Old 08-16-2012, 11:33 AM   #71 (permalink)
90 day: 51.82 mpg (US)
Agreed - you're admirably brave for a teenager! I seem to remember everyone (self included) being overly preoccupied with what everyone else might think at that age.
Question: you don't have a fuel log here (doesn't mean you don't keep records). How are you going to be able to determine the tail's effect on MPG? Of course, if it's close to "the template", we know it'll be an improvement regardless.
Old 08-16-2012, 11:46 AM   #72 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Keep up the good work.
It looks like you've rediscovered the 1964 Shelby Daytona coupe rear end. It was an outstanding design, allowing the Shelby Daytona to achieve higher top end speed on the Mulsanne straight at Le Man with a carbureted 289 than the 427 powered Fort GT or the competing Ferrari.
I say if you find a good horse, ride it.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 08-16-2012, 03:07 PM   #73 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
WD40- Thank you very much
MetroMPG- I actually just started driving recently. I can pretty much bike anywhere I need to go so i havent used much fuel. You're probably wondering why I have a car and did these mods? My mom is going back to school for nursing and she's going to be busy all the time, so I got the car pretty much for baseball and fun. I go out of town a lot for baseball so I figured it wouldn't hurt to save some money going there.
With my estimated miles per year of $2,500, it'll take me 2 years to pay for all my mods. Which isn't too bad with such low mileage. Most of all, the project was a lot of fun. Not necessarily "worth-it" in my case, but I'll know how to do it to my commuter car when I'm older
Big Dave- I can definitely see the similarities between the shelby and my car. I just wish I had all that horsepower...
The moment you have all been waiting for:
There are still many hours ahead of me finishing, sealing, and painting the tail, but for now, I consider the project mostly complete. I can't wait to take it for a test drive as soon as I figure out a way to seal the boat tail to the car.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following 13 Users Say Thank You to HydroJim For This Useful Post:
Cd (08-16-2012), CigaR007 (08-18-2012), echo-francis (08-16-2012), euromodder (08-16-2012), HyperMileQC (08-16-2012), JethroBodine (08-16-2012), landsailor (09-01-2012), NachtRitter (08-20-2012), NeilBlanchard (08-16-2012), Pawtuckett (08-28-2012), Phantom (08-18-2012), Sven7 (08-17-2012), Weather Spotter (08-16-2012)
Old 08-16-2012, 03:36 PM   #74 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
As for how i attached the foam. I used the pre glued stuff so that tool care of one side, the other I used caulk and epoxy to attach it to the car.
In your case I would try hot melt glue (glue gun) it will stick to the plastic and the foam yet be removable if needed.
from the pics it looks like you got some wrinkles in the coroplast, how much tension is on those?
How is the rear view out the back?
Old 08-16-2012, 05:07 PM   #75 (permalink)
Hot glue may melt in direct sun.
Old 08-16-2012, 05:21 PM   #76 (permalink)
Wiki Mod
so only use it on the inside. use caulk on the out side.
Old 08-16-2012, 05:47 PM   #77 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
You can't really seal it if you want to be able to open the hatch.
Duct tape would do it, temporarily, but the hatch would be shut.
* Make a shallow wedge, just a little bit taller than the spacing between the car's body and the boattail, and tightly stick it onto the car body , directly in front of the gap.
* Rubber seal around the front end of the boattail, if you can find something suitable that closes the gap.
Old 08-16-2012, 09:15 PM   #78 (permalink)
Cd
Ultimate Fail
Cd's Avatar
[IMG][/IMG]Great job ! ( and so quickly too ! )
Looking more and more like the Daytona :
Old 08-16-2012, 09:42 PM   #79 (permalink)
HydroJim's Avatar
weather spotter- If my first idea doesn't work I'll probably have to end up going your route. I may also eventually drop my goal of having hatch functionality because this thing is HEAVY and I don't think it's going to be easy to seal this gap and allow the hatch to be open and closed. As far as the wrinkles in the coroplast goes, I'm not really sure what the negative of having those is besides appearance?
euromodder-I may have to take a trip up to the autoparts store and see what the have, but in some places where the body panels switch over, the gap becomes as 1" high so it's very hard to find something that will work.
Cd- I may have the add a daytona type spoiler to get the last 12 inches of my boat tail to line up with the template. I'll see what tuft testing tells me, but for now I'm not worried about it.
Here is a photo of the process I'm using to seal the gap. The metal part is 3 inch wide 26 gauge galvanized steel that is bent at a angle so the the leading edge touches the body of the car. Then, I added 1/4" rubberized foam weatherstrip to protect the car's body and allow the metal to make better contact with curving body panels. There are still some gaps, so I'm hoping my metal pieces don't become huge metal air flaps when I get up to highway speeds.
Here is a photo of the process I'm using the seal the gaps between coroplast panels. On the left is what the seam used to look like. On the right is what it looks like after I'm done. The finish should be better after I paint the tail. The technique is being called "heat gun viola"
Steps:
1. Prepare "Heat Gun"
2. Power on Heat gun and point at seam.
3. As coroplast begins to flex, bubble up, and melt pull heat gun away
4. As soon as possible, press a flat sheet of metal against the seam.
5. Let cool and...
6. "Viola!" a smooth water tight seam.
Oh, I also checked out my tail lights for the first time at night. All I can say is WOW! I'm sorry for whoever pulls up behind me because these are BRIGHT. I may add lights on the mirrors because from behind I appear narrower than I actually am.
Tail lights in action. I have the blinkers flashing for effect
The Following User Says Thank You to HydroJim For This Useful Post:
Cd (08-16-2012)
Old 08-16-2012, 10:21 PM   #80 (permalink)
This is a good idea. Also, because the lights are closer together than normal, a following driver may also think you're further away than you really are. Mirror mounted lights will help address this. (Basjoos' Aerocivic was struck from behind on the highway once at night, if I recall.)
