Old 08-13-2012, 08:10 PM   #51 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
I got most of the wiring done except for the side markers lights and the extra brake light because those have to be done later when I get the window and some skin on.
It's a little sloppy, but it works and that's all that counts.
I ran into a little problem because on the Ford Focus, the tail lights bulb only has 3 wires which means the STOP/TURN function share the same wire. Since I decided to have independent turn signal lights, I can't use a signal with a STOP function because all brake lights have to be red not amber. I plan on tapping into the signal under the dashboard near the steering column.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 08-13-2012, 08:37 PM   #52 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
see if your car has a trailer adapter kit, that should separate out what your need.
Old 08-13-2012, 09:18 PM   #53 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Originally Posted by HydroJim
The only 16 year old in the world interested in ecomodding.
False! I started to be an Hypermiler and to aknowledge ecomodding at 15! Now I am 17 and I am still in it! Same for Echo-Francis
BTW : great project!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 08-13-2012, 09:57 PM   #54 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
If the wire doesn't work, you'll have to change the amber lights to red. I wonder if you could tie into the front turn signal wires.
- Tony
Old 08-13-2012, 10:25 PM   #55 (permalink)
HydroJim's Avatar
There is a trailer kit, but it's $60 and still doesn't give an independent signal for the turn signal.
Old 08-13-2012, 10:26 PM   #56 (permalink)
HydroJim's Avatar
Look's like I'll have to change it to "One of the only 16 year olds in the world interested in ecomodding."
Old 08-13-2012, 10:28 PM   #57 (permalink)
HydroJim's Avatar
My first consideration was to tie into the front turn signal wires, but I'm not sure how I could get the wires to the back of the car very easily.
If anyone has any ideas on how to do that, let me know. All of my interior from the front seats back is removed so I'm not really worried about looks.
Old 08-14-2012, 05:42 PM   #58 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Run the wires under the carpeting. If you have an electrical diagram, you can probably pick out the wires by color under the dash.
- Tony
Old 08-14-2012, 09:20 PM   #59 (permalink)
HydroJim's Avatar
Finally finished up the wiring for the most part. All the lights are operational and everything outside of the hatch is in place. Inside the car I have some finish work to do, but I'm happy with the way this came out.
Instead of finding the wire under the steering column as planned, I ran wires straight to the front turn signals. The reason I didn't is because my chilton manual said the wire was green w/ yellow and when I got under the dash, I found 6 green w/ yellow wires and couldn't find my 12v test light to make sure I had the right one. I may switch it in the future because the way I ran the wires out of the engine compartment isn't the best and I'm worried the wires may snag or chaff causing a short. For now though, it's good. I'll have some more pics of the installation up tomorrow.
Now that I've got the wiring issue worked out, It's time to finally get to the window and coroplast skin. There should be a lot of progress tomorrow.
Old 08-15-2012, 10:16 AM   #60 (permalink)
HydroJim's Avatar
I got the window on this morning. I used very thin acrylic because it was the cheapest thing at Home Depot in the right size. I may switch it out in the future because there were a few cracks and I assume they'll get worse in the weather.
I also finished most of the left side of the coroplast skin. I'm having a little problem with the gap between the body and the hatch, so I'll have to come up with something for that.
everything would have been so much simpler if I didn't go for functionality of the hatch...
The Following User Says Thank You to HydroJim For This Useful Post:
Weather Spotter (08-15-2012)
