Old 01-25-2009, 12:51 PM   #291 (permalink)
PaulH
MPaulHolmes's Avatar
Make sure you get an emergency disconnnect switch at least for during testing, since mosfets fail short circuited. I'm not saying there will be a problem, but you know, just to be safe. haha!
kits and boards
Old 01-25-2009, 01:37 PM   #292 (permalink)
A picture of a giant frankenstein circuit breaker mounted to the dash just popped into my head
Old 01-25-2009, 01:41 PM   #293 (permalink)
PaulH
haha! That would be perfect. Ben, you should add one of those. That could be the contactor. Each time the switch closes, an evil recorded laugh should play over the car's speakers. It would really scare passengers.
kits and boards
Old 01-25-2009, 02:41 PM   #294 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Heck, if my wiring doesn't scare passengers, nothing will....
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-25-2009, 07:47 PM   #295 (permalink)
PaulH
I uploaded the text file of the coordinates of where to drill through the PCB, and where to etch it. One picture is for the bottom side, where the capacitors get soldered, and the other picture is for the top side, where the mosfets/diodes get soldered.
The JPG files are set up so that if you print them, they will be the exact size of a 8"x7" PCB. It's possible to use a 8"x6" board with some of the capacitors hanging over the edges at the top and bottom. I might do that, but then the coordinates would need to be shifted up a bit if you are doing some sort of CNC milling. If you are just pressing the ink directly onto a PCB, then who cares! haha!
The squares in the second picture mean that you have to shave off ALL OF THE COPPER INSIDE THOSE SQUARES! YUCK! That's the trials of using 2 sided PCB!
The third picture you can use if you aren't using 2sided PCB. You can avoid all that dang shaving of copper! That sounds good!
Here's a cool utility that I've found useful! This Circuit Width Calculator and it seems to be OK with 3 ounce copper, as long as you aren't drag racing at 1000 amps or something, so I think 3 ounce will be fine.
Name:	144v 500amp controller layout BOTTOM JPG.jpg
ID:	2617   Click image for larger version
Name:	MosfetDiode Board Layout 2 SIDED PCB JPG.jpg
ID:	2624   Click image for larger version
Name:	MosfetDiode Board Layout JPG.jpg
File Type: txt 144v 500amp controller layout BOTTOM TEXT FILE.txt (1.5 KB, 271 views)
kits and boards
Old 01-25-2009, 09:48 PM   #296 (permalink)
Great Success On This Open Source Forum
I have just finished reading all of the links on the design and implementation of this motor controller and am thoroughly impressed. We are also working toward open source designs and will post our progress on chargers.
Old 01-25-2009, 10:24 PM   #297 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Paul,
I weight tested my Metro today with 144V of batteries in it.
The brakes are fine with it, but the suspension isn't happy.
120V of batteries is better. I will be able to do 12 batteries if I put in some beefier rear suspension and shift more of the weight to the front.
Neon Tom also has plenty of matched small batteries I could use to build a custom lower amp/hr higher voltage pack for testing the controller.
My YouTube Videos
Old 01-26-2009, 08:30 AM   #298 (permalink)
EV Novice
nickfarmer's Avatar
Peugeot 306 EV - '95 Peugeot 306 XL
Great project.
I will look forward to using it in my EV, I'll start a build thread when I get the car (hopefully next week).
Old 01-26-2009, 09:03 AM   #299 (permalink)
PaulH
That's awesome, Dan! Thank you! We need a good cheap charger.
kits and boards
Old 01-26-2009, 09:43 AM   #300 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I love it: mosfet Emma, Jake and Little Miss Muffet. Be careful!
I test fit only 2 more (EDIT - correction ... 4 more) 6v floodies in the back of the ForkenSwift, and it wasn't happy on the stock suspension:
Can you say SQUAT! Click in, it's pretty funny in the big image.
But Ivan and I both agree we don't want to give up the rear seat.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
