Old 05-15-2014, 08:33 AM   #391 (permalink)
A brief tuft testing clip in this video.
Dr. Ferdinand Porsche Commercial, Time
<iframe width="420" height="315" src="//www.youtube.com/embed/sOE9mNe5c7M" frameborder="0" allowfullscreen></iframe>>
aerohead (05-15-2014)
Old 05-19-2014, 03:58 AM   #392 (permalink)
Random Wind Tunnel and Smoke Pictures Thread
I haven't picture right now but its a very good idea. Where you get this idea. I will post my pictures later night. I am using Volkswagen Jetta.
Sorry, new users are not permitted to post links in their signatures.
The Following User Says Thank You to wilsont777 For This Useful Post:
aerohead (05-19-2014)
Old 06-05-2014, 01:59 PM   #393 (permalink)
A bit of a stretch for this thread, but i'm getting bored.
MORE random pics...... - Page 3033 - Pelican Parts Technical BBS
The Following 3 Users Say Thank You to kach22i For This Useful Post:
aerohead (06-05-2014), Cd (07-27-2014), sendler (08-06-2014)
Old 06-05-2014, 05:33 PM   #394 (permalink)
1938 M-B 540 K Streamliner
ran across this:Mercedes-Benz 540 K Streamliner: Ahead of its time
Old 06-06-2014, 12:31 PM   #395 (permalink)
aerohead (06-06-2014)
Old 07-17-2014, 09:12 AM   #396 (permalink)
Model:
File:Maserati 250F wind tunnel model top Enzo Ferrari Museum.jpg - Wikimedia Commons
Scale model of the Maserati 250F streamliner for wind tunnel tests
aerohead (07-18-2014), NeilBlanchard (07-17-2014)
Old 08-05-2014, 09:10 AM   #397 (permalink)
SUBARU | WRX STI / WRX | Design
aerohead (08-05-2014), jedi_sol (08-06-2014)
Old 08-05-2014, 12:29 PM   #398 (permalink)
Would this help?
Discovery is key to metal wear in sliding parts
This sequence of images reveals surprising fluid-like behavior in a solid piece of metal sliding over another, forming defects leading to wear in metal parts. (Top) Two image frames of the material flow showing how these defects are spawned in the wake of the contact. (Bottom) Scanning electron microscope pictures of the corresponding wear surfaces showing a tear and a crack. Wear particles are formed when the tears and cracks detach from the surfaces.
Credit: Purdue University School of Industrial Engineering image/Anirban Mahato
Old 08-06-2014, 10:41 AM   #399 (permalink)
Some side bar on the above topic for a moment.
915 miracle juice - Pelican Parts Technical BBS
healing of tooth surface damage
Here is the updated link on the PDF for Dow Corning M-gear oil additive.
http://krayden.com/tds/dow_m_gearoil_tds.pdf
Healing of tooth surface
damage with resultant
reduction of pitting and
wear debris (Figures 1 and 2)
freebeard (08-06-2014)
Old 08-06-2014, 04:11 PM   #400 (permalink)
Services | REM Surface Engineering
REM Isotropic Superfinish
REM Surface Engineering’s ISF Process produces a surface that has several key advantages over other “superfinishing” techniques. The resulting surface is asperity free, with a non-directional (isotropic) texture. The surface has an increased bearing ratio and enhances the lubricant retention properties of the mating surface.
Services | Weddle Industries | High Performance Driveline Components for Race Vehicles | Off-Road Transaxles, Clutches, Gears
In-House REM Polishing, Magnaflux Particle Inspection and Shot Peening
Not that I can afford this stuff, but it's there.
