03-20-2025, 12:07 AM
#561 (permalink)
Originally Posted by Logic
IF there was a way to create a VERY large spark (or 4...) one could do away with it..??
Would it be out of question to use 2, or even 3, spark plugs. I guess you know about Bajaj using 3 spark plugs in the Pulsar 200.
03-20-2025, 08:47 AM
#562 (permalink)
In Lean Burn Mode
I came up with that means of optimizing valve/chamber shape (Tuliping. Thx freebeard) ages ago while gas flowing my Alpha Giulietta 2L head.
I miss that car! If I knew then what I know now..!
I'm getting my head around what you have said (and not!  ) in the rest of your reply.
We'll chat more on that privately. But we are heading into territory where a picture (and gesturing) is worth a thousand words... (in a trustworthy ear!)
IIRC your compression ratio and AF ratio numbers aren't much different!? Hats off on that!
If I understand things correctly (with almost no research) the pre-chamber is basically about creating a very big 'spark' that lights more AF up faster, at a better crank angle closer to TDC, by setting fire to that separate mixture at a/the 'timing advance' that would otherwise be unworkable?
ie:
Hydrogen:
I NB that the previously discussed copper plating that creates a bit of H, more during/after the main combustion event, does not suffer from that drawback in a pre-chamber!
There are a good number of other possibilities for getting some 'free' H2 or Ozone type radicals out of an engine.
eg: A constant but separate (dioded) Ozone producing voltage (circuit) on the spark plug.
I'll get back to you on that when more of my vast multitude of ducks are in a row!
(I'm researching senescent cell clearance for my Mom (urgent) too atm, which is taking a lot of my free time)
Lots of good stuff here, thanks for the reply. In short what the pre-chamber does is makes its chamber an A/F rich area. I suspect the pre-chamber A/F during light load FE mode is around 16:1 to 20:1. The normal combustion chamber A/F is at 30:1 plus. Without the pre-chamber even with my race extremely high energy ignition system the engine starts to misfire above 20:1 A/F.
The second major thing the pre-chamber does is it creates a very powerful flame torch. This is due to its shape. The torch that enters the normal combustion chamber covers a lot of distance and a much larger area then a normal CC. This helps light off the very lean A/F area in the CC with a complete burn of all the fuel. The flame torch also increases flame propagation. This helps the extremely lean normal CC that without the pre chamber at a A/F ratio of 30:1 would have a very low flame speed. This where all my testing using my home-built gasoline combustion chamber paid off.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
03-22-2025, 12:20 AM
#563 (permalink)
Makes me wonder how it would handle ethanol.
03-22-2025, 08:53 AM
#564 (permalink)
In Lean Burn Mode
It works great with all types of fuel including ethanol.
These are the fuels I have tested with... Gasoline pump 91 and 87. E98 E85 E75 and E10. DTR601 auto paint reducer, and 7 other types of paint solvent. GEM 42 and 38 fuel.
03-25-2025, 01:57 AM
#565 (permalink)
I guess the only fuel it won't handle is Diesel fuel. Possibly it would be a good engine for a road trip...
03-25-2025, 02:44 AM
#566 (permalink)
Hmmm... With the compression ratios pgfpro runs I wouldn't be surprised if it did run on diesel too with the pre chambers blocked off.
The conrods etc might be a bit too light though.
(I get the impression compression ratio talk is avoided here to avoid a whole lot of: "Impossible! Lies!" hoo-ha BS.
Remember it's adjustable via the turbo boost and 2 AF ratios here)
03-26-2025, 10:28 AM
#567 (permalink)
In Lean Burn Mode
At this time, I haven't tried diesel fuel and to be honest don't have the interest in it. All my time and energy are to test types of petrol and different solvents.
This Summer I will be finishing testing Gasoline Compression Ignition GCI with this engine. The initial test looks very promising.
03-26-2025, 10:34 AM
#568 (permalink)
In Lean Burn Mode
It definitely could run on diesel in the high compression engine V2 version, but my focus is petrol and solvents.
Your 100% correct on given the compression ratios.  I decided to make a video on the compression ratio in the future and take advantage of visual aspect.
03-30-2025, 01:13 AM
#569 (permalink)
If I were 100% sure you wouldn't risk ruining the engine trying to run on Diesel fuel, I would be curious to see it running on Diesel. But anyway, since you're more into testing it with solvents, I guess you already gave kerosene a try.
With port injection? No way. Unless he tried a similar approach to the Hesselman engines, which featured direct injection and spark ignition yet were meant to use heavy fuels such as kerosene and Diesel fuel.
03-30-2025, 11:41 AM
#570 (permalink)
In Lean Burn Mode
My focus has been solvent type of fuels. I just have too many irons in the fire to add another one. lol
