Old 12-09-2019, 01:14 AM   #41 (permalink)
Master procastinator
Turan turan - '09 Volkswagen Touran Freestyle
Combot - '04 Opel Combo Tour
90 day: 40.37 mpg (US)
Originally Posted by Gasoline Fumes View Post
Normal 15" wheels would be too wide for these tires.
I now realized i read 145/65-15 as 145/65-13 for some reason my bad.
The Following User Says Thank You to iikhod For This Useful Post:
Gasoline Fumes (12-09-2019)
Old 12-09-2019, 02:23 AM   #42 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
15" steelies are heavy.
I compared the 15" spare on my Civic with the alloy (18lbs plus tire weight, 16lbs I think, so 34lbs total?) and the spare was significantly heavier.
I've seen 13" old CRX or Civic steelies for $50/pair that weigh about 13lbs each. There's a selection of 155/80R13 snow tires available.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 12-09-2019, 04:02 AM   #43 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I wasn't expecting 4" wide steel wheels to be so heavy. I might've gone with 13s if I had known how heavy the donuts were. I had some 155/80-13 Blizzaks with about one season left on them, but I gave them to another Insight owner. My skinny 15" Yokohama snow tires were only $44 each after a rebate, so I'm not complaining. The $60 rebate paid for the donuts. Maybe I'll try 13s next time, I have the wheels. I didn't find the weight noticeable, but the rolling resistance sure is different! I'm gonna try more pressure in them soon. They're at 50 now.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 12-09-2019, 05:26 AM   #44 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Originally Posted by Natalya View Post
If it's bucking in lean burn and you cleaned the egr passages then the egr valve is the main culprit. I'm not sure if it could be something else. I don't know how to test it unless you have a friend with an Insight and a good EGR valve you can try who lives near you. It's not super hard to pull the valve out.
I've tried unplugging the EGR valve and also replacing it with a block-off plate. Still had the bucking.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 01-21-2020, 12:57 AM   #45 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I had one of my RE92s blown up in my basement! 2009 date code and heavy wear on the inside edge. At least it didn't happen on the road! I have more, hopefully newer, RE92s.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 01-22-2020, 02:29 AM   #46 (permalink)
Wow. Ugly.
I had belts on another brand of tire begin to come apart on a travel trailer a few years ago that were date-coded at eight years. They were great tires, but the ravages of time, heat and load caused the belts to begin to release in the tread area. Fortunately, I noticed it and took them out of service before they were able to emulate the tire in the picture.
I like to run a hand over the treads when on the road. A lot of time, the belts can be felt coming apart due to distortion. You have to be careful doing this, because steel belts can produce sharp steel shards that can do a number on bare, tender hands.
The Following User Says Thank You to MeteorGray For This Useful Post:
Gasoline Fumes (01-22-2020)
Old 01-22-2020, 03:37 AM   #47 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Don't buy or use them report it to the NHTSA they are interested
Old 01-22-2020, 03:53 AM   #48 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
It's a worn-out tire that's 11 years old.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Natalya (01-23-2020)
Old 01-22-2020, 04:10 AM   #49 (permalink)
it goes to show you they manufacture grade A garbage..
my grandpa had tires 30 years old they still had 30 years old air in them
the person who bought the set used them to move a car that was on bricks 2.5ton
legally you can still sell them as there is a "loop hole" if you sell them as a spare or burn out use only..
good ole contract that they sign
people will actually buy them this is how i avoid the "disposal fee" when i get new tires
Old 01-22-2020, 08:33 PM   #50 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Not too bad for soft snow tires in cold weather! Cruising between 40 and 50 MPH. Some engine-off coasting.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Ecky (01-22-2020)
