Old 09-10-2012, 08:21 PM   #161 (permalink)
Coroplast Engineer
slowbro's Avatar
AV - '04 Chevy Aveo sedan - not LS
90 day: 34.28 mpg (US)
Jolteon - '00 Honda Insight MT
90 day: 77.25 mpg (US)
When I brought up the comment about the tire contacting the skirt, I was talking about the tire contacting the METAL STRIP across the wheel wells, not the plastic skirt. My experience with using a metal strip that grazes the tire occasionally has led to a FLAT TIRE, that's all I was saying.
Good luck with the transmission, HydroJim.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
The Following User Says Thank You to slowbro For This Useful Post:
Sven7 (09-11-2012)
Old 09-10-2012, 08:53 PM   #162 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I have no metal strip.
Jim, Maybe you can research focus transmission gear ratios and find one that is geared up for lower rpms.
http://www.vibratesoftware.com/html_..._2000-2012.htm
Transmissions:
Gear Ratios
5-Speed Manual Transmission
1st: 3.42 2nd: 2.14 3rd: 1.45 4th: 1.03 5th: 0.77 Final Drive: 3.82
- Tony
Old 09-10-2012, 10:31 PM   #163 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Hopefully I can spend some time this weekend diagnosing the problem. I'm 80% sure it's the 2nd gear synchro, but based on what I've read about the focus, it could be something as simple as shift cables that need adjusted. so Hopefully I can figure it out.
Anybody have any experience with transmissions that can help me out?
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 09-11-2012, 07:57 AM   #164 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
What is it doing to make you believe its the synchro?
You might as well check the shifter cable, it should be a bit easier than tearing down the tranny. It might be in need of adjusting even if it isn't the problem.
Camry Thread
E-Bike Thread
Old 09-11-2012, 01:09 PM   #165 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
I had a car once that acted like the 2nd gear synchro was shot. It turned out to be worn out shift linkage.
Double clutching works also.
Old 09-11-2012, 04:55 PM   #166 (permalink)
HydroJim's Avatar
I believe it's the synchro because when I try to go into 2nd, there is a grinding. I'll have to investigate more.
I mainly notice it when I put the car in neutral, coast around a turn at an intersection, and then try to put it back into second. Many times it'll grind and then everyone in the intersection looks at me so I know I'm not hearing things. I also get it will upshifting and I never downshift, so I haven't checked that.
Old 09-16-2012, 02:41 PM   #167 (permalink)
HydroJim's Avatar
I have a 3 day weekend off from school so it gave me more time to get in the garage and continue working on the aeromods.
Today I went for the airdam. I may eventually go for a belly pan, but considering this took me 1 hour to complete, it sounds much better than crawling around on the ground installing a belly pan for hours.
Anybody have any tips on how large the radiator opening should be? I never use my AC because it doesn't work anyway so I would assume I need less cooling than most people.
Old 09-16-2012, 03:00 PM   #168 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
You may wanna take a cue from Vman455 (The Tyrant) and his Most Excellent Civic mods here.
Streamlining 2005 Civic EX
Old 09-16-2012, 03:16 PM   #169 (permalink)
HydroJim's Avatar
His mods are much better looking than mine! Wish I had that talent with fiberglass but I've never worked with the stuff and using coroplast was so much cheaper for me.
Old 09-16-2012, 04:33 PM   #170 (permalink)
HydroJim's Avatar
I'll be going out for a fuel economy test on my 60 mile route later tonight so hopefully I can get an idea of what all the work I've done has done.
Best I could do without scraping. I may have to trim a little off depending on how the dam goes with driveways
