Old 12-24-2014, 07:29 AM   #841 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Working through the code for the OBDuino, what if the A/F ratio is not 14.7? i.e. cars that are lean burn would in theory report incorrect readings, or during warm up the fuel report would be wrong...
Is there any reason NOT to use the ECU reported Injector Pulse Width? Why use MAF at all??
Old 12-31-2014, 11:08 AM   #842 (permalink)
Originally Posted by yensen View Post
Yes. This allowed mine to complete the init sequence using obduino code versions r198 or r203 with Arduino v1.0.5.
I never got much further than this. The screen would go to sleep seemingly randomly. I need to play with the config settings, but started to lose interest.
That's how it works You were right, it was enough to change serial.print serial.write. I did have a problem with the MC33290 because I'm just walked. thank you
Old 02-13-2016, 01:30 PM   #843 (permalink)
I've been using the OBDuino32k.pde file. When I load on the IDE plateforme I receive the following errors. I thought replacing prog_char by const char would do the work but it didn't. Any body can help ?
Code:
OBDuino.ino:597: error: 'prog_char' does not name a type
 prog_char PID_Desc[(1+LAST_PID)+(0xFF-FIRST_FAKE_PID)+1][9] PROGMEM=
OBDuino.ino:721: error: 'prog_char' does not name a type
 const prog_char obd_std_strings[17][9] PROGMEM =
OBDuino.ino:732: error: 'prog_uchar' does not name a type
 prog_uchar pid_reslen[] PROGMEM=
OBDuino.ino:757: error: 'prog_char' does not name a type
 prog_char pctd[] PROGMEM="- %d + "; // used in a couple of place
OBDuino.ino:758: error: 'prog_char' does not name a type
 prog_char pctdpctpct[] PROGMEM="- %d%% + "; // used in a couple of place
OBDuino.ino:759: error: 'prog_char' does not name a type
prog_char pctspcts[] PROGMEM="%s %s"; // used in a couple of place
OBDuino.ino:760: error: 'prog_char' does not name a type
 prog_char pctldpcts[] PROGMEM="%ld %s"; // used in a couple of place
OBDuino.ino:761: error: 'prog_char' does not name a type
 prog_char select_no[]  PROGMEM="(NO) YES "; // for config menu
OBDuino.ino:762: error: 'prog_char' does not name a type
prog_char select_yes[] PROGMEM=" NO (YES)"; // for config menu
OBDuino.ino:763: error: 'prog_char' does not name a type
prog_char gasPrice[][10] PROGMEM={"-  %s\354 + ", CurrencyAdjustString}; // dual string for fuel price
OBDuino.ino:764: error: 'prog_char' does not name a type
 prog_char noDTCcodes[] PROGMEM="No DTC codes"; // for MIL
OBDuino.ino:768: error: 'prog_char' does not name a type
 prog_char *topMenu[] PROGMEM = {"Configure menu", "Exit", "Display", "Adjust", "PIDs", "Clear DTC"};
OBDuino.ino:769: error: 'prog_char' does not name a type
 prog_char *displayMenu[] PROGMEM = {"Display menu", "Exit", "Contrast", "Metric", "Fuel/Hour", "Font"};
OBDuino.ino:770: error: 'prog_char' does not name a type
 prog_char *adjustMenu[] PROGMEM = {"Adjust menu", "Exit", "Tank Size", "Fuel Cost", "Fuel %", "Speed %", "Out Wait", "Trip Wait", "Tank Used", "Tank Dist", "Eng Disp", };
OBDuino.ino:771: error: 'prog_char' does not name a type
 prog_char *PIDMenu[] PROGMEM = {"PID Screen menu", "Exit", "Scr 1", "Scr 2", "Scr 3", "Big 1", "Big 2"};
OBDuino.ino:786: error: 'prog_char' does not name a type
 prog_char * tripNames[NBTRIP] PROGMEM =
OBDuino.ino:902: error: 'prog_char' does not name a type
 prog_char *econ_Visual[] PROGMEM=
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                from sketch\OBDuino.ino.ino.cpp:1:
Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'boolean get_pid(byte, char*, long int*)':
OBDuino.ino:1733: error: 'pid_reslen' was not declared in this scope
  reslen=pgm_read_byte_near(pid_reslen+pid);
OBDuino.ino:1815: error: 'pctldpcts' was not declared in this scope
    sprintf_P(retbuf, pctldpcts, *ret,
OBDuino.ino:2020: error: 'obd_std_strings' was not declared in this scope
       strcpy_P(retbuf, obd_std_strings[buf[0]-1]);
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'unsigned int get_icons(char*)':
OBDuino.ino:2299: error: 'pctspcts' was not declared in this scope
   sprintf_P(retbuf, pctspcts, decs,
Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'unsigned int get_cons(char*, byte)':
OBDuino.ino:2392: error: 'pctspcts' was not declared in this scope
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void get_fuel(char*, byte)':
OBDuino.ino:2432: error: 'pctspcts' was not declared in this scope
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void get_waste(char*, byte)':
OBDuino.ino:2470: error: 'pctspcts' was not declared in this scope
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void get_dist(char*, byte)':
OBDuino.ino:2508: error: 'pctspcts' was not declared in this scope
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void get_remain_dist(char*)':
OBDuino.ino:2556: error: 'pctldpcts' was not declared in this scope
   sprintf_P(retbuf, pctldpcts, remain_dist,
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void get_max_vss(char*, byte)':
OBDuino.ino:2586: error: 'pctldpcts' was not declared in this scope
   sprintf_P(retbuf, pctldpcts, maxspeed,
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void display_mil_code_count(char*, long unsigned int*, byte*)':
OBDuino.ino:2986: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_cls_print_P(PSTR("CHECK ENGINE ON"));
OBDuino.ino:382: error: initializing argument 1 of 'void lcd_cls_print_P(char*)' [-fpermissive]
void lcd_cls_print_P(char *string);  // clear screen and display string
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void check_mil_code(bool)':
OBDuino.ino:3060: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
       lcd_cls_print_P(PSTR("Error reading DTC"));
OBDuino.ino:3127: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
     lcd_cls_print_P(PSTR("Clear DTC?"));
OBDuino.ino:3139: error: 'noDTCcodes' was not declared in this scope
       lcd_cls_print_P(noDTCcodes);
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void clear_mil_code()':
OBDuino.ino:3181: error: 'noDTCcodes' was not declared in this scope
OBDuino.ino:3188: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_cls_print_P(PSTR("Clearing codes..."));
OBDuino.ino:3199: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_cls_print_P(PSTR("Codes cleared"));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'byte menu_select_yes_no(byte)':
OBDuino.ino:3285: error: 'select_no' was not declared in this scope
       lcd_print_P(select_no);
OBDuino.ino:3287: error: 'select_yes' was not declared in this scope
       lcd_print_P(select_yes);
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void config_menu()':
OBDuino.ino:3423: error: 'topMenu' was not declared in this scope
     selection = menu_selection(topMenu, ARRAY_SIZE(topMenu));
OBDuino.ino:3431: error: 'displayMenu' was not declared in this scope
         displaySelection = menu_selection(displayMenu, ARRAY_SIZE(displayMenu));
OBDuino.ino:3435: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("LCD contrast"));
OBDuino.ino:3446: error: 'pctd' was not declared in this scope
             sprintf_P(str, pctd, params.contrast);
OBDuino.ino:3458: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Use metric unit"));
OBDuino.ino:3470: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             lcd_cls_print_P(PSTR("Use comma format"));
OBDuino.ino:3486: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Fuel/hour speed"));
OBDuino.ino:3495: error: 'pctd' was not declared in this scope
             sprintf_P(str, pctd, params.per_hour_speed);
OBDuino.ino:3510: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Font type"));
OBDuino.ino:3519: error: 'pctd' was not declared in this scope
             sprintf_P(str, pctd, params.BigFontType);
OBDuino.ino:3536: error: 'adjustMenu' was not declared in this scope
       byte count = ARRAY_SIZE(adjustMenu);
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino:773:31: note: in definition of macro 'ARRAY_SIZE'
 #define ARRAY_SIZE(x) (sizeof(x) / sizeof(*(x)))
OBDuino.ino:3549: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Tank size ("));
OBDuino.ino:3559: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             lcd_print_P(PSTR("L)"));
OBDuino.ino:381: error: initializing argument 1 of 'void lcd_print_P(char*)' [-fpermissive]
 void lcd_print_P(char *string);  // to work with string in flash and PSTR()
OBDuino.ino:3564: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             lcd_print_P(PSTR("G)"));
OBDuino.ino:3622: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Fuel Price ("));
OBDuino.ino:3631: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
OBDuino.ino:3637: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
OBDuino.ino:3692: error: 'gasPrice' was not declared in this scope
             sprintf_P(str, gasPrice[fuelUnits > 999], decs);
OBDuino.ino:3721: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Fuel adjust"));
OBDuino.ino:3731: error: 'pctdpctpct' was not declared in this scope
             sprintf_P(str, pctdpctpct, params.fuel_adjust);
OBDuino.ino:3742: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Speed adjust"));
OBDuino.ino:3752: error: 'pctdpctpct' was not declared in this scope
             sprintf_P(str, pctdpctpct, params.speed_adjust);
OBDuino.ino:3763: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Outing stop over"));
OBDuino.ino:3785: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Trip stop over"));
OBDuino.ino:3808: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Tank used ("));
OBDuino.ino:3818: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
OBDuino.ino:3823: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
OBDuino.ino:3879: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Tank dist ("));
OBDuino.ino:3890: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             lcd_print_P(PSTR("KM)"));
OBDuino.ino:3895: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
             lcd_print_P(PSTR("M)"));
OBDuino.ino:3951: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
           lcd_cls_print_P(PSTR("Eng dplcmt (MAP)"));
OBDuino.ino:3986: error: 'PIDMenu' was not declared in this scope
         PIDSelection = menu_selection(PIDMenu, ARRAY_SIZE(PIDMenu));
OBDuino.ino:4012: error: 'PID_Desc' was not declared in this scope
               strcpy_P(strpid, PID_Desc[remap_pid(pid)]);
OBDuino.ino:4029: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
OBDuino.ino:4039: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
     lcd_cls_print_P(PSTR("Saving config"));
OBDuino.ino:4041: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
     lcd_print_P(PSTR("Please wait..."));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void trip_reset(byte, boolean)':
OBDuino.ino:4063: error: 'tripNames' was not declared in this scope
   sprintf_P(str, PSTR("Zero %s data"), (char*)pgm_read_word(&(tripNames[ctrip])));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void test_buttons()':
OBDuino.ino:4193: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
     lcd_cls_print_P(PSTR(" LCD backlight"));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void display_PID_names()':
OBDuino.ino:4229: error: 'PID_Desc' was not declared in this scope
       lcd_print_P(PID_Desc[remap_pid(params.screen[active_screen].PID[count++])]);
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void setup()':
OBDuino.ino:4314: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_cls_print_P(PSTR("OBDuino32k  v198"));
OBDuino.ino:4320: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
       lcd_print_P(PSTR("ISO9141 Init"));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void lcd_char_init()':
OBDuino.ino:4821: error: 'prog_uchar' does not name a type
   static prog_uchar chars[] PROGMEM ={
OBDuino.ino:4834: error: 'chars' was not declared in this scope
       lcd.write(pgm_read_byte(&chars[y*NB_CHAR+x])); //write the character data to the character generator ram
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void lcd_char_bignum()':
OBDuino.ino:4846: error: 'prog_uchar' does not name a type
   static prog_uchar chars[BIGFontFontCount*BIGFontSymbolCount*8] PROGMEM = {
OBDuino.ino:4880: error: 'chars' was not declared in this scope
       lcd.write(pgm_read_byte(&chars[params.BigFontType*BIGFontSymbolCount*8 + y*BIGFontSymbolCount + x])); //write the character data to the character generator ram
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void bigNum(char*, char*)':
OBDuino.ino:4926: error: 'prog_char' does not name a type
   static prog_char bignumchars1[40*BIGFontFontCount] PROGMEM = {
OBDuino.ino:4960: error: 'prog_char' does not name a type
   static prog_char bignumchars2[40*BIGFontFontCount] PROGMEM = {
OBDuino.ino:5011: error: 'bignumchars1' was not declared in this scope
         lcd_print_P(line==0?&bignumchars1[address]:&bignumchars2[address]);
OBDuino.ino:5011: error: 'bignumchars2' was not declared in this scope
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void eco_visual(char*)':
OBDuino.ino:5148: error: 'econ_Visual' was not declared in this scope
   sprintf_P(retbuf, PSTR("%s"), (char*)pgm_read_word(&(econ_Visual[stars])));
 Desktop\Arduino Tutorial\OBD Arduino code\OBDuino\OBDuino.ino\OBDuino.ino.ino: In function 'void save_params_and_display()':
OBDuino.ino:5213: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_cls_print_P(PSTR("TRIPS SAVED!"));
OBDuino.ino:4803: error: initializing argument 1 of 'void lcd_cls_print_P(char*)' [-fpermissive]
OBDuino.ino:5218: error: invalid conversion from 'const char*' to 'char*' [-fpermissive]
   lcd_print_P(PSTR("Wasted:"));
OBDuino.ino:4796: error: initializing argument 1 of 'void lcd_print_P(char*)' [-fpermissive]
exit status 1
Old 02-14-2016, 01:32 AM   #844 (permalink)
Anybody please?
I've re-read the whole thread but without any success.
Could it be related with the version of the IDE environment ? If so anybody have a clue where to get a hold of an older version ?
Best regards.
Old 02-14-2016, 03:49 AM   #845 (permalink)
I apologize, I am not a very useful person, but I hope that someone is able to help you.
Old 02-14-2016, 11:58 AM   #846 (permalink)
I hope so too
Old 02-14-2016, 12:10 PM   #847 (permalink)
MAF (mass air flow) compensates for pressure, temperature, humidity, and density.
MAP(manifold absolute pressure) only measures the difference between the current atmospheric pressure and the pressure of the air entering the cylinder.
Nissan went to MAF in 1984 with the then new 300zx in the USA. Heated wire in the incoming air stream with the resistance created by air particles passing over the wire precisely measured.
regards
mech
Old 02-14-2016, 12:16 PM   #848 (permalink)
Measuring only injector pulse width, in a system with a fuel pressure regulator that is typically vacuum controlled will not give you the required accuracy of the amount of fuel delivered.
In more modern systems, fuel pressure is regulated by controlling the voltage to the pump itself (Ford) but still receives input from the fuel pressure sensor, without vacuum control of the pressure used with earlier systems with a fuel return line from the pressure regulator back to the tank.
The Ford system had no return line.
regards
mech
Old 02-14-2016, 01:02 PM   #849 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I would beg to differ. I have found MPGuino to be a lot more accurate than either the OBDII-based scanners (to include ScanGauge II) or the on-board factory trip computers I have used. MPGuino measures fuel injector pulse widths directly.
Old 02-14-2016, 01:07 PM   #850 (permalink)
MPGuino Supporter
t vago's Avatar
You have to go through the entire OBDuino code and replace each and every instance of "prog_char" with "const char". That is a total pain in the neck, but it has to be done.
Code:
For instance, this wasn't changed, and it failed when the compile attempt was made.
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 02:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 05:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 05:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 11:04 PM
