Old 02-02-2013, 02:37 AM   #401 (permalink)
Just ordered from JBD, look forward to receiving it.
Old 02-02-2013, 02:45 AM   #402 (permalink)
meelis11's Avatar
Green frog - '97 Audi A4 Avant 1.9TDI 81kW
Diesel
90 day: 43.1 mpg (US)
Originally Posted by live4soccer7 View Post
Any advantages from buying mgpuino from one vendor or another?
Differences/extra features you can get with my custom code/hardware:
* added metric version (must choose before code/firmware uploading, no change possible in settings)
* bargraphs (shows 2min average 4-12L/100km - dropped 0-4L to gain better resolution)
* battery voltage
* trip cost (in settings you enter fuel price)
* current trip does not reset automatically after 2min engine off. Manual reset like tank trip.
* tank trip time in hours.minutes, current trip time is now available too
* saving tank trip data to eeprom (dont forget it when disconnected)
* some values are shown in integers (speed, rpm)
* removed leading zeroes (instead "012.45" shows " 12.45")
* added dragrace screen (0-100km/h time, 400m time and trap speed, calculated horsepower)
* using Atmega chip sleep mode (consumes about 5milliAmps versus 20milliAmps when in sleep)
* instant speed does not jump around - it means accurate speed and distance!
* small PCB so you can mount buttons separately (if buttons on top is not suitable)
http://mpguino.wiseman.ee/eng - get assembled mpguino from here!
Old 02-02-2013, 10:09 AM   #403 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
So would the bargraph not work for vehicles getting under 4.0 L/100km?
I'm putting money aside for an MPGuino, it will be my next purchase.
Old 02-02-2013, 02:44 PM   #404 (permalink)
JBD, what is the width and height of your MPGuino? I'm looking for a project box to fit it and my oil pressure gauge, so any kind of dimensions would be great.
Old 02-03-2013, 11:58 PM   #405 (permalink)
JellyBeanDriver's Avatar
ignoring the buttons coming out the top, and using a scale to measure,
Width is 3.15", height is 1.4"
Add another 0.1" all around for tolerance and you'd be safe.
1992 Geo Metro, 1.0L 5spd, 435,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- averaging 51.7 MPG, 56.9MPG best tank.
- self built MPGuino
- http://www.dschmidt.com/MPGuinoJBD.html
The Following User Says Thank You to JellyBeanDriver For This Useful Post:
Davinator61 (02-15-2013)
Old 02-04-2013, 12:14 AM   #406 (permalink)
Sweet, thank you very much. Can't wait to receive and install.
Old 02-10-2013, 05:01 PM   #407 (permalink)
How much, on average, are yous guys charging for one of these units? I'd like to EVENTUALLY order one of these for my 1991 Jeep Cherokee Laredo 4.0L with the AW4 Automatic Transmission, New Process Gear 242 Selec-Trac Transfer Case, Dana35 Rear Axle & Dana30 High-Cut Pinion Front Axle, so I can monitor my Current MPGs on long trips more accurately, as well as on my Daily Work Commutes.
This would be purchased once I've been able to do the GoJeep 20-To-25-Gallon-Fuel-Tank-Capacity-Increase-Mod on either my Factory-Original fuel tank, as is currently installed, or on an exact-fit OEM Replacement Fuel Tank from one of my after-market online sources, should the current FT need replacing due to serious dents, gouges, rust-out, etc., etc., etc.
Update: since I SHOULD be getting my IRS Refund by the end of the month, I've decided to purchase the MPGuino from JellyBeanDriver via his Web Page dedicated to THIS product, as DCB appears to no longer be handling the assembly and sales of said item. Hey, JBD, I'll send you a PM as soon as I've ordered, okay? Once I've received said unit I'll send you another, and then once I've installed and gotten it up and running, I'll PM you again as well as post my first impressions of this device on this thread. Here's hoping everything works out the way it was intended.../8/
Last edited by Davinator61; 02-10-2013 at 11:13 PM.. Reason: additional info added
Old 02-11-2013, 03:25 AM   #408 (permalink)
meelis11's Avatar
Diesel
Yes it does not show bar if consumption is under 4L/100km
I can always configure it to other values if user requests it. Defualt i 4-12L/100km or 18-58MPG
I have used 3-7L/100km too and then you can see 0.25L resolution instead of 0.5L
Meelis
Old 02-12-2013, 08:42 AM   #409 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Guys please help
I've made a temporary mpguino on a breadboard configuring to metric,
the thing is that some times it shows a consumption of 9.99 and all readings went crazy...
Also other issue how i am i going to calibrate it cause it shows pulses per mile and not pulses per Km the same is for Microsec per gallon...
and for last i can see some display flicker like on pc monitors when are configured with wrong refresh rate...
Version is V0.86 on a 16Mhz crystal
Old 02-12-2013, 09:02 AM   #410 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
There's a metric option in v0.86 code or you can use "Canadian" metric v0.81 code.
If you want to calibrate US version you just need to use conversion factors that you may find here: Fuel economy conversions / calculator - EcoModder.com
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
For Sale Preassembled MPGUINO NEW $45. randall OpenGauge / MPGuino FE computer 1 10-24-2009 04:13 PM
MPGuino, Preassembled BRAND NEW Sean T. For Sale 4 10-22-2009 07:00 PM
Brand New MPGuino Preassembled Sean T. For Sale 1 06-17-2009 01:02 AM
