Old 05-30-2013, 11:12 AM   #6141 (permalink)
PaulH
MPaulHolmes's Avatar
Power into the motor is approximately power out of the motor (except for losses), so...
1) BatteryCurrent * BatteryVoltage = MotorCurrent * MotorVoltage.
Now,
2) MotorVoltage = BatteryVoltage * PWM_DUTY
Let's substitute 2 into 1:
BatteryCurrent * BatteryVoltage = MotorCurrent * (BatteryVoltage * PWM_DUTY)
Now, cancel BatteryVoltage from both sides of the equation, to get....
BatteryCurrent = MotorCurrent * PWM_DUTY.
Or, said another way,
BatteryCurrent / MotorCurrent = PWM_DUTY
So, if you only know the PWM_DUTY, there are still 2 other variables. You can't know both the battery current and the motor current if you only know the pwm duty.
Hey! It has over 1 million views! I was hoping it would roll over to zero, and there'd be a y2k catastrophe. oh well.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
cyrusamory (05-30-2013), thingstodo (07-06-2013)
Old 05-30-2013, 11:36 AM   #6142 (permalink)
Originally Posted by MPaulHolmes View Post
Yes, it's just a single line of code to go up to maybe 900 amps. Well, or maybe 2 lines. I forgot...
Thanks! I tried to dig into code (being a beginner means it's like deep water diving) and I understand that these mentioned lines simply change translation of LEM signal onto current_fb; so for example current_fb=500 means ~600A real; to get rtd_explorer displaying proper values we'd need to modify either rtd_explorer or cougar's output datastream?
Old 05-30-2013, 12:11 PM   #6143 (permalink)
PaulH
Oops. Yes! That's exactly right. 0 to MAX_CURRENT would be 0 to 500 (or 511 haha)
The code on the chip would have to do a multiply by 600/500 before displaying it.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
z_power (05-30-2013)
Old 05-30-2013, 12:48 PM   #6144 (permalink)
EVVette - '71 Chevy Corvette Coupe
RTD Explorer filters incoming data with a REGEX. I would have to check it and make sure it can take a larger value, but I think it is just looking for format. Which means any current up to 999 would be ok.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
Old 05-31-2013, 12:54 PM   #6145 (permalink)
jackbauer's Avatar
Re-moc progress. Getting to like those C4DE caps .........
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 3 Users Say Thank You to jackbauer For This Useful Post:
adamj12b (05-31-2013), MPaulHolmes (05-31-2013), thingstodo (07-06-2013)
Old 05-31-2013, 01:15 PM   #6146 (permalink)
Originally Posted by jackbauer View Post
re-moc progress. Getting to like those c4de caps .........
that is awesome!
Old 06-02-2013, 12:35 PM   #6147 (permalink)
jackbauer's Avatar
Re-moc is alive! Video uploading .........
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
MPaulHolmes (06-02-2013), thingstodo (07-06-2013)
Old 06-02-2013, 01:32 PM   #6148 (permalink)
PaulH
Oh heck ya! Hurry up and upload, you stupid computer!!!!! I just about have to leave. dang it. I'll get that code changed too so that it shows the actual amps instead of the scale of 0-500.
kits and boards
Old 06-02-2013, 03:22 PM   #6149 (permalink)
SEBART PL's Avatar
...where is this video , please? ( I have checked your youtub profile but is not there)
After my second set of mosfet failed, I have decided to put more of them in TO220 case
- I want to change IRFP4668PbF for irfb4115gpbf (150V 11mohm 70A ) 22 pieces
1. I want to ask is mic4451YN can manage those 22 mosfets? And do I need to change resistors gate parametrs ?
Data S:
mic4451YN http://www.micrel.com/_PDF/mic4451.pdf
MOSFET Ciss Input Capacitance ––– 5270 ––– pF x22=115940 pF
mic load drive is 62000 Pf looks it is not good
or I need to check just Gate-to-Source Forward Leakage it is 100nA and mic can work on 2A - I am not so sure is this is OK.
2. What about resistors, have they need to be amended?
3. Another important question I aware my fail could happened becouse of spikes from motor could produce over voltage - can I protect my controler with some kind diode or transil installed on motor? (Motor parametrs 80V 200A 13.5 KW DCseries)
For any help thank you in advance.
Old 06-03-2013, 05:24 AM   #6150 (permalink)
Me Again
Looking at the spec sheet for the IXYs mosfet, It appears to have a Diode integrated into the device between the drain and source, could this replace the freewheel diode? here is the spec sheet.
http://ixdev.ixys.com/DataSheet/DS10...FX230N20T).pdf
Thankyou again
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
