08-03-2010, 11:42 PM
#3621 (permalink)
PaulH
I checked out the LEM current sensor with 3 wraps of wire around it. I measured the current with a 200amp 200mV shunt, and with a Fluke 337. The fluke 337 gives identical results as the shunt! 17amps on the fluke, 17mV across the shunt! They don't mess around at Fluke!
So, since I'm using a LEM 50, with 3 wraps, it should behave like a LEM 16.666666667, which is 50/3 HEHE. So, according to the datasheet, 16.666667 amps on the charger should result in a reading from the LEM of 512 + 128. Know what it was? 512 + 128. Ya. Perfectly accurate. That's what I"m talking about. The Japanese make some good stuff.
So anyway! I'm ordering those 1000amp control boards. Friggen heck ya! Does anyone want to buy one so that I don't go broke in the process? I am praying that there are no mistakes. There probably aren't since much of the circuitry is so similar to the charger I recently made, and that works perfectly. The few minor mistakes that the charger had, I already fixed on the control board layout for the controller. The control boards are going to be around $29 each before tax and shipping (I'm ordering 10), so probably $35 each would cover the cost of them. If I can get like 3 or 4 people, I can afford the rest. The software is actually mostly done, since it's SOOOOO similar to the charger. The same microcontroller. The dsPIC30F4011. All the chips are throughhole, so you can socket them, and all the resistors and capacitors are surface mount. 0805 and 1206 package resistors and capacitors. It's actually easier than through hole soldering once you get used to it. All you need is some solder flux. I can explain how if anyone needs help (or watch youtube video. haha. That's where I learned how).
08-04-2010, 12:15 AM
#3622 (permalink)
EV test pilot
Hey Paul!
I'll take one of those Killa-Amp boards.
Do you want to set up something through the PaulandSabrinasEVStuff order page, or do something else for ordering one?
08-04-2010, 12:55 AM
#3623 (permalink)
PaulH
I was hoping that only extra special people that know just how prototypish it is would buy them. Sort of ecomodder in-house. Where all the peeps hang. Sabrina is going to post a super secret ordering page on the website. then, anyone that wants the link to the super sneaky page can get it! Just email us, and we'll send you the link. Our email for this sneakiness is paulandsabrinasevstuff@gmail.com. So I guess it's not too secret, since anyone can go there. hahaha. She's going to set it up tonight.
08-04-2010, 02:52 AM
#3624 (permalink)
Sign me up!
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
08-04-2010, 05:24 AM
#3625 (permalink)
Must discuss with my compadres; I may be able to be counted in.
08-04-2010, 06:43 AM
#3626 (permalink)
I'll take one .
08-04-2010, 07:55 AM
#3627 (permalink)
AC-DC enthusiast
Control Board
Hi Paul, I want to preorder one "Control Board". How can I do this.
Thank you
Horacio
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
08-04-2010, 08:14 AM
#3628 (permalink)
Paul,
What are the features of this control board?
What is the firmware? Did you port the cougar firmware to the dsPIC?
-Adam
08-04-2010, 08:16 AM
#3629 (permalink)
ReVolt Enthusiast
Hi Paul,
I too, would be interested in one of your 1000amp control boards !!!
Thanks,
-Mark
08-04-2010, 09:39 AM
#3630 (permalink)
I've been reading, but must've lost track. What is the difference between this new board and the Rev C board? Synchronous rectification? PIC instead of atmega?
Will this one require more expensive components to populate? Does it work with the same power board that only gives you 500 amp (obviously not resulting in a 1000amp controller)?
