Old 07-01-2012, 08:58 PM   #11 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
Originally Posted by t vago View Post
What caused the improvement? Removing the cold air inlet? Removing the resonator? Changing from a probably dirty filter to a likely clean filter? A combination of all 3 actions? What?
So.... in other words, you don't know whether IAT has changed.
The EPA has done studies and found out that a dirty filter affects power not FE
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
But changing out the OE tiny little air tubes for the cold air intake vast gaping cavity vastly improved airflow. So more air means better volumetric efficiency. And if you P&G, more power means getting to speed sooner, which translate to more gliding and less pulsing.
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 07-02-2012, 12:31 AM   #12 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
This mod only helps FE if you're using fuel line magnets.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
The Following 2 Users Say Thank You to Mustang Dave For This Useful Post:
aerohead (07-03-2012), mcrews (07-02-2012)
Old 07-02-2012, 02:00 AM   #13 (permalink)
It will help if it changes the MAF signal in the right direction. Aside from turbulence factors, air filters sometimes cause the engine to lean out slightly, as the ECU is receiving more air than it thinks it's receiving.
Air filters can and sometimes DO change economy. The problem is they usually do so for reasons that have nothing to do with the filter media and everything to do with the shape of the filter and the filter installation.
Old 07-02-2012, 02:34 AM   #14 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Until 0.0000001 seconds later when the ECU sees the O2 sensor value change and makes a fuel trim correction, netting absolutely no A/F difference at all.
The Following 2 Users Say Thank You to mechman600 For This Useful Post:
aerohead (07-03-2012), TEiN (07-04-2012)
Old 07-02-2012, 07:23 AM   #15 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Someone posted that he saw an mpg gain from this on a forum dedicated to the Focus...took me a long time to try it due to believing it had little chance of working. I already had what I thought was a good flow...don't exactly run the car a full throttle a lot...taxing the intake system. You can buy these cone filters at parts stores for not too much (the off brands)...installing it like I did means it is easily reversible.
All the brilliant analysis as to why it won't work is FUNNY. Just like watching people TAKE A DUMP.
cons? Noisy if you floor it...not the best filtering in a dusty area?
I wouldn't want to encourage anyone to improve their mpg...it's like pushing drugs.
Originally Posted by HydroJim View Post
Please do more testing because if this is true, I'll have to install one of these on my focus.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 07-02-2012, 07:26 AM   #16 (permalink)
It depends on the car and the filter. It is not that instant, as it requires the O2 readings to wander significantly in closed loop running. Won't affect idle, WOT or anything else, not unless the discrepancy is so big it throws the long term fuel trim completely out of whack and the car starts to adapt over the next few hundred miles.
And even then, with the limited fidelity of narrowband O2 sensors that come on most cars as stock, sometimes, the car can't adapt. Or, it maladapts, which is how the Mazdaspeed brand CAI causes CELs on the Mazdaspeed3 and 6, and how certain cheap aftermarket filters with MAF adapters cause Subarus to blow up.
The better modern brand name filters and CAIs are tested extensively to ensure they don't cause the LTFTs to wander, even when they lean out the intake charge.
Old 07-02-2012, 08:04 AM   #17 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
look, you have 281 posts, so you have been here awhile.
Let me be blunt.
you'tr not a neebie.
post up an aba test or take the wrath you have coming.
What's funny is your clueless post.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-02-2012, 08:18 AM   #18 (permalink)
Well...you can't have it both ways? Time will tell...no point in arguing about it.....
1st tank I thought it was a refill issue...but gas gauge is accurate at 1/2 tank mark vs trip meter....looking like the gain will stick.
I do A-B tests only.
I'm not a newbee...but I am clueless!
Let me be blunt.
Old 07-02-2012, 09:41 AM   #19 (permalink)
90 day: 51.82 mpg (US)
mcrews is referring to this idea:
http://ecomodder.com/forum/showthrea...ery-11445.html
(Members who have been around here a while should by now expect skepticism in proportion to the validity of the testing method used.)
Old 07-02-2012, 10:20 AM   #20 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I'm not saying that you didn't get a 6% improvement because of your filter.
I'm saying that you have no clue how your filter installation caused that 6% improvement. Furthermore, I'm saying that your guesswork (you did say "IAT is probably close to the same as before...around 10F higher at 70F...3-4F higher at 90F vs ambient....so it's not likely a warm air issue.") isn't helping matters any.
You need to be more rigorous in your statements. It's fine that you make initial observations, but you need to be able to back them up with verifiable data. Otherwise, as another poster pointed out, you might as well be installing fuel magnets.
The Following User Says Thank You to t vago For This Useful Post:
mcrews (07-02-2012)
