Old 03-16-2015, 01:52 PM   #301 (permalink)
Dino - '93 Honda Civic DX
90 day: 43.65 mpg (US)
White Shadow - '15 Toyota Prius C Two
90 day: 50.69 mpg (US)
Only way I've successfully cut perfect circles was with a hole saw drill bit. When I cut a hole in my dash for my vacuum gauge I bit the bullet and just bought the right tool for the job And it turned out great.
Old 03-16-2015, 02:13 PM   #302 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Mark the outline of your hole, get it started with a hole saw, then grind/jigsaw/dremel/multitool the finish work.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
OG VX (03-16-2015)
Old 03-16-2015, 02:26 PM   #303 (permalink)
JDM hypeR mileR
OG VX's Avatar
The OG VX - '92 Honda Civic VX
90 day: 68.64 mpg (US)
Thanks for that info. Just went back and updated my post.
It's actually an obtuse, more oval shape, whole.
"Yesterday as I was going in to the shop, I came upon a recently killed Armadillo in the middle of the road with one front leg sticking up. As I passed over him he "High Fived" my air dam. I thought that showed a great attitude on his part." -The Donkey CRX
Old 03-16-2015, 03:43 PM   #304 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Go with Fat Charlie's method. Use a hole saw that will take out the most material easily then get in there with a diegrinder bit on the Dremel. Don't waste your time using cutting discs, just start chunking out metal and move slow so your don't "color outside the lines"
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
OG VX (03-16-2015)
Old 03-22-2015, 12:02 AM   #305 (permalink)
JDM hypeR mileR
OG VX's Avatar
Update 3/21/2015: Aero Work Continued...
Gorgeous weather here in NC today. Got a lot done.
Started by giving the car and OEM bra a good washing. Let the bra parts hang dry. After some degreasing and agitation with a toothbrush, the Civic embroidery on the bra looks as-new again.
Installed some visors I ordered off of Ebay. They'll be good enough for now, until I can source an OEM set in the (far off) future.
Some friends came over and helped me to hold the panels while I ran a few screws in. My first drill into the rear quarters was painful. There's no going back now!
There only a few screws holding on the panels, so fitment looks extra horrible. As you can see, there is LOTS of work still left to do on the rear end. I've got many hours ahead in fitment, trimming, shaping, drilling, sanding, etc... before paint work can begin on the panels and they can be ran on the street. I'll keep you all posted. So far, so good, however.
Finished off the day with some CF vinyl wrapping. I did the mirror block offs and the OEM antenna block in the vinyl tonight. Fun and easy work. Grille and fog covers will be done also, to match. They must, however, be painted first.
More to come soon. Thank you for eco-tuning in!
The Following 4 Users Say Thank You to OG VX For This Useful Post:
bluesteel93 (03-22-2015), pgfpro (03-22-2015), The donkey CRX (03-22-2015), vrmouseyd15b (03-22-2015)
Old 03-22-2015, 12:08 AM   #306 (permalink)
ALL UP ON THE INTERWEB!!!
vrmouseyd15b's Avatar
skidmark - super snail - '89 honda civic wagon WAGOVAN
Team "Old SKOOL"
90 day: 30.87 mpg (US)
Pituca - '19 Honda Insight Touring
90 day: 39.34 mpg (US)
That's sharp dude! I like the view from further back like that. The few buddies would make or break that one as far as lining it up, but you look spot on so far! Keep doing your thing- and post Lotsa pics. .
Thanks,
Victor
The Following User Says Thank You to vrmouseyd15b For This Useful Post:
OG VX (03-22-2015)
Old 03-22-2015, 12:26 AM   #307 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Looks great!!
I understand you on the hesitation. I did the same thing on my car once you start cutting and/or screwing there's no going back lol
Pressure Gradient Force
The Positive Side of the Number Line
The Following 2 Users Say Thank You to pgfpro For This Useful Post:
OG VX (03-22-2015), The donkey CRX (03-22-2015)
Old 03-22-2015, 03:11 PM   #308 (permalink)
bluesteel93's Avatar
Turtle - '94 Honda Civic VX
90 day: 48.37 mpg (US)
SVO - '86 Ford Mustang SVO
Team Turbocharged!
90 day: 22.03 mpg (US)
Looking good so far! Keep up the good work man.
Check out my Civic VX build thread here:
http://ecomodder.com/forum/showthrea...ild-30800.html
Old 03-22-2015, 03:54 PM   #309 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
That's great dedication. Hope it works out for you.
1998 LX with a full HX swap + VX transaxle.
Old 03-23-2015, 09:27 AM   #310 (permalink)
JDM hypeR mileR
OG VX's Avatar
Thanks fellas. Got my butt handed to me yesterday afternoon on the first rivet nut installations. Looks like I'll have to remove the hatch temporarily to install all the rivet nuts on the metal strip atop the OEM spoiler. The latches sitting underneath are effecting my ability to install the rivet nuts. I'll explain with pics later, once I (hopefully) "tame this beast".
