Old 09-25-2012, 10:09 PM   #121 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
good job,fair price. I hope . like to see you in the 10s at least
Old 09-25-2012, 11:50 PM   #122 (permalink)
Yea those 4.10 gears are killing the MPG's. The new gears/rear center section would pay for itself in no time. What about the one your friend had in the Ambulance?
94 Geo Metro 52-56 MPG
06 Jetta TDI 46-48 MPG
Old 10-01-2012, 11:33 AM   #123 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Hi guys,
Had my big interstate road trip over the weekend, before i left i made up a quick air dam.
Some garden edging from the local hardware store as well as aluminium U section:
Screw it all together:
Add some brackets on the sides to bring it out level with the tires:
and paint it black:
The bottom of it is about level with the lowest point on the front suspension and the butt-dyno says its helping aero quite a bit
First fill before the road trip got me a new PB of 9.48 mpg, most of that tank was done without the air dam. The fill halfway along the road trip i got a massive 10.6mpg! there was a decent tailwind most of the way which obviously helped as well as the air dam and a couple of long EOC's.
For the second leg the wind died down and there wasnt any decent hills for me to do good EOC's down so i mainly used DWL and a little bit of drafting, the average speed was probably around 90-95kmh for the whole trip. The second leg as well as 2 days of pottering around the town at the end netted me 9.63mpg, and the same trip on the way home with similar conditions i got 9.66mpg. Still yet to fill up again for the 4th leg after getting home.
Oh yeah i also forgot to show you guys my new batteries, tray welded up and painted:
Batteries, buss bars and wiring mounted:
2 part terminal cover started:
and finished:
there are tools in holes in the sides of the terminal cover (in the purple section) to change the main fuses under the bonnet as well as remove the terminal cover.
Thanks for looking
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 10-04-2012, 05:55 AM   #124 (permalink)
Aero + Tuneup = New PB!
Hi Guys,
Just filled up my last tank from the return trip of the journey, back up to 10.14mpg! a couple of downhill EOCs pushed me back over 10 i think, hopefully i can keep it up around town
Heres a few pics from the road trip:
Thanks for looking
The Following User Says Thank You to bobo333 For This Useful Post:
HHOTDI (12-13-2012)
Old 10-04-2012, 09:58 AM   #125 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
The 4.10s are definitely doing you in. Does the truck have overdrive/
Old 10-04-2012, 12:35 PM   #126 (permalink)
Fat free ranch for life!
Ultra-Orange's Avatar
Ecno-bubble - '96 Geo Metro Base
love your work!
The kick panel on the drivers side looks awful close to the gas pedal. Id be worried about putting my foot through the speaker, Your foot rub at all?
Not to beat a dead horse (Get on there! Whack! Whack!) But with the bed cap I doubt your going to be hauling more than a few hundred pounds. If your not going to be hauling loads of gravel or bed fulls of construction supplies the 4:10 gears are hurting you. Id suggest looking for a similar width car rear end with some highway gears, (2.74 or so). Many custom shops make custom universal joints for these applications.
Old 10-04-2012, 01:24 PM   #127 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
With that engine, and your aero mods, you should be able to gear it for about 1500 RPM at 60 MPH. Possibly even 1400 RPM if you are good at DWL. That plus making sure that the carburetor is giving the right F/A ratio should push your mileage to close to 20 MPG.
Old 10-04-2012, 08:51 PM   #128 (permalink)
Thanks guys,
Im still saving for new gears, being such a popular diff they are quite expensive here, even from the wreckers they wanted $400 for a used center with a different ratio, then i still need to rebuild it with new seals and fluid and put it in
There is no overdrive which makes things worse, i have looked into getting taller tires to help out until i can afford a new diff center but tires this size are also quite expensive
I havnt yet kicked the speaker on the drivers side (there is about an inch and a half to the pedal) but i am working on a grill to put over it just in case.
Thanks for looking
Ultra-Orange (10-05-2012)
Old 10-22-2012, 01:35 AM   #129 (permalink)
Haven't heard from you in a while bobo, any updates?
Old 10-22-2012, 06:38 AM   #130 (permalink)
No updates on this really, i have been busy with other projects and havnt done much driving lately so i havnt even refilled it recently (yay!) the next fill will be a bit screwed up though because the LPG solenoid died halfway though the tank so i had to use gasoline for a couple of days.
Dad cleaned out his shed the other day though and found something that might interest you guys...
Its a chinese 49cc 2 stroke designed to mount onto a pushbike, unfortunatly going through my pile of old bike parts i dont have a frame that it fits in so il have to find one for it, the plan is for a board track racer style bike to do local trips where i dont need to carry much with, similar to this:
i took it all apart the other day and made sure everything inside is in order, re greased and lubed it all and filed out the intake and exhaust flanges to promote a bit smoother flow in and out of the motor:
Thanks for lookin
