed on laptop) and the measured pressure doesn't change at all.
Should be able to do some car stuff tomorrow.
Edit: I've discovered a software setting for 'relative' measurements, where one port is the reference (eg connect to the static port on pitot tube).
However, there appears to be no smoothing or averaging function in the software, something that would be useful. I am not sure that I am in a position to suggest changes to the software, but I can always try!
Old 12-09-2020, 12:57 AM   #19 (permalink)
This is far better than the switchable manifold you said doesn't exist any way.
Old 12-09-2020, 01:07 AM   #20 (permalink)
Huh? Scanivalves have been used for decades in wind tunnels, so I am hardly likely to say they don't exist.
