08-06-2008, 08:31 PM
#161 (permalink)
Go up to post 127. It pretty much still looks exactly like it did there, except the forward edges are trimmed.
Tomorrow I'll get some new pics.
08-06-2008, 09:09 PM
#162 (permalink)
Civic 4 Life
Woo woo good luck with the primer! I think this is going to be pretty good-looking.
What method are you going to use to paint it?
08-07-2008, 05:01 PM
#163 (permalink)
Using spray cans. Apparently one full can per coat! :O
Here are a couple of pix after the first primer coat. The edges are mostly finished, but still lots of filling & smoothing out to do. (Flat grey primer hides a lot in a photo!)
More pics later....
08-07-2008, 05:11 PM
#164 (permalink)
Addicted
That is fff-ing sweet I love the way it looks on there. Good Job Darin!!!
08-07-2008, 06:55 PM
#165 (permalink)
Looks very nice Darin (even if the picture helps).
08-07-2008, 08:15 PM
#166 (permalink)
That is turning out well.
08-07-2008, 08:24 PM
#167 (permalink)
Dartmouth 2010
Make a mold!!!
08-07-2008, 08:55 PM
#168 (permalink)
Thanks, guys.
More pixxors!
The home-made brackets. Flattened & bent copper pipe, aluminum rivets. Yes. I drilled into the hatch. The sweet, pristine hatch! Oh well. I need to seal with silicone and paint these black.
Detail of the underside. I glassed in that cross member to stiffen things up. The trailing edge was a little flappy over bumps before I did that. I'll just be brush painting flat black under here. You can't see the crossmember standing behind the car - you have to get underneath and look up.
Detail of the leading edge. 5 screws up top, and there will be 2 or 3 screws per side as well. Hopefully I can find some kind of trim button to put over them to make it look a bit more pro. (Pro would have been fasteners on the underside only...) That's a strip of black duct tape on the side to protect the paint because I've been un/re-installing this multiple times while constructing.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
08-07-2008, 09:29 PM
#169 (permalink)
Hi-Tech Redneck
OMG! Scrapper alert! First they steal your fuel, then they steal your copper
GeoMetroforum.com - got mpg?
08-07-2008, 09:46 PM
#170 (permalink)
wow, looks amazing.
Have you considered putting a 3rd brakelight on the kammback, so that those in taller vehicles know when you are braking?
