Old 03-16-2016, 12:20 AM   #2641 (permalink)
PaulH
MPaulHolmes's Avatar
Holy mackeral! A lot has happened in the last few days! I need to check in more often! I've been so busy with my job, I haven't been keeping up. Shaggy, could you tell us what the name plate says on your motor? It's a 3 phase motor? What is the kw rating? What voltage rating? What does
run-pi-test
do? does it just say the test failed? This is sort of hard to debug. There's a lot of unknowns.
kits and boards
Old 03-16-2016, 12:25 AM   #2642 (permalink)
PaulH
Originally Posted by tajman View Post
Also, is there still a way to contribute to the development? I saw there was a donation link very early in the thread but it doesn't seem functional anymore.
Tarquin.
YES!!! HAHA. you can send a donation to paulandsabrinasevstuff@gmail.com. Not to sound too needy or anything. LOL. (that was one of the kindest posts I've ever read. It was very encouraging! thank you!!) If you email me, I can send you all the schematic/pcb files. I need to post them to our website or something.
Also, yes, you can disable the resolver circuit on the new board by bringing the chip select pin high.
kits and boards
Old 03-16-2016, 01:14 AM   #2643 (permalink)
run-pi-test
Hello Paul the motor is 3 phase motor rated for 230v or 380v. I'm using the motor in 230v configuration and it has 8.4A nominal current and the power factor of 0.78.
When I run the pi test I can hear tick tick noise but the motor just remains blocked.. It does not rotates like in many videos that I have seen on thingstodo' channel during the pi test..
Would you please send me a code for pwm testing... Like driving the motor in open loop to be sure that pwm are OK?
Old 03-16-2016, 01:55 AM   #2644 (permalink)
PaulH
The PI test isn't supposed to move the motor. It's supposed to find the right Proportional and Integral constants that let Id and Iq converge fast to IdRef and IqRef. Does it say that the test was a success?
kits and boards
Old 03-16-2016, 02:00 AM   #2645 (permalink)
No it says pi test failed...
Old 03-16-2016, 02:14 AM   #2646 (permalink)
this is what i got...
run-pi-test
No values passed the test.
Try the following:
pi-ratio 63
run-pi-test
pi-ratio 64
run-pi-test
pi-ratio 65
run-pi-test
Just keep going. If nothing passes the test after you have tried pi-ratio all the way to, say, 200,
it may be that the PI test is too stringent for your motor. Email me at paulandsabrinasevstuff@gmail.com.
config
config
motor-type=1
kp=00062 ki=00001
current-sensor-amps-per-volt=0013
max-regen-position=0390
min-regen-position=0490
min-throttle-position=0510
max-throttle-position=0610
fault-throttle-position=0005
max-battery-amps=0008 amps
max-battery-amps-regen=0008 amps
max-motor-amps=008 amps
max-motor-amps-regen=008 amps
precharge-time=0005 tenths of a sec
rotor-time-constant=005 ms
pole-pairs=001
max-rpm=03000 rev/min
throttle-type=1
encoder-ticks=2048 ticks/rev
pi-ratio=062
raw-throttle=0499
Old 03-16-2016, 10:43 AM   #2647 (permalink)
PaulH
What is your DC input? Do you have current sensors on all 3 lines? Try changing this piece of code:
Code:
				if (myPI.error_q < -120/*-80*/) {  // if it overshot the target by 80, move on to the next one.  We don't want overshoot.
					MoveToNextPIValues();
				else if (myPI.error_q > IqRef + 200) {  //  IqRef is a constant 511.  If Iq swung to -200, that's bad.  Move on.  Iq shouldn't go below zero much.
				else if (myPI.zeroCrossingIndex == -1 && myPI.iteration > myPI.maxIterationsBeforeZeroCrossing) {  // myPI.zeroCrossingIndex == -1 means it hasn't crossed zero yet.
					MoveToNextPIValues();  // CONVERGENCE TOO SLOW!!!  Move on!
				else if (myPI.error_q > 120/*80*/ && myPI.zeroCrossingIndex >= 0) {  // it already crossed zero, but now is way back up again.  This is oscillation.  move on!
Where it says -120 and 120, change those to -200 and 200. Maybe the noise on your current sensors is higher.
Also, find this piece of code:
Code:
void InitPIStruct() {
	myPI.Kp = (long)savedValues.Kp;
	myPI.Ki = (long)savedValues.Ki;
	myPI.error_d = 0l;
	myPI.pwm_d = 0l;
	myPI.errorSum_d = 0l;
	myPI.error_q = 0l;
	myPI.pwm_q = 0l;
	myPI.errorSum_q = 0l;
	myPI.testFinished = 0;
	myPI.testFailed = 0;
	myPI.testRunning = 0;
	myPI.ratioKpKi = 62; //savedValues2.ratioKpKi;
	myPI.zeroCrossingIndex = -1; // initialize to -1.
	myPI.iteration = 0; // how many times have you run the PI loop with the same Kp and Ki?  This is used in the PI auto loop tuning.
	myPI.maxIterationsBeforeZeroCrossing = 20; //20
	myPI.previousTestCompletionTime = counter10k;
and change myPI.maxIterationsBeforeZeroCrossing to maybe 100. If you can't get the PI loop tuned, nothing is going to work. The goal right now is to just get the test to pass, and then slowly make it more restrictive.
kits and boards
Old 03-16-2016, 10:51 AM   #2648 (permalink)
Code:
Code:
	myPI.error_d = 0l;
	myPI.pwm_d = 0l;
	myPI.error_q = 0l;
	myPI.pwm_q = 0l;
Hello my bus voltage is outlet 230vac rectified... But I'm using 300 watt bulb in series with an input.. To be sure if there is some problem they will protect my hardware
I will do these modifications and let you know if it works..
Another question after pi tuned it can work with encoder disconnected?
Thanks again Paul
Old 03-16-2016, 11:02 AM   #2649 (permalink)
PaulH
So, the DC has a 300w bulb attached? It's not going to work. The current is going to be +/- 1 amp at its absolute maximum. But the controller commands current rather than voltage. And the DC input is going to vary all over the place. It would be much easier to test if you just used maybe 4 12v lead acid batteries for your DC input. The encoder is required with this code.
kits and boards
Old 03-16-2016, 11:25 AM   #2650 (permalink)
The encoder is attached in series with Ac input not in series with DC bus voltage...
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
